Samsung LE37B653T5W. Do not open media library
munia
Post Fri Oct 28, 2011 10:55 am
Samsung B class TV, I cant open media library, then open see this 'request cannot be completed. Media play will return to the main screen" and back to main window. I am using system Windows 7, DLNA
Samsung C class Tv - no problem.
Any advice, please
munia
Post Mon Oct 31, 2011 9:26 am
Re: Samsung LE37B653T5W. Do not open media library
any advice?
maybe W7 problem, but TV Samsung C working good.
I do not want back to Samsung PC Share..
Post Mon Oct 31, 2011 2:32 pm
is your B series samsung's firmware up-to-date?
munia
Post Mon Oct 31, 2011 2:45 pm
Yes I did.
Now firmware last version T-CHL7DEUC-3001.1
Post Mon Oct 31, 2011 4:42 pm
enable detailed log and post it here (try to browse on the B series)
munia
Post Wed Nov 02, 2011 9:23 am
I tried make file smaller, but can't and cut in middle.
Did it help?
2011-11-02 11:11:38,178 INFO  [RestletServer] Starting Restlet server exposed on port 23423
2011-11-02 11:11:38,223 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-11-02 11:11:38,229 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2011-11-02 11:11:38,972 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2011-11-02 11:11:38,972 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2011-11-02 11:11:38,973 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2011-11-02 11:11:38,973 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2011-11-02 11:11:38,974 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2011-11-02 11:11:38,975 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2011-11-02 11:11:38,975 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2011-11-02 11:11:38,976 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2011-11-02 11:11:38,976 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2011-11-02 11:11:39,344 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2011-11-02 11:11:39,380 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2011-11-02 11:11:39,829 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-11-02 11:11:39,830 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2011-11-02 11:11:40,066 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-11-02 11:11:40,067 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2011-11-02 11:11:40,195 INFO  [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-11-02 11:11:40,197 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2011-11-02 11:11:40,317 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-11-02 11:11:40,319 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2011-11-02 11:11:40,423 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-11-02 11:11:40,424 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2011-11-02 11:11:40,537 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-11-02 11:11:40,539 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2011-11-02 11:11:40,783 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-11-02 11:11:40,784 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2011-11-02 11:11:40,823 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2011-11-02 11:11:40,825 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 9
2011-11-02 11:11:41,121 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-11-02 11:11:41,123 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2011-11-02 11:11:41,614 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-11-02 11:11:41,616 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 12
2011-11-02 11:11:41,808 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-11-02 11:11:41,810 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2011-11-02 11:11:41,995 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2011-11-02 11:11:41,997 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2011-11-02 11:11:42,046 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2011-11-02 11:11:42,048 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2011-11-02 11:11:42,073 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2011-11-02 11:11:42,075 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2011-11-02 11:11:42,157 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2011-11-02 11:11:42,159 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2011-11-02 11:11:42,200 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2011-11-02 11:11:42,202 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2011-11-02 11:11:42,293 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2011-11-02 11:11:42,294 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 19
2011-11-02 11:11:42,610 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV 2011' (id=19)
2011-11-02 11:11:42,612 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2011-11-02 11:11:42,891 INFO  [ProfilesDefinitionParser] Added profile 'Sony SMP-N100' (id=20)
2011-11-02 11:11:42,907 INFO  [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-11-02 11:11:42,911 INFO  [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-11-02 11:11:42,914 INFO  [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-11-02 11:11:42,914 INFO  [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-11-02 11:11:42,915 INFO  [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-11-02 11:11:42,915 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-11-02 11:11:42,915 INFO  [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1320225102915, LastAccessTime = 1320225102915, getTimeToLiveSeconds() = -1, createTime = 1320225102915 ]
2011-11-02 11:11:42,935 INFO  [LRUMemoryCache] initialized LRUMemoryCache for thumbnails
2011-11-02 11:11:42,935 INFO  [CompositeCache] Constructed cache with name [thumbnails] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-11-02 11:11:42,936 INFO  [LRUMemoryCache] initialized LRUMemoryCache for online_feeds
2011-11-02 11:11:42,936 INFO  [CompositeCache] Constructed cache with name [online_feeds] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-11-02 11:11:42,936 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-11-02 11:11:42,936 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-11-02 11:11:42,936 INFO  [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-11-02 11:11:42,936 INFO  [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-11-02 11:11:42,936 INFO  [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-11-02 11:11:42,936 INFO  [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-11-02 11:11:42,936 INFO  [CompositeCacheConfigurator] Parsed regions [thumbnails, online_feeds, local_default, local_resetafterplay]
2011-11-02 11:11:42,937 INFO  [CompositeCacheConfigurator] Finished configuration in 23 ms.
