bluu-ray btt370 - getting started
4hrserver
Post Thu Sep 15, 2011 12:17 pm
I started running serviio on my windows XP machine.
I have two other devices on my wireless network a PS3, and my Panasonic btt370.
As soon as I installed Serviio my PS3 auto detected it, and has worked fine ever since. But I cannot even get my blu ray player to even detect the server.
I am going into "Viera Cast" and nothing is showing up except the default content (Youtube, Picasa etc...). I manually added my blu ray IP address into the rendering device section and bound my server IP address.
Sorry if this an overly simple question, but is there something stupid and obvious I am missing? Why can my PS3 detect serviio and my blu ray cannot?
Post Thu Sep 15, 2011 12:51 pm
Re: bluu-ray btt370 - getting started
Could you remove all device in the serviio console list, enable detailed logging (see signature), clean log file, restart serviio service then post the result log file here?
4hrserver
Post Thu Sep 15, 2011 11:26 pm
Is this what you are looking for?
2011-09-15 19:24:38,796 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2011-09-15 19:24:38,796 INFO [MediaServer] ------------------------------------------------------------------------
2011-09-15 19:24:38,796 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-09-15 19:24:38,796 INFO [MediaServer] Petr Nejedly 2009-2011
2011-09-15 19:24:38,796 INFO [MediaServer] http://www.serviio.org
2011-09-15 19:24:38,796 INFO [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2011-09-15 19:24:38,796 INFO [MediaServer] OS Windows XP x86 5.1
2011-09-15 19:24:38,796 INFO [MediaServer] File encoding: windows-1252
2011-09-15 19:24:38,906 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-09-15 19:24:38,968 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-09-15 19:24:38,968 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2011-09-15 19:24:39,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2011-09-15 19:24:39,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2011-09-15 19:24:39,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2011-09-15 19:24:39,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2011-09-15 19:24:39,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2011-09-15 19:24:39,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2011-09-15 19:24:39,906 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2011-09-15 19:24:39,906 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2011-09-15 19:24:40,093 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-09-15 19:24:40,109 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2011-09-15 19:24:40,437 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-09-15 19:24:40,437 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2011-09-15 19:24:40,609 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-09-15 19:24:40,609 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2011-09-15 19:24:40,703 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-09-15 19:24:40,703 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2011-09-15 19:24:40,781 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-09-15 19:24:40,781 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2011-09-15 19:24:40,875 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-09-15 19:24:40,875 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2011-09-15 19:24:40,937 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-09-15 19:24:40,937 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2011-09-15 19:24:41,078 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-09-15 19:24:41,078 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2011-09-15 19:24:41,125 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-09-15 19:24:41,125 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 9
2011-09-15 19:24:41,359 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-09-15 19:24:41,359 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2011-09-15 19:24:41,734 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-09-15 19:24:41,734 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 12
2011-09-15 19:24:41,843 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-09-15 19:24:41,843 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2011-09-15 19:24:41,921 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-09-15 19:24:41,921 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path E:\Serviio\bin\\..\lib/ffmpeg.exe
2011-09-15 19:24:41,921 DEBUG [ProcessExecutor] Starting E:\Serviio\bin\\..\lib/ffmpeg.exe
2011-09-15 19:24:41,984 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-09-15 19:24:41,984 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2011-09-15 19:24:42,000 INFO [WebServer] Socket buffer set to 65535 bytes
2011-09-15 19:24:42,031 INFO [WebServer] WebServer starting on port 8895
2011-09-15 19:24:42,171 INFO [Device] Created UPnP Device with UUID: b417b37c-4030-3c89-bb6e-b5e8798e235b, bound address: 192.168.2.10
2011-09-15 19:24:42,203 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-09-15 19:24:42,203 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-09-15 19:24:42,203 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-09-15 19:24:42,203 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-09-15 19:24:42,203 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-15 19:24:42,203 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-09-15 19:24:42,203 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1316129082203, LastAccessTime = 1316129082203, getTimeToLiveSeconds() = -1, createTime = 1316129082203 ]
2011-09-15 19:24:42,203 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-09-15 19:24:42,218 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-09-15 19:24:42,218 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-15 19:24:42,218 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-09-15 19:24:42,218 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-09-15 19:24:42,218 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-15 19:24:42,218 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-09-15 19:24:42,218 INFO [CompositeCacheConfigurator] Finished configuration in 15 ms.
