new 6 verson dont work old one used to
• Page 1 of 2 • 1, 2
hi i have had so much head ach with this. and i kow its the software because i have tryed mezzmo that i dont want to do because i liked serviio. when i updated it it stopped work i changed the windows password thing as well my device just dont sence it up and serviio laggs up major
Re: new 6 verson dont work old one used to
Can you post the full serviio.log file. If it is to big you might have to zip it.
download and install version 0.6.0.1 for windows.
2011-10-04 12:08:20,040 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-10-04 12:08:20,040 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-10-04 12:09:13,942 WARN [TranscodingView$1] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-10-04 12:09:30,789 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-04 12:09:38,097 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-04 12:09:45,390 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-04 12:09:52,598 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-04 12:09:59,906 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-04 12:10:07,198 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-04 12:10:14,500 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-04 12:10:21,799 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-04 12:10:29,100 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
gos on like that and well before version 6.01 it was working fine
Did you download and install 0.6.0.1?
yes that updated version has screwed it up i think 5.2 worked better
did you use your library from 0.5.2? Or did you let serviio regenerate the library.
2011-10-04 19:01:02,851 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-04 19:01:10,151 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-04 19:01:17,451 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-04 19:01:24,751 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-04 19:01:32,051 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-04 19:01:39,351 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-04 19:01:46,651 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-04 19:01:52,661 WARN [RepositoryView$10] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-10-04 19:01:53,951 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-04 19:02:01,251 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-04 19:02:02,151 WARN [RepositoryView$8] Cannot connect to server: Communication Error (1001) - Connection refused: connect
ive re added the libery now thats what im getting it works when you have no files added to the list
From 0.5.2 to 0.6.0.1 big changes were made to the library so you need to completely remove the library folder and let serviio rebuild it as your old library is missing information that serviio requires to work that is why its failing.
tinytitan wrote:2011-10-04 19:01:02,851 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
Looks like a communication problem between the Serviio's server and console.
It may append if new console try to connect to an old server.
Or if the service is not launched.
Try to remove and recreate Windows Serviio service.
Serviio WebUI console developer : New Homepage | Support | Project | Issues
Samsung UA32C6600 | WinXP / Ubuntu 11.10 | Samsung Galaxy S | Freebox v6
nope still cant get in to the libery i even made new folders put the films and stuff in
yes i have installed and uninstalled and reinstalled its the software gone wrong
I would uninstall it and delete the serviio directory and reinstall it. Unless you delete your library folder, the library is not deleted.
yea deleted reinstalled meany times and soon as i add the folders to the libery it comes with this
2011-10-07 01:15:15,432 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-10-07 01:16:26,325 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-07 01:16:26,585 WARN [RepositoryView$8] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-10-07 01:16:33,625 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-07 01:16:39,907 WARN [RepositoryView$8] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-10-07 01:16:40,919 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-07 01:16:48,221 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-07 01:16:55,521 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-07 01:17:02,821 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-07 01:17:03,771 WARN [RepositoryView$8] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-10-07 01:17:10,121 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-07 01:17:17,421 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-07 01:17:23,111 WARN [RepositoryView$8] Cannot connect to server: Communication Error (1001) - Connection refused: connect
2011-10-07 01:17:24,721 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-07 01:17:32,021 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-07 01:17:39,321 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-07 01:17:46,621 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-07 01:17:53,921 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-07 01:18:01,221 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
2011-10-07 01:18:08,525 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Communication Error (1001) - Connection refused: connect
what version of java do you have?
DONT ADD THE OLD LIBRARY, delete everything and start from scratch.
also make sure that if you are using teh remote console that versions MATCH (0.6 server must be used with 0.6 console)
what delete all my files on my harddrive i have spend years downloading? and yea i dl the newest version from this site what i am really stuck
tinytitan wrote:what delete all my files on my harddrive i have spend years downloading?
Do not delete your files !!
but you could delete the serviio library database "../serviio/library/db" when you change/update the serviio version.
tyes did that i uninstalled and reinstalled servio the new one like 8 times