2011-11-02 11:11:42,947 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2011-11-02 11:11:44,319 INFO  [WebServer] Socket buffer set to 65535 bytes
2011-11-02 11:11:44,319 INFO  [Device] Created UPnP Device with UUID: e0c9b1c8-f3a6-3a60-a033-10a35435509f, bound address: 192.168.216.102
2011-11-02 11:11:44,337 INFO  [PluginCompilerThread] Looking for plugins at c:\Program Files (x86)\Serviio\bin\..\plugins
2011-11-02 11:11:44,341 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path c:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe
2011-11-02 11:11:44,343 DEBUG [ProcessExecutor] Starting c:\Program Files (x86)\Serviio\bin\\..\lib/ffmpeg.exe
2011-11-02 11:11:44,350 INFO  [PluginCompilerThread] Started looking for plugins
2011-11-02 11:11:44,391 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-11-02 11:11:44,392 DEBUG [AbstractTranscodingDeliveryEngine] Deleting temporary transcoded files from: D:\Laikinas\Serviio
2011-11-02 11:11:44,418 INFO  [WebServer] WebServer starting on port 8895
2011-11-02 11:11:44,422 DEBUG [DiscoveryManager] UPNP device e0c9b1c8-f3a6-3a60-a033-10a35435509f (192.168.216.102) is available
2011-11-02 11:11:44,427 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2011-11-02 11:11:44,428 INFO  [RendererSearchSender] Searching for Renderer devices
2011-11-02 11:11:44,432 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-11-02 11:11:44,432 INFO  [EventDispatcher] Starting EventDispatcher
2011-11-02 11:11:44,433 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-11-02 11:11:44,478 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (NVIDIA nForce Networking Controller #2) and address 192.168.216.102, timeout = 0
2011-11-02 11:11:45,780 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth4 (NVIDIA nForce Networking Controller #2) and address 192.168.216.102, timeout = 0
2011-11-02 11:11:45,792 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device e0c9b1c8-f3a6-3a60-a033-10a35435509f
2011-11-02 11:11:46,207 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth4 (NVIDIA nForce Networking Controller #2) and address 192.168.216.102, timeout = 0
2011-11-02 11:11:46,207 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2011-11-02 11:11:46,208 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.216.102:54066
2011-11-02 11:11:46,210 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.216.102:54066
2011-11-02 11:11:46,425 DEBUG [WebServer] Incoming connection from /192.168.216.101:2318
2011-11-02 11:11:46,432 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device e0c9b1c8-f3a6-3a60-a033-10a35435509f from 192.168.216.101 (headers = [HOST: 192.168.216.102:8895,USER-AGENT: SamsungWiselinkPro/1.0,ACCEPT-LANGUAGE: en-us])
2011-11-02 11:11:46,432 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.216.101
2011-11-02 11:11:46,457 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.216.102:8895,USER-AGENT: SamsungWiselinkPro/1.0,ACCEPT-LANGUAGE: en-us]
2011-11-02 11:11:46,458 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.216.101
2011-11-02 11:11:46,495 DEBUG [WebServer] Incoming connection from /192.168.216.101:2319
2011-11-02 11:11:46,496 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device e0c9b1c8-f3a6-3a60-a033-10a35435509f from 192.168.216.101 (headers = [HOST: 192.168.216.102:8895,USER-AGENT: SamsungWiselinkPro/1.0,ACCEPT-LANGUAGE: en-us])
2011-11-02 11:11:46,497 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.216.101
2011-11-02 11:11:46,498 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.216.102:8895,USER-AGENT: SamsungWiselinkPro/1.0,ACCEPT-LANGUAGE: en-us]
2011-11-02 11:11:46,499 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.216.101
2011-11-02 11:11:46,601 DEBUG [WebServer] Incoming connection from /192.168.216.101:2320
2011-11-02 11:11:46,601 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device e0c9b1c8-f3a6-3a60-a033-10a35435509f from 192.168.216.101 (headers = [HOST: 192.168.216.102:8895,USER-AGENT: SamsungWiselinkPro/1.0,ACCEPT-LANGUAGE: en-us])
2011-11-02 11:11:46,602 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.216.101
2011-11-02 11:11:46,602 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.216.102:8895,USER-AGENT: SamsungWiselinkPro/1.0,ACCEPT-LANGUAGE: en-us]
2011-11-02 11:11:46,603 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.216.101
2011-11-02 11:11:46,644 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV (B-series)'
2011-11-02 11:11:46,646 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV (B-series)'
2011-11-02 11:11:46,660 DEBUG [RendererSearchSender] Received search response: location: http://192.168.216.101:52235/dmr/SamsungMRDesc.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-11-02 11:11:46,661 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 59dc8344-8700-6d98-75c1-00b108b13874 from address /192.168.216.101:1028
2011-11-02 11:11:46,665 DEBUG [RendererSearchSender] Received search response: location: http://192.168.216.101:52235/dmr/SamsungMRDesc.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-11-02 11:11:46,665 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 59dc8344-8700-6d98-75c1-00b108b13874 from address /192.168.216.101:1028
2011-11-02 11:11:46,672 DEBUG [RendererManager] Adding renderer Renderer [uuid=59dc8344-8700-6d98-75c1-00b108b13874, ipAddress=192.168.216.101, name=Samsung DTV DMR, profileId=2, manuallyAdded=false] to list of active renderers
2011-11-02 11:11:47,593 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-11-02 11:11:48,660 DEBUG [RendererSearchSender] Received search response: location: http://192.168.216.101:52235/dmr/SamsungMRDesc.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2011-11-02 11:11:48,661 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 59dc8344-8700-6d98-75c1-00b108b13874 from address /192.168.216.101:1028
2011-11-02 11:11:52,208 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2011-11-02 11:11:53,048 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.216.102:51757
2011-11-02 11:11:56,049 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.216.102:51757
