Cant find server on KDL-EX711
Agnin
Post Fri Sep 23, 2011 4:49 pm
Hi all
Used Serviio for several months without any problems. But got some new equipment from my ISP and now i cant find the server? The tv is found by serviio and the tv is able to go on the internet.
I worked fine yesterday but had to reset the router and now no server :(
Help
Log file
2011-09-23 18:43:25,142 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-09-23 18:43:25,177 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-09-23 18:43:31,277 INFO [DBSchemaUpdateExecutor] Updating DB schema
2011-09-23 18:43:37,606 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-09-23 18:43:37,933 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-09-23 18:43:38,026 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-09-23 18:43:38,076 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-09-23 18:43:38,115 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-09-23 18:43:38,161 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-09-23 18:43:38,188 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-09-23 18:43:38,258 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-09-23 18:43:38,276 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-09-23 18:43:38,392 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-09-23 18:43:38,575 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-09-23 18:43:38,624 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-09-23 18:43:38,709 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-09-23 18:43:38,892 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-09-23 18:43:38,909 INFO [WebServer] Socket buffer set to 65535 bytes
2011-09-23 18:43:38,941 INFO [WebServer] WebServer starting on port 8895
2011-09-23 18:43:39,134 INFO [Device] Created UPnP Device with UUID: 61cd396e-1894-3da9-91a2-e8090bcf4e54, bound address: 192.168.1.11
2011-09-23 18:43:39,150 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-09-23 18:43:39,154 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-09-23 18:43:39,156 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-09-23 18:43:39,156 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-09-23 18:43:39,157 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-23 18:43:39,157 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-09-23 18:43:39,157 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1316796219157, LastAccessTime = 1316796219157, getTimeToLiveSeconds() = -1, createTime = 1316796219157 ]
2011-09-23 18:43:39,159 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-09-23 18:43:39,168 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-09-23 18:43:39,168 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-23 18:43:39,168 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-09-23 18:43:39,168 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-09-23 18:43:39,168 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-23 18:43:39,168 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-09-23 18:43:39,168 INFO [CompositeCacheConfigurator] Finished configuration in 13 ms.
2011-09-23 18:43:39,170 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-09-23 18:43:39,173 INFO [EventDispatcher] Starting EventDispatcher
2011-09-23 18:43:39,173 INFO [RendererSearchSender] Searching for Renderer devices
2011-09-23 18:43:39,173 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-09-23 18:43:39,174 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-09-23 18:43:39,190 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 192.168.1.11, timeout = 0
2011-09-23 18:43:41,722 INFO [RendererManager] Stored a new renderer: uuid='00000000-0000-1010-8000-78843c4e830e', name = 'KDL-40EX711', ipAddress='192.168.1.10', profile = '9'
2011-09-23 18:43:51,832 INFO [ServiioConsole] Starting Serviio Console
2011-09-23 18:43:51,898 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-09-23 18:43:52,467 INFO [Messages] Loaded console message bundle for locale: en
2011-09-23 18:43:53,302 INFO [Messages] Loaded console message bundle for locale: en
2011-09-23 18:43:53,414 INFO [UpdateChecker] Checking if a new version is available
2011-09-23 18:43:58,692 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-09-23 18:43:58,949 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-09-23 18:44:05,447 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-09-23 18:44:05,447 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-09-23 18:45:12,576 INFO [RendererManager] Stored a new renderer: uuid='49cb7543-1962-4d75-81ae-c10eab3720dc', name = 'Unrecognized device', ipAddress='192.168.1.11', profile = '1'
Post Fri Sep 23, 2011 7:28 pm
Re: Cant find server on KDL-EX711
What are the IP addresses of the computer running serviio and the KDL-EX711
Agnin
Post Sat Sep 24, 2011 8:07 am
The EX711 has 192.168.1.10
I'm not entirely sure but think the pc running serviio has 192.168.1.11
serviio sees the Tv with the above adress and also an unrecognized device with the pc adress
mikexo
Post Sat Sep 24, 2011 3:55 pm
I'm having the same problem. Serviio was working fine, but I needed faster router and after that I haven't been able to get this work. Serviio finds my TV with the correct IP ()192.168.1.5) and shows a green dot indicating that everything is working, but my TV can't seem to connect to Serviio server. Computer IP is 192.168.1.2.
edit: I don't know what I did, but now I can access my Serviio media library from my TV and my TV seems to recognize my laptop, but when I browse to a file and start play, it says that it couldn't establish connection to server.
edit2: It actually did play some files, small samples I had. But on 99% of the files it says that couldn't establish connection to server, try again later.
edit3: OK, this is embarrassing. Apparently after update to 0.6 Serviio lost it's admin privileges. I wasn't able to play because it didn't have access to write to /windows/temp. Working like a charm once again. Thanks.
