"Filetype not recognized" on Samsung plasma
I'm quite new to this so please excuse any newbie mistakes... though, I don't get this to work with video files
Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.79, timeout = 0
-name = 'Unrecognized device', ipAddress='192.168.1.75', profile = '1'
-name = 'Unrecognized device', ipAddress='192.168.1.69', profile = '1'
-name = 'PS51D8000', ipAddress='192.168.1.69', profile = '1'
-name = 'AVR-3311', ipAddress='192.168.1.75', profile = '1
- name = 'Unrecognized device', ipAddress='192.168.1.64', profile = '1''
- name = 'Unrecognized device', ipAddress='192.168.1.79', profile = '1'
- name = 'Sony BD Player', ipAddress='192.168.1.70', profile = '10'
Xabre wrote:I clicked stop and start
Complete name : C:\Users\Hibiscus\Videos\Serviio test\Videokamera 001 - HD - Xvid Video.avi
Format : AVI
File size : 93.7 MiB
Duration : 1mn 3s
Overall bit rate : 12.3 Mbps
Writing application : Lavf51.12.1
Format : xvid
Codec ID : xvid
Duration : 1mn 3s
Bit rate : 12.2 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 fps
Bits/(Pixel*Frame) : 0.117
Stream size : 92.6 MiB (99%)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1mn 3s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 998 KiB (1%)
Alignment : Aligned on interleaves
Interleave, duration : 26 ms (1.31 video frame)General
Unique ID : 168348648403719580577546155723716462494 (0x7EA6C532C2870C1E037BA147C20E879E)
Complete name : C:\Users\Hibiscus\Videos\Serviio test\Videokamera 002 - HD - MKV Video.mkv
Format : Matroska
Format version : Version 2
File size : 76.1 MiB
Duration : 35s 82ms
Overall bit rate : 18.2 Mbps
Writing library : Lavf51.12.1
Format : AVC
Format profile : Baseline@L1.3
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=12
Codec ID : V_MPEG4/ISO/AVC
Duration : 35s 80ms
Bit rate : 17.7 Mbps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.171
Stream size : 74.0 MiB (97%)
Language : English
Format : MPEG Audio
Mode : Joint stereo
Codec ID : A_MPEG/L3
Codec ID/Hint : MP3
Duration : 35s 81ms
Bit rate : 128 Kbps
Stream size : 548 KiB (1%)
Language : EnglishXabre wrote:Hmm... the "ffmpeg" (program) does not launch correctly on my Win7 machine. When I click the file there's just a flash with a small cmd pop-up and then it's gone. I will try on a different machine.
Xabre wrote:Mediainfo details (Xvid)
Xabre wrote:Mediainfo details (MKV)
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "c:\Videokamera 001 - HD - Xvid Video.avi"
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
Input #0, avi, from 'c:\Videokamera 001 - HD - Xvid Video.avi':
encoder : Lavf51.12.1
Duration: 00:01:03.86, start: 0.000000, bitrate: 12311 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 50 tbr, 50 tbn, 50 tbc
Stream #0.1: Audio: mp3, 44100 Hz, 2 channels, s16, 128 kb/s
At least one output file must be specifiedC:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "c:\Videokamera 002 - HD - MKV Video.mkv"
686-mingw32-
[matroska,webm @ 016bbd00] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 100.00 (100/1) -> 250.00 (250/1)
Input #0, matroska,webm, from 'c:\Videokamera 002 - HD - MKV Video.mkv':
Duration: 00:00:35.08, start: 0.000000, bitrate: 128 kb/s
Stream #0.0: Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 50 fps, 250 tbr, 1k tbn, 100 tbc
At least one output file must be specifiedXabre wrote:The source files are AVCHD from a Panasonic video camera. I converted them to XVID, DivX, MKV etc using a video converter from [MODERATED]. Maybe there are better converters?
Users browsing this forum: Baidu [Spider] and 11 guests