2011-11-02 11:11:58,957 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth4 (NVIDIA nForce Networking Controller #2) and address 192.168.216.102, timeout = 0
2011-11-02 11:11:58,958 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device e0c9b1c8-f3a6-3a60-a033-10a35435509f
2011-11-02 11:11:59,050 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.216.102:51757
2011-11-02 11:12:00,759 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:10
2011-11-02 11:12:02,079 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.216.102:51757
2011-11-02 11:12:04,773 DEBUG [WebServer] Incoming connection from /192.168.216.101:3907
2011-11-02 11:12:04,778 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.216.101:
2011-11-02 11:12:04,778 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.216.101
2011-11-02 11:12:04,875 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2011-11-02 11:12:04,885 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-11-02 11:12:04,891 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=0, titleKey=pc5dczc_media_library, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = null
2011-11-02 11:12:04,907 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A, titleKey=audio, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:04,914 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_A, titleKey=artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:04,920 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-11-02 11:12:04,925 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2011-11-02 11:12:04,932 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2011-11-02 11:12:04,937 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-11-02 11:12:04,943 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=AL_A, titleKey=album_artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:04,957 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-11-02 11:12:04,968 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2011-11-02 11:12:04,994 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForAlbumArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2011-11-02 11:12:04,999 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,004 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:05,009 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=local_default
2011-11-02 11:12:05,019 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:05,024 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioGenresByNameCommand, containerClass=MUSIC_GENRE, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,031 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForGenreCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,038 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_C, titleKey=composers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:05,044 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,050 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposersForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=COM, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,055 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForComposerCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,060 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForComposerAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,064 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:05,069 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,073 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForInitialCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,077 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_R, titleKey=random, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2011-11-02 11:12:05,082 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListRandomSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=no_cache
2011-11-02 11:12:05,086 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_OF, titleKey=online_feeds, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2011-11-02 11:12:05,091 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioOnlineFeedsByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=REPO, recursive=false, cacheRegion=no_cache
2011-11-02 11:12:05,095 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForOnlineFeedCommand, containerClass=null, itemClass=AUDIO_ITEM, idPrefix=F, recursive=false, cacheRegion=no_cache
2011-11-02 11:12:05,100 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_S, titleKey=All songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2011-11-02 11:12:05,105 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllSongsCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,110 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_AS, titleKey=Artist Songs, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2011-11-02 11:12:05,115 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsByNameCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART_S, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,119 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,124 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_ALB, titleKey=All albums, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2011-11-02 11:12:05,129 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAllAlbumsCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,133 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,138 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I, titleKey=image, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:05,143 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_A, titleKey=albums, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:05,150 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListFlatImageFoldersByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=ALB, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,153 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.216.102:51757
