Nasty Artifacts when playing MKV files via PS3
mfractal
Post Sun Sep 25, 2011 1:45 pm
First of all i would like to thank the author for the time and effort he put into this brilliant piece of software!
So... Huge Thanks!!!!
My problem (and i've tried 0.52 and 0.6) is that almost any MKV file i am trying to play on my PS3 has real bad artifacts around moving objects, especially when the scene changes.
Info of a faulty file:
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-mingw32- --pkg-config=pkg-config
[matroska,webm @ 003d8ce0] Estimating duration from bitrate, this may be inaccurate
Input #0, matroska,webm, from 'f:\Media\TV Shows\Modern.Family.S03E01.720p.HDTV.X264-DIMENSION\Modern.Family.S03E01.720p.HDTV.X264-DIMENSION.mkv':
  Duration: 00:21:34.96, start: 0.000000, bitrate: 448 kb/s
    Stream #0.0(eng): Video: h264 (High), yuv420p, 1280x720, PAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
Here's MediaInfo's output
Unique ID                        : 169486093151272331552399057807110523536 (0x7F81D58DD9D8F4B00206043B062B4A90)
Complete name                    : F:\Media\TV Shows\Modern.Family.S03E01.720p.HDTV.X264-DIMENSION\Modern.Family.S03E01.720p.HDTV.X264-DIMENSION.mkv
Format                           : Matroska
Format version                   : Version 2
File size                        : 814 MiB
Duration                         : 21mn 34s
Overall bit rate                 : 5 276 Kbps
Encoded date                     : UTC 2011-09-21 21:16:24
Writing application              : mkvmerge v3.0.0 ('Hang up your Hang-Ups') built on Apr 19 2010 11:58:49
Writing library                  : libebml v0.7.7 + libmatroska v0.8.1
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 8 frames
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 21mn 34s
Bit rate                         : 4 723 Kbps
Width                            : 1 280 pixels
Height                           : 720 pixels
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.214
Stream size                      : 729 MiB (90%)
Writing library                  : x264 core 116 r2074 2641b9e
Encoding settings                : cabac=1 / ref=8 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language                         : English
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : A_AC3
Duration                         : 21mn 34s
Bit rate                         : 448 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 16 bits
Stream size                      : 69.2 MiB (8%)
I am running a 4GB Core i5 Machine with Windows 7 on it.
Anything i could try ?
Post Sun Sep 25, 2011 6:25 pm
Re: Nasty Artifacts when playing MKV files via PS3
this is likely to be down to your network not being able to handle the stream or broken file rather than serviio issue. :)
mfractal
Post Sun Sep 25, 2011 10:24 pm
I doubt it because
a. it happens on almost all the MKV files i have
b. PS3 Media Server can handle the network traffic just fine so i don't see a reason why serviio woudn't + i use a 1GB wired connection between the PS3 the router and the streaming computer
Post Sun Sep 25, 2011 10:26 pm
then when are at broken file, as there is soething in it that FFmpeg doesnt like and taht why u get artifacts.
mfractal
Post Sun Sep 25, 2011 10:36 pm
Ok, so how do i diagnose it ? Is there a way to fix it ?
thanks for the responses btw ;)
Post Sun Sep 25, 2011 11:15 pm
mfractal wrote:Ok, so how do i diagnose it ? Is there a way to fix it ?
reencode them, also check that header compression wasnt used when they were encoded as this causes all sort of problems.
mfractal
Post Mon Sep 26, 2011 12:14 pm
could you elaborate a bit ?
Post Mon Sep 26, 2011 4:00 pm
What is your TV model? do you have some "Motionflow" option activated?
mfractal
Post Mon Sep 26, 2011 6:53 pm
My TV model is Panasonic V20 plasma, but i am using the PS3 as the DLNA receiver.
Post Mon Sep 26, 2011 6:57 pm
mfractal wrote:My TV model is Panasonic V20 plasma, but i am using the PS3 as the DLNA receiver.
Do you have some "Motionflow" or "Motion Smoother" option enabled on your Pana?
And do you confirm that when using PS3 Media Server with the same device : PS3+Panasonic V20, you don't have artifacts?
mfractal
Post Mon Sep 26, 2011 8:02 pm
No, those options aren't enabled
And yes, i confirm that using PS3 Media Server + My Panasonic TV there aren't any artifacts. The problem has to be with the mkv decoder of Serviio.
Post Tue Sep 27, 2011 6:50 am
So this file must be re-muxed into MPEG2 Transport Stream, video and audio codecs must be copied.
Enable detailed logging (see signature) and check the ffmpeg command line used to deliver this stream.
Could you also check the PS3 Media Server logging, probably this file is transcoded into MPEG2 video, so there were no artifacts.
mfractal
Post Tue Sep 27, 2011 11:55 am
Just to confirm, you want me to enable detail logging and play the file right ?
Or am i to remux (not sure how) the file into MPEG2 first and then try to play it ?
Post Tue Sep 27, 2011 4:26 pm
mfractal wrote:Just to confirm, you want me to enable detail logging and play the file right ?
Yes,
-First, just find in log the ffmpeg command line used by serviio to transcode this file (so enable detailed logging and start the file).
-Then try locally the same command line in windows terminal, an add the resulting output file to the library and see if result is the same.
-And that could be fine to compare with the PS3 Media Server encoder command line.