2011-09-15 19:24:42,234 DEBUG [DiscoveryManager] UPNP device b417b37c-4030-3c89-bb6e-b5e8798e235b (192.168.2.10) is available
2011-09-15 19:24:42,234 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-09-15 19:24:42,234 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-09-15 19:24:42,234 INFO [EventDispatcher] Starting EventDispatcher
2011-09-15 19:24:42,234 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (NVIDIA nForce Networking Controller) and address 192.168.2.10, timeout = 0
2011-09-15 19:24:42,234 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-09-15 19:24:42,234 INFO [RendererSearchSender] Searching for Renderer devices
2011-09-15 19:24:42,250 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (NVIDIA nForce Networking Controller) and address 192.168.2.10, timeout = 0
2011-09-15 19:24:42,250 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth0 (NVIDIA nForce Networking Controller) and address 192.168.2.10, timeout = 0
2011-09-15 19:24:42,265 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b417b37c-4030-3c89-bb6e-b5e8798e235b
2011-09-15 19:24:42,265 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2011-09-15 19:24:42,265 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.2.10:1447
2011-09-15 19:24:42,281 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.2.10:1447
2011-09-15 19:24:44,078 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-09-15 19:24:48,265 DEBUG [RendererSearchSender] Finished searching for Renderer devices
4hrserver
Post Sat Sep 17, 2011 1:36 pm
Another quick note, I did a ping test from my computer and it can send info to my panasonic
4hrserver
Post Sat Sep 24, 2011 5:32 pm
Did I not provide the right info or my question is not worth answering?
Post Sat Sep 24, 2011 7:21 pm
your post will be replied to when some has any information for you, also the forum is very busy atm so post will take longer to be answered
Post Sun Sep 25, 2011 12:46 am
what is the IP address of your player?
4hrserver
Post Sun Sep 25, 2011 3:44 am
My PS# which works fine is 192.168.2.14, and my Panasonic which is not detecting Serviio is 198.168.2.16
Post Sun Sep 25, 2011 3:47 am
4hrserver wrote:My PS# which works fine is 192.168.2.14, and my Panasonic which is not detecting Serviio is 198.168.2.16
is that a miss type did you mean 192.168.2.16???
4hrserver
Post Sun Sep 25, 2011 5:37 am
Yes it was, sorry. My IP for my Panasonic is 192.168.2.16
Post Mon Sep 26, 2011 2:51 pm
4hrserver wrote:Yes it was, sorry. My IP for my Panasonic is 192.168.2.16
No entries with 192.168.2.14 or 192.168.2.16 on your log file ?!
Could you retry?
4hrserver
Post Mon Sep 26, 2011 11:44 pm
2011-09-26 19:37:29,093 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2011-09-26 19:37:29,093 INFO [MediaServer] ------------------------------------------------------------------------
2011-09-26 19:37:29,093 INFO [MediaServer] Serviio DLNA media streaming server v 0.6 (rev. a369baa35bfe)
2011-09-26 19:37:29,093 INFO [MediaServer] Petr Nejedly 2009-2011
2011-09-26 19:37:29,093 INFO [MediaServer] http://www.serviio.org
2011-09-26 19:37:29,093 INFO [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2011-09-26 19:37:29,093 INFO [MediaServer] OS Windows XP x86 5.1
2011-09-26 19:37:29,093 INFO [MediaServer] File encoding: windows-1252
2011-09-26 19:37:29,484 INFO [MediaServer] Headless mode enabled: true
2011-09-26 19:37:29,484 INFO [MediaServer] ------------------------------------------------------------------------
2011-09-26 19:37:29,593 INFO [RestletServer] Starting Restlet server exposed on port 23423
2011-09-26 19:37:29,640 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-09-26 19:37:29,656 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2011-09-26 19:37:30,875 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2011-09-26 19:37:30,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2011-09-26 19:37:30,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2011-09-26 19:37:30,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2011-09-26 19:37:30,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2011-09-26 19:37:30,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2011-09-26 19:37:30,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2011-09-26 19:37:30,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2011-09-26 19:37:30,890 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2011-09-26 19:37:31,109 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-09-26 19:37:31,140 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2011-09-26 19:37:31,531 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-09-26 19:37:31,531 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2011-09-26 19:37:31,843 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-09-26 19:37:31,843 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2011-09-26 19:37:32,015 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-09-26 19:37:32,015 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2011-09-26 19:37:32,171 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-09-26 19:37:32,171 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2011-09-26 19:37:32,296 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-09-26 19:37:32,296 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2011-09-26 19:37:32,421 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-09-26 19:37:32,421 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2011-09-26 19:37:32,734 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-09-26 19:37:32,734 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2011-09-26 19:37:32,781 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2011-09-26 19:37:32,781 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 9
2011-09-26 19:37:33,171 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-09-26 19:37:33,171 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2011-09-26 19:37:33,781 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-09-26 19:37:33,781 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 12
