MetaData Rescanning
First, thanks for 0.6.0.1 the new features are excellent.
Now the log file log "WARN" for meta data lookups which fail, I have been able to identify (with ease) the 134 films that I had which the Online lookup failed on. Most of the Online lookup failures were just timeouts from the website so can Serviio be configured to...
a) Rescan automatically any move which dont have Metadata associated with it.
b) Have a method to just scan meta data for films without any.
You have a Rescan video metadata button but the problem with this is it rescans everything and any film that already has metadata but then gets a timeout while rescanning will loose it's metadata. This means that I fix the ones I detected earlier but loose metadata for ones I already had metadata for. If this could be changed so it only overwrites the metadata on a successful lookup...
Serviio is a fantastic product and the best I have used. Looking forward to 0.6.1
Mike