2011-11-02 11:12:05,156 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForFolderCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,161 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:05,167 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=PHOTO, idPrefix=FOL, recursive=true, cacheRegion=local_default
2011-11-02 11:12:05,172 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_Y, titleKey=year, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:05,176 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,181 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,186 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_T, titleKey=month, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:05,191 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationYearsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=YEAR, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,196 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesCreationMonthsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=MON, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,201 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForCreationMonthAndYearCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,206 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_OF, titleKey=online_feeds, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2011-11-02 11:12:05,210 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImageOnlineFeedsByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=REPO, recursive=false, cacheRegion=no_cache
2011-11-02 11:12:05,215 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListImagesForOnlineFeedCommand, containerClass=null, itemClass=PHOTO, idPrefix=F, recursive=false, cacheRegion=no_cache
2011-11-02 11:12:05,220 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=I_AI, titleKey=All images, class=CONTAINER, cacheRegion=local_default, browsable = false, editable = null
2011-11-02 11:12:05,225 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.image.ListAllImagesCommand, containerClass=null, itemClass=PHOTO, idPrefix=I, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,229 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V, titleKey=video, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:05,235 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_T, titleKey=titles, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:05,242 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,250 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForInitialCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,255 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_M, titleKey=movies, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:05,261 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListMovieVideosByNameCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,266 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_S, titleKey=series, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:05,271 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeriesByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SER, recursive=false, cacheRegion=local_resetafterplay
2011-11-02 11:12:05,276 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListSeasonsForSeriesCommand, containerClass=CONTAINER, itemClass=null, idPrefix=SSN, recursive=false, cacheRegion=local_resetafterplay
2011-11-02 11:12:05,282 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListEpisodesForSeriesSeasonCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2011-11-02 11:12:05,287 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:05,293 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=VIDEO_ITEM, idPrefix=FOL, recursive=true, cacheRegion=local_default
2011-11-02 11:12:05,298 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LV, titleKey=last_viewed, class=CONTAINER, cacheRegion=local_resetafterplay, browsable = null, editable = true
2011-11-02 11:12:05,302 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastViewedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_resetafterplay
2011-11-02 11:12:05,307 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_LA, titleKey=last_added, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:05,312 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListLastAddedVideosCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,317 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:05,322 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoGenresByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,328 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForGenreCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,333 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_A, titleKey=actors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:05,338 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,343 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListActorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,348 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForActorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,353 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_D, titleKey=directors, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:05,358 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,363 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListDirectorsForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,369 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForDirectorCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,374 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_P, titleKey=producers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2011-11-02 11:12:05,380 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,385 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListProducersForInitialCommand, containerClass=PERSON, itemClass=null, idPrefix=P, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,391 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForProducerCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=V, recursive=false, cacheRegion=local_default