2011-09-26 19:37:34,015 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-09-26 19:37:34,015 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2011-09-26 19:37:34,234 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2011-09-26 19:37:34,234 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2011-09-26 19:37:34,296 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2011-09-26 19:37:34,296 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2011-09-26 19:37:34,328 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2011-09-26 19:37:34,328 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2011-09-26 19:37:34,437 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2011-09-26 19:37:34,437 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2011-09-26 19:37:34,484 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2011-09-26 19:37:34,484 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2011-09-26 19:37:34,609 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2011-09-26 19:37:34,609 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 19
2011-09-26 19:37:35,015 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV 2011' (id=19)
2011-09-26 19:37:35,015 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2011-09-26 19:37:35,375 INFO [ProfilesDefinitionParser] Added profile 'Sony SMP-N100' (id=20)
2011-09-26 19:37:35,390 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-09-26 19:37:35,406 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-09-26 19:37:35,406 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-09-26 19:37:35,406 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-09-26 19:37:35,406 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-26 19:37:35,406 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-09-26 19:37:35,406 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1317080255406, LastAccessTime = 1317080255406, getTimeToLiveSeconds() = -1, createTime = 1317080255406 ]
2011-09-26 19:37:35,437 INFO [LRUMemoryCache] initialized LRUMemoryCache for thumbnails
2011-09-26 19:37:35,437 INFO [CompositeCache] Constructed cache with name [thumbnails] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-26 19:37:35,437 INFO [LRUMemoryCache] initialized LRUMemoryCache for online_feeds
2011-09-26 19:37:35,437 INFO [CompositeCache] Constructed cache with name [online_feeds] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-26 19:37:35,437 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-09-26 19:37:35,437 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-09-26 19:37:35,437 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-26 19:37:35,437 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-09-26 19:37:35,437 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-09-26 19:37:35,437 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-26 19:37:35,437 INFO [CompositeCacheConfigurator] Parsed regions [thumbnails, online_feeds, local_default, local_resetafterplay]
2011-09-26 19:37:35,437 INFO [CompositeCacheConfigurator] Finished configuration in 31 ms.
2011-09-26 19:37:35,453 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2011-09-26 19:37:35,625 INFO [WebServer] Socket buffer set to 65535 bytes
2011-09-26 19:37:35,625 INFO [Device] Created UPnP Device with UUID: b417b37c-4030-3c89-bb6e-b5e8798e235b, bound address: 192.168.2.10
2011-09-26 19:37:35,640 INFO [PluginCompilerThread] Looking for plugins at E:\Serviio\bin\..\plugins
2011-09-26 19:37:35,640 INFO [PluginCompilerThread] Started looking for plugins
2011-09-26 19:37:35,656 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path E:\Serviio\bin\\..\lib/ffmpeg.exe
2011-09-26 19:37:35,656 DEBUG [ProcessExecutor] Starting E:\Serviio\bin\\..\lib/ffmpeg.exe
2011-09-26 19:37:35,750 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-09-26 19:37:35,781 INFO [WebServer] WebServer starting on port 8895
2011-09-26 19:37:35,796 DEBUG [DiscoveryManager] UPNP device b417b37c-4030-3c89-bb6e-b5e8798e235b (192.168.2.10) is available
2011-09-26 19:37:35,796 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-09-26 19:37:35,796 INFO [EventDispatcher] Starting EventDispatcher
2011-09-26 19:37:35,796 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-09-26 19:37:35,796 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (NVIDIA nForce Networking Controller) and address 192.168.2.10, timeout = 0
2011-09-26 19:37:35,796 INFO [RendererSearchSender] Searching for Renderer devices
2011-09-26 19:37:35,796 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-09-26 19:37:35,843 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth0 (NVIDIA nForce Networking Controller) and address 192.168.2.10, timeout = 0
2011-09-26 19:37:35,843 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2011-09-26 19:37:35,859 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.2.10:1252
2011-09-26 19:37:35,890 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (NVIDIA nForce Networking Controller) and address 192.168.2.10, timeout = 0
2011-09-26 19:37:35,890 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b417b37c-4030-3c89-bb6e-b5e8798e235b
2011-09-26 19:37:37,046 DEBUG [WebServer] Incoming connection from /192.168.2.14:58730
2011-09-26 19:37:37,046 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device b417b37c-4030-3c89-bb6e-b5e8798e235b from 192.168.2.14 (headers = [Host: 192.168.2.10:8895,Date: Tue, 27 Sep 2011 00:58:27 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";])
2011-09-26 19:37:37,046 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.14
2011-09-26 19:37:37,062 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.2.10:8895,Date: Tue, 27 Sep 2011 00:58:27 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";]
2011-09-26 19:37:37,062 DEBUG [RendererDAOImpl] Creating a new Renderer (uuid = 032f7211-c265-4d20-9f5a-38bda4ae5e47)
2011-09-26 19:37:37,140 INFO [RendererManager] Stored a new renderer: uuid='032f7211-c265-4d20-9f5a-38bda4ae5e47', name = 'Playstation 3', ipAddress='192.168.2.14', profile = '4'
2011-09-26 19:37:37,140 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.14
2011-09-26 19:37:37,328 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Playstation 3'
2011-09-26 19:37:37,343 DEBUG [WebServer] Incoming connection from /192.168.2.14:58729
2011-09-26 19:37:37,359 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2011-09-26 19:37:37,375 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2011-09-26 19:37:37,406 DEBUG [WebServer] Incoming connection from /192.168.2.14:58728
2011-09-26 19:37:37,406 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.2.14:
2011-09-26 19:37:37,421 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.14
2011-09-26 19:37:37,671 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-09-26 19:37:37,687 DEBUG [WebServer] Incoming connection from /192.168.2.14:58727
2011-09-26 19:37:37,687 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.2.14:
2011-09-26 19:37:37,687 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.14
2011-09-26 19:37:37,843 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = 0, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID, startIndex = 0, count = 1, sortCriteria =
2011-09-26 19:37:37,859 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-09-26 19:37:37,859 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-09-26 19:37:37,859 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=0, titleKey=pc5dczc_media_library, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = null
2011-09-26 19:37:37,875 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A, titleKey=audio, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:37,890 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_A, titleKey=artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:38,000 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,000 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,000 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,015 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,015 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=AL_A, titleKey=album_artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:38,015 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,031 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,031 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForAlbumArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,046 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,046 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:38,046 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=local_default
2011-09-26 19:37:38,062 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:38,062 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioGenresByNameCommand, containerClass=MUSIC_GENRE, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,062 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForGenreCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,078 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_C, titleKey=composers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:38,078 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,078 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposersForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=COM, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,093 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForComposerCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,093 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForComposerAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,093 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:38,109 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,109 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForInitialCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,109 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_R, titleKey=random, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2011-09-26 19:37:38,125 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListRandomSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=no_cache
2011-09-26 19:37:38,125 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_OF, titleKey=online_feeds, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2011-09-26 19:37:38,125 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioOnlineFeedsByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=REPO, recursive=false, cacheRegion=no_cache
2011-09-26 19:37:38,140 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForOnlineFeedCommand, containerClass=null, itemClass=AUDIO_ITEM, idPrefix=F, recursive=false, cacheRegion=no_cache
2011-09-26 19:37:38,140 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_S, titleKey=All songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2011-09-26 19:37:38,156 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,156 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_AS, titleKey=Artist Songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2011-09-26 19:37:38,156 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART_S, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,171 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,171 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_ALB, titleKey=All albums, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2011-09-26 19:37:38,171 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,187 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,187 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I, titleKey=image, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:38,187 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_A, titleKey=albums, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:38,203 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListFlatImageFoldersByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,203 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForFolderCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,218 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:38,218 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=local_default
2011-09-26 19:37:38,218 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_Y, titleKey=year, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:38,234 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,234 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,234 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_T, titleKey=month, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:38,250 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,250 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationMonthsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=MON, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,265 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationMonthAndYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,265 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_OF, titleKey=online_feeds, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2011-09-26 19:37:38,265 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageOnlineFeedsByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=REPO, recursive=false, cacheRegion=no_cache
2011-09-26 19:37:38,281 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForOnlineFeedCommand, containerClass=null, itemClass=PHOTO, idPrefix=F, recursive=false, cacheRegion=no_cache
