[DONE] vimeo
• Page 1 of 1
does it even need to be requested?
Re: vimeo
Looked into it, will have to wait for 0.6.1
Petr
Help translate Serviio
Re: vimeo
looks like the only problem here is that vimeo wants you to authenticate against their site and serviio doesn't provide an option to enter the login information. As the plugins are available as plain source code shouldn't it be possible to edit the plugin code with the users vimeo credentials? Not the best bet in terms of security as the credentials would be saved plaintext on hard drive but at least an option, depending on when 0.6.1 is scheduled.
Maybee there is another reason why it wont work with 0.6.0? I don't know serviios plugin system in detail yet.
Greetings
DizTortion
Greetings
DizTortion
Re: vimeo
I didn't need to authenticate, looking at the channel feeds. I can get the content URL but it expires within 1 second so it would expire before serviio can play it. Need to enable invoking the plugins just before the file is played in 0.6.1
Petr
Re: vimeo
I have it working, will be released after 0.6.1 is out.
Petr
Re: vimeo
0.6.1 is not out yet.
Petr
Re: vimeo
Vimeo isnt available in my plugins pack either it will be included in a pack im gonna compile especially for 0.6.1 once its out
Re: vimeo
Petr
• Page 1 of 1
