[SOLVED] no subtitle, lg ld840
It is impossible to see subtitles.
However, Nero MediaHome and Mezzmo that are in windows works.
All servers works in linux streaming video, but subtitles no.
Is there a solution to this?
2011-09-22 21:02:52,789 INFO [MediaServer] ------------------------------------------------------------------------
2011-09-22 21:02:52,825 INFO [MediaServer] Serviio DLNA media streaming server v 0.6 (rev. a369baa35bfe)
2011-09-22 21:02:52,825 INFO [MediaServer] Petr Nejedly 2009-2011
2011-09-22 21:02:52,825 INFO [MediaServer] http://www.serviio.org
2011-09-22 21:02:52,825 INFO [MediaServer] Java 1.6.0_22-Sun Microsystems Inc.
2011-09-22 21:02:52,826 INFO [MediaServer] OS Linux i386 2.6.38-11-generic
2011-09-22 21:02:52,826 INFO [MediaServer] File encoding: UTF-8
2011-09-22 21:02:52,839 INFO [MediaServer] Headless mode enabled: true
2011-09-22 21:02:52,839 INFO [MediaServer] ------------------------------------------------------------------------
2011-09-22 21:02:53,469 INFO [RestletServer] Starting Restlet server exposed on port 23423
2011-09-22 21:02:53,686 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-09-22 21:02:56,265 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-09-22 21:02:56,800 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-09-22 21:02:57,016 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-09-22 21:02:57,130 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-09-22 21:02:57,263 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-09-22 21:02:57,359 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-09-22 21:02:57,464 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-09-22 21:02:57,657 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-09-22 21:02:57,690 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2011-09-22 21:02:57,959 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-09-22 21:02:58,476 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-09-22 21:02:58,636 INFO [ServiioConsole] Starting Serviio Console
2011-09-22 21:02:58,654 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-09-22 21:02:58,813 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2011-09-22 21:02:58,862 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2011-09-22 21:02:58,887 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2011-09-22 21:02:58,965 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2011-09-22 21:02:59,015 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2011-09-22 21:02:59,133 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2011-09-22 21:02:59,458 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV 2011' (id=19)
2011-09-22 21:02:59,736 INFO [ProfilesDefinitionParser] Added profile 'Sony SMP-N100' (id=20)
2011-09-22 21:02:59,805 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-09-22 21:02:59,839 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-09-22 21:02:59,843 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-09-22 21:02:59,843 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-09-22 21:02:59,844 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-22 21:02:59,844 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-09-22 21:02:59,845 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1316736179844, LastAccessTime = 1316736179844, getTimeToLiveSeconds() = -1, createTime = 1316736179844 ]
2011-09-22 21:02:59,887 INFO [LRUMemoryCache] initialized LRUMemoryCache for thumbnails
2011-09-22 21:02:59,887 INFO [CompositeCache] Constructed cache with name [thumbnails] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-22 21:02:59,887 INFO [LRUMemoryCache] initialized LRUMemoryCache for online_feeds
2011-09-22 21:02:59,887 INFO [CompositeCache] Constructed cache with name [online_feeds] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-22 21:02:59,887 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-09-22 21:02:59,887 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-09-22 21:02:59,887 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-22 21:02:59,888 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-09-22 21:02:59,888 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-09-22 21:02:59,888 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-09-22 21:02:59,888 INFO [CompositeCacheConfigurator] Parsed regions [thumbnails, online_feeds, local_default, local_resetafterplay]
2011-09-22 21:02:59,888 INFO [CompositeCacheConfigurator] Finished configuration in 47 ms.
2011-09-22 21:03:00,026 INFO [WebServer] Socket buffer set to 65535 bytes
2011-09-22 21:03:00,026 INFO [Device] Created UPnP Device with UUID: c40a518f-6e4b-3d4a-b2ea-f39bd2e8b629, bound address: 192.168.0.10
2011-09-22 21:03:00,272 INFO [PluginCompilerThread] Looking for plugins at /home/marcos/pms/serviio-0.6/plugins
2011-09-22 21:03:00,272 INFO [PluginCompilerThread] Started looking for plugins
2011-09-22 21:03:02,060 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-09-22 21:03:02,162 INFO [WebServer] WebServer starting on port 8895
2011-09-22 21:03:02,169 INFO [EventDispatcher] Starting EventDispatcher
2011-09-22 21:03:02,170 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-09-22 21:03:02,170 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-09-22 21:03:02,319 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.0.10, timeout = 0
2011-09-22 21:03:02,321 INFO [RendererSearchSender] Searching for Renderer devices
2011-09-22 21:03:02,322 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-09-22 21:03:02,910 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-09-22 21:03:04,421 INFO [Messages] Loaded console message bundle for locale: en
2011-09-22 21:03:09,286 INFO [Messages] Loaded console message bundle for locale: en
2011-09-22 21:03:09,402 INFO [UpdateChecker] Checking if a new version is available
2011-09-22 21:03:17,543 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-09-22 21:03:18,114 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-09-22 21:03:28,361 INFO [FeedUpdaterThread] Started looking for information about online feeds
2011-09-22 21:03:28,362 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-09-22 21:03:28,369 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-09-22 21:04:29,979 ERROR [ActionNode] Cannot retrieve results of action command: Cannot execute library command for single item: For input string: "73/Inside Job"