2011-09-26 19:37:38,281 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_AI, titleKey=All images, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2011-09-26 19:37:38,296 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListAllImagesCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,296 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V, titleKey=video, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:38,296 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:38,312 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,312 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,312 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_M, titleKey=movies, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:38,328 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosByNameCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,328 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_S, titleKey=series, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:38,343 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeriesByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SER, recursive=false, cacheRegion=local_resetafterplay
2011-09-26 19:37:38,343 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeasonsForSeriesCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SSN, recursive=false, cacheRegion=local_resetafterplay
2011-09-26 19:37:38,343 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListEpisodesForSeriesSeasonCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2011-09-26 19:37:38,359 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:38,359 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=local_default
2011-09-26 19:37:38,375 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LV, titleKey=last_viewed, class=CONTAINER, cacheRegion=local_resetafterplay, browsable = null, editable = true
2011-09-26 19:37:38,375 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastViewedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2011-09-26 19:37:38,375 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LA, titleKey=last_added, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:38,390 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastAddedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,390 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:38,406 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoGenresByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,406 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForGenreCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,421 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_A, titleKey=actors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:38,421 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,421 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,437 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForActorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,437 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_D, titleKey=directors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:38,453 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,453 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,468 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForDirectorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,468 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_P, titleKey=producers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-09-26 19:37:38,484 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,484 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducersForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,484 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForProducerCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-09-26 19:37:38,500 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_OF, titleKey=online_feeds, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2011-09-26 19:37:38,500 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoOnlineFeedsByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=REPO, recursive=false, cacheRegion=no_cache
2011-09-26 19:37:38,515 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForOnlineFeedCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=F, recursive=false, cacheRegion=no_cache
2011-09-26 19:37:38,531 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-09-26 19:37:38,531 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-09-26 19:37:38,546 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-09-26 19:37:38,718 DEBUG [WebServer] Incoming connection from /192.168.2.14:58726
2011-09-26 19:37:38,718 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon largePNG
2011-09-26 19:37:38,906 DEBUG [WebServer] Incoming connection from /192.168.2.14:58725
2011-09-26 19:37:38,906 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon largePNG
2011-09-26 19:37:38,984 DEBUG [WebServer] Incoming connection from /192.168.2.14:58724
2011-09-26 19:37:38,984 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon largePNG
2011-09-26 19:37:41,859 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2011-09-26 19:37:43,140 DEBUG [ServiioConsole] Initializing Serviio Console
2011-09-26 19:37:43,156 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2011-09-26 19:37:43,156 INFO [ServiioConsole] Starting Serviio Console
2011-09-26 19:37:43,187 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2011-09-26 19:37:43,218 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-09-26 19:37:44,078 INFO [Messages] Loaded console message bundle for locale: en
2011-09-26 19:37:44,390 DEBUG [ServiioConsole] Retrieving preferred console language
2011-09-26 19:37:44,937 DEBUG [ServiioConsole] Setting console locale to be: en
2011-09-26 19:37:44,937 INFO [Messages] Loaded console message bundle for locale: en
2011-09-26 19:37:45,046 INFO [UpdateChecker] Checking if a new version is available
2011-09-26 19:37:45,593 DEBUG [ServiioFrameView] Initializing main frame
2011-09-26 19:37:45,593 DEBUG [ServiioFrameView] System tray is supported
2011-09-26 19:37:46,875 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-09-26 19:37:46,906 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
4hrserver
Post Mon Sep 26, 2011 11:50 pm
I read through the result before I posted, and can see that this time (with both machines turned on...) that serviio was able to detect my PS3 and not my Panasonic.
My panasonic is connected to the network, and as I said in a previous post I can ping it from my machine.
Return to Panasonic
