Issue with avi streaming to Sony BDP-S570
plank10
Post Thu Dec 30, 2010 12:56 pm
I'm sure there's an answer for this up here already but I can't seem to find it. I'm trying to stream avi files to my BDP-S570 but none show up in the library unless I rename them to mp4. Once I rename them everything works great. I'm guessing there's something simple i'm missing.
Post Thu Dec 30, 2010 3:32 pm
Re: Issue with avi streaming to Sony BDP-S570
Please provide "ffmpeg -i" result of your avi file. (see my signature).
plank10
Post Thu Dec 30, 2010 4:41 pm
done.
FFmpeg version SVN-r23012, Copyright (c) 2000-2010 the FFmpeg developers
built on May 3 2010 19:05:24 with gcc 3.4.5 (mingw-vista special r3)
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-li
bmp3lame --enable-w32threads --extra-ldflags=-L/static/lib --extra-cflags=-I/static/include
libavutil 50.15. 0 / 50.15. 0
libavcodec 52.66. 0 / 52.66. 0
libavformat 52.62. 0 / 52.62. 0
libavdevice 52. 2. 0 / 52. 2. 0
libswscale 0.10. 0 / 0.10. 0
Input #0, avi, from 'H:\music\!tv shows\community\Community.S02E01.Anthropology.101.HDTV.XviD-FQM.avi':
ISFT : transcode-1.0.4
Duration: 00:20:58.44, start: 0.000000, bitrate: 1167 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 624x352 [PAR 1:1 DAR 39:22], 23.98 tbr, 23.98 tbn, 23.98 tbc
Stream #0.1: Audio: mp3, 48000 Hz, 2 channels, s16, 128 kb/s
Post Thu Dec 30, 2010 7:14 pm
Serviio doesn't care about extensions (for file type scanning), so this makes no sense :?
plank10
Post Thu Dec 30, 2010 8:20 pm
Not sure if this means anything but I can play the avi files on an xbox 360 streaming from Windows Media Player.
plank10
Post Fri Dec 31, 2010 3:08 pm
also the Sony sees the Windows library but shows no files as well. it's odd.
Post Fri Dec 31, 2010 4:19 pm
it's possible that you have US or Canadian version of the player, check the forum for a proper profile
plank10
Post Wed Jan 05, 2011 4:48 pm
That did it. Thanks!
vghadge
Post Sun Jan 16, 2011 12:47 am
I'm having a similar issue (with my Sony Network Media Player SMP-N100). I can see the folders but cannot view anything inside it. It says "No playable files". I'm in US. Please let me know how do I change the profile so that I would be able to view the media files. Thanks in advance.
Post Sun Jan 16, 2011 12:48 am
vghadge
Post Sun Jan 16, 2011 1:12 am
Thank you so much for your quick response. Had couple of very dum questions. I can see the file called "profiles" in the "config" folder. I'm assuming I need to change this. Should I replace the entire code in this file with the US version of the profile you sent the link to ?? Can I open it up in MS Word, do the "replace" and then save it ?
Post Sun Jan 16, 2011 1:17 am
No, open it in a simple text editor (like notepad, definitely not MS Word ;-) ), replace the current Sony DB profile or add the US one at the end (but make sure that ID attribute includes unique value). Then save and restart Serviio service (or restart the PC).
More info here: http://www.serviio.org/index.php?option ... icle&id=16
palu11
Post Sun Feb 27, 2011 9:41 pm
I installed Serviio and got everything up and running, updated the profiles.xml file with the latest US and EU profiles but I still cannot see AVI files from my Sony BDP-S570. I still get the messages about no files found. Am I missing something? I have restarted the service and switched profiles multiple times. Any help you can provide is much appreciated. This is pretty aggravating *Sony's fault) because everything was working fine until today. It just started acting up for no reason.
Thanks in advance!
Post Mon Feb 28, 2011 12:50 am
create a topic in Sony's section and post a detailed log there
DarkMatter
Post Mon Mar 07, 2011 12:53 am
Just wanted to say a big Thanks for Serviio - Installed the latest version which already has the profiles - started the console - appeared on my BD player an hey presto it can suddenly see and play avi files. Very pleased!
JJKnight
Post Wed Aug 10, 2011 1:11 am
zip wrote:Serviio doesn't care about extensions (for file type scanning), so this makes no sense :?
I have a Sony BDP-BX57 Bluray player and was having a similar issue. I used to just re encode the files with whatever encoder I could find and they worked. Tried renaming the file extension to MP4 like another poster suggested and now my file plays fine. I agree that it shouldn't matter as the only change was the extension but it does play now.
The ffmpeg-i of a working file follows:
Memphis Beat 7
libavutil 50.15. 1 / 50.15. 1
libavcodec 52.72. 2 / 52.72. 2
libavformat 52.64. 2 / 52.64. 2
libavfilter 1.19. 0 / 1.19. 0
libswscale 0.11. 0 / 0.11. 0
BTW I did not crop this, this really is all it says at the bottom and it worked fine.
The ffmpeg-i of the non working file is:
Memphis Beat 8
Input #0, avi, from 'Memphis.Beat.S02E08.Identity.Crisis.HDTV.XviD-FQM.avi':
Duration: 00:41:33.84, start: 0.000000, bitrate: 1178 kb/s
Can't find a difference myself except the obvious extra stream info but again the first file played just fine without it!
And again all I had to do was change the file extension to MP4 to make the second file play.
Weird Huh? ;)
Return to General discussion
Users browsing this forum: Baidu [Spider] and 3 guests