org.serviio.upnp.service.contentdirectory.command.CommandExecutionException: Cannot execute library command for single item: For input string: "73/Inside Job"
at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItem(AbstractCommand.java:136)
at org.serviio.upnp.service.contentdirectory.definition.ActionNode.executeRetrieveItemAction(ActionNode.java:175)
at org.serviio.upnp.service.contentdirectory.definition.ActionNode.retrieveDirectoryObject(ActionNode.java:80)
at org.serviio.upnp.service.contentdirectory.ContentDirectory.Browse(ContentDirectory.java:199)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeOperation(ServiceInvoker.java:253)
at org.serviio.upnp.protocol.soap.ServiceInvoker.invokeService(ServiceInvoker.java:93)
at org.serviio.upnp.webserver.ServiceControlRequestHandler.handleRequest(ServiceControlRequestHandler.java:74)
Caused by: java.lang.NumberFormatException: For input string: "73/Inside Job"
at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65)
at java.lang.Integer.parseInt(Integer.java:481)
at java.lang.Integer.parseInt(Integer.java:514)
at org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand.getInitialFromId(ListVideosForInitialCommand.java:58)
at org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand.retrieveItemCount(ListVideosForInitialCommand.java:49)
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.executeCountAction(ContainerNode.java:214)
at org.serviio.upnp.service.contentdirectory.definition.ContainerNode.retrieveContainerItemsCount(ContainerNode.java:114)
at org.serviio.upnp.service.contentdirectory.definition.ActionNode.retrieveContainerItemsCount(ActionNode.java:155)
at org.serviio.upnp.service.contentdirectory.command.ObjectValuesBuilder.instantiateValuesForContainer(ObjectValuesBuilder.java:127)
at org.serviio.upnp.service.contentdirectory.command.AbstractListInitialsCommand.retrieveSingleItem(AbstractListInitialsCommand.java:71)
at org.serviio.upnp.service.contentdirectory.command.AbstractListInitialsCommand.retrieveSingleItem(AbstractListInitialsCommand.java:29)
at org.serviio.upnp.service.contentdirectory.command.AbstractCommand.retrieveItem(AbstractCommand.java:131)
... 15 more
2011-09-22 21:04:30,005 ERROR [ActionNode] Cannot retrieve results of action command: Cannot execute library command for single item: For input string: "73/Inside Job"
... 15 more
2011-09-22 21:15:01,680 ERROR [ActionNode] Cannot retrieve results of action command: Cannot execute library command for single item: For input string: "73/Inside Job"
at sun.reflect.GeneratedMethodAccessor3.invoke(Unknown Source)
... 14 more
2011-09-22 21:15:01,716 ERROR [ActionNode] Cannot retrieve results of action command: Cannot execute library command for single item: For input string: "73/Inside Job"
... 14 more
2011-09-22 21:17:22,937 ERROR [ActionNode] Cannot retrieve results of action command: Cannot execute library command for single item: For input string: "73/Inside Job"
... 14 more
2011-09-22 21:17:22,955 ERROR [ActionNode] Cannot retrieve results of action command: Cannot execute library command for single item: For input string: "73/Inside Job"
... 14 more
xpto09 wrote:Today I downloaded a movie with extension .mkv (burnt by the sun).
Only to test it, I played it and "I COULD SEE SUBTITLES"!
Then I changed green_zone.avi to green_zone.mkv and inside_job.avi to inside_job.mkv.
I could see subtitles.
Now, I wiill test all my movies to make sure that this procedure will always work.
mrcs@natty-P35-DS3:~/Downloads/midia/filmes/Green Zone$ ffmpeg -i GreenZone.avi
FFmpeg version 0.6.2-4:0.6.2-1ubuntu1.1, Copyright (c) 2000-2010 the Libav developers
built on Sep 16 2011 16:57:46 with gcc 4.5.2
configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
WARNING: library configuration mismatch
libavutil configuration: --extra-version=4:0.6.2-1ubuntu2 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-libopenjpeg --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdirac --enable-libfaad --enable-libmp3lame --enable-librtmp --enable-libx264 --enable-libxvid --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
libavcodec configuration: --extra-version=4:0.6.2-1ubuntu2 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-libopenjpeg --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdirac --enable-libfaad --enable-libmp3lame --enable-librtmp --enable-libx264 --enable-libxvid --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
libavformat configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
libavdevice configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
libavfilter configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
libswscale configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
libpostproc configuration: --extra-version=4:0.6.2-1ubuntu1.1 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --disable-stripping --enable-runtime-cpudetect --enable-vaapi --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --shlibdir=/usr/lib/i686/cmov --cpu=i686 --enable-shared --disable-static --disable-ffmpeg --disable-ffplay
libavutil 50.15. 1 / 50.15. 1
libavcodec 52.72. 2 / 52.72. 2
libavformat 52.64. 2 / 52.64. 2
libavdevice 52. 2. 0 / 52. 2. 0
libavfilter 1.19. 0 / 1.19. 0
libswscale 0.11. 0 / 0.11. 0
[mpeg4 @ 0x8d49e20]Invalid and inefficient vfw-avi packed B frames detected
Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65534/2733) -> 23.98 (2997/125)
Input #0, avi, from 'GreenZone.avi':
ISFT : VirtualDubMod 1.5.10.2 (build 2540/release)
Duration: 01:54:46.46, start: 0.000000, bitrate: 852 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 648x256 [PAR 1:1 DAR 81:32], 23.98 tbr, 23.98 tbn, 23.98 tbc
Stream #0.1: Audio: mp3, 44100 Hz, 2 channels, s16, 112 kb/s
At least one output file must be specified<Profile id="8" name="LG TV / player" extendsProfileId="1">
<Detection>
<HttpHeaders>
<friendlyName.dlna.org>LG.*</friendlyName.dlna.org>
</HttpHeaders>
</Detection>
<MediaFormatProfile mime-type="video/mp4" name="">AVI</MediaFormatProfile>
<Video targetContainer="mpegts" targetACodec="mp3">
<Matches container="matroska" aCodec="ac3" />
</Profile>Users browsing this forum: No registered users and 4 guests
