files
• Page 1 of 1
Re: files
is transcoding enabled and have you set the right profile is alll i can suggest on the info i have if you can provide info on your setup and the file you are trying to play that would help alot
Re: files
casey01 wrote:Love serviio but would like to know why not all files work , MKV for instance
A ton more information on your setup and devices is required before we can even attempt to help you.
Re: files
I seem to have this issue too.
Running Serviio on FreeNAS ( free bsd UNIX ).
Sony Bravia TV.
Using handbrake to rip the movies. Would a different tool work better? Suggestions?
What other info is needed?
I do see actor, director and producer info in the Serviio menu on the TV so part of it works.
Sony Bravia TV.
Re: files
Re: files
Trying to find out why I can't see Movie titles. I do see actors, genre, etc.
Serviio is running from FreeNAS ( free BSD UNIX )
Serviio Console is running on a Win XP box - this will be turned off most of the time, hope that is ok.
TV is a Sony Bravia
After running the ffmpeg exe I see this:
The last line is most likely part of my problem - how do I fix it?
dc5700:~# /usr/local/bin/ffmpeg ffmpeg -i /mnt/ZFS_Pool/Movies
FFmpeg version 0.6.1, Copyright (c) 2000-2010 the FFmpeg developers
built on Jan 31 2011 16:15:05 with gcc 4.2.1 20070719 [FreeBSD]
configuration: --prefix=/usr/local --mandir=/usr/local/man --enable-shared --enable-gpl --enable-postproc --enable-avfilter --enable-avfilter-lavf --enable-pthreads --enable-x11grab --enable-memalign-hack --cc=cc --extra-cflags=-msse -I/usr/local/include/vorbis -I/usr/local/include --extra-ldflags=-L/usr/local/lib --extra-libs=-pthread --disable-debug --enable-runtime-cpudetect --disable-indev=alsa --disable-outdev=alsa --disable-libopencore-amrnb --disable-libopencore-amrwb --disable-libdirac --disable-libfaac --enable-libfaad --enable-libfaadbin --disable-libgsm --disable-libmp3lame --disable-libopenjpeg --enable-libschroedinger --disable-ffplay --disable-libspeex --enable-libtheora --disable-vdpau --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxvid
libavutil 50.15. 1 / 50.15. 1
libavcodec 52.72. 2 / 52.72. 2
libavformat 52.64. 2 / 52.64. 2
libavdevice 52. 2. 0 / 52. 2. 0
libavfilter 1.19. 0 / 1.19. 0
libswscale 0.11. 0 / 0.11. 0
Unable to find a suitable output format for 'ffmpeg'
any help is most welcome! Thanks!!
TV is a Sony Bravia
Re: files
First your FFmpeg is quite old.
Second, you're pointing to a folder (after the -i parameter), not a file
Petr
Help translate Serviio
• Page 1 of 1