2011-11-02 11:12:05,396 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=V_OF, titleKey=online_feeds, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2011-11-02 11:12:05,402 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideoOnlineFeedsByNameCommand, containerClass=CONTAINER, itemClass=null, idPrefix=REPO, recursive=false, cacheRegion=no_cache
2011-11-02 11:12:05,407 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.video.ListVideosForOnlineFeedCommand, containerClass=null, itemClass=VIDEO_ITEM, idPrefix=F, recursive=false, cacheRegion=no_cache
2011-11-02 11:12:05,422 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-11-02 11:12:05,428 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for AUDIO
2011-11-02 11:12:05,455 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-11-02 11:12:05,470 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-11-02 11:12:05,475 DEBUG [WebServer] Incoming connection from /192.168.216.101:3908
2011-11-02 11:12:05,476 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.216.101:
2011-11-02 11:12:05,476 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.216.101
2011-11-02 11:12:05,480 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 20, sortCriteria =
2011-11-02 11:12:05,483 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for AUDIO
2011-11-02 11:12:05,490 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for IMAGE
2011-11-02 11:12:05,496 DEBUG [RepositoryDAOImpl] Retrieving list of Repositories for VIDEO (from=0, count=18)
2011-11-02 11:12:05,532 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root'
2011-11-02 11:12:05,655 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO
2011-11-02 11:12:05,658 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-11-02 11:12:05,662 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-11-02 11:12:05,795 DEBUG [WebServer] Incoming connection from /192.168.216.101:3909
2011-11-02 11:12:05,797 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.216.101:
2011-11-02 11:12:05,797 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.216.101
2011-11-02 11:12:05,810 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 0, count = 1, sortCriteria =
2011-11-02 11:12:05,818 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for AUDIO
2011-11-02 11:12:05,833 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-11-02 11:12:05,838 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-11-02 11:12:05,846 DEBUG [WebServer] Incoming connection from /192.168.216.101:3910
2011-11-02 11:12:05,847 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.216.101:
2011-11-02 11:12:05,847 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.216.101
2011-11-02 11:12:05,853 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 1, count = 1, sortCriteria =
2011-11-02 11:12:05,856 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for IMAGE
2011-11-02 11:12:05,861 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-11-02 11:12:05,866 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-11-02 11:12:05,877 DEBUG [WebServer] Incoming connection from /192.168.216.101:3911
2011-11-02 11:12:05,878 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.216.101:
2011-11-02 11:12:05,878 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.216.101
2011-11-02 11:12:05,884 DEBUG [ContentDirectory] Browse() called for renderer Samsung DTV DMR (profile 2) with parameters: objectID = 0, browseFlag = BrowseDirectChildren, filter = @id,@parentID,@restricted,dc:title,upnp:class,res,dc:date,@childCount,sec:CaptionInfo,sec:CaptionInfoEx,res@resolution,res@size,upnp:genre,dc:date,upnp:album,res@duration,upnp:albumArtURI,res@bitrate,dc:creator, startIndex = 2, count = 1, sortCriteria =
2011-11-02 11:12:05,892 DEBUG [RepositoryDAOImpl] Retrieving list of Repositories for VIDEO (from=2, count=1)
2011-11-02 11:12:05,909 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO
2011-11-02 11:12:05,912 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-11-02 11:12:05,917 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2011-11-02 11:12:08,154 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.216.102:51757
2011-11-02 11:12:12,128 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth4 (NVIDIA nForce Networking Controller #2) and address 192.168.216.102, timeout = 0
2011-11-02 11:12:12,128 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device e0c9b1c8-f3a6-3a60-a033-10a35435509f
2011-11-02 11:12:12,215 INFO  [FeedUpdaterThread] Started looking for information about online feeds
2011-11-02 11:12:12,222 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2011-11-02 11:12:12,248 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-11-02 11:12:12,248 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-11-02 11:12:12,258 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-11-02 11:12:12,258 DEBUG [RepositoryDAOImpl] Reading all Repositories
2011-11-02 11:12:12,262 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: D:\Downloads\HD
2011-11-02 11:12:12,262 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Downloads\HD
2011-11-02 11:12:12,262 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Downloads\HD\BBC.Planeta.ludey.(8.seriy.iz.8).2011.x264.BDRip
2011-11-02 11:12:12,264 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 2)
2011-11-02 11:12:12,284 DEBUG [LibraryAdditionsCheckerThread] Found file 'BBC.Planeta.ludey.(1.iz.8).Okeany.2011.x264.BDRip.mkv', checking if it's already in the Library
2011-11-02 11:12:12,284 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item BBC.Planeta.ludey.(1.iz.8).Okeany.2011.x264.BDRip.mkv
2011-11-02 11:12:12,343 DEBUG [MediaItemDAOImpl] Media item BBC.Planeta.ludey.(1.iz.8).Okeany.2011.x264.BDRip.mkv already exists in DB
2011-11-02 11:12:12,362 DEBUG [MediaItemDAOImpl] Getting file of media item 223
2011-11-02 11:12:12,363 DEBUG [LibraryAdditionsCheckerThread] Found file 'BBC.Planeta.ludey.(2.iz.8).Pustyni.2011.x264.BDRip.mkv', checking if it's already in the Library
2011-11-02 11:12:12,363 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item BBC.Planeta.ludey.(2.iz.8).Pustyni.2011.x264.BDRip.mkv
2011-11-02 11:12:12,366 DEBUG [MediaItemDAOImpl] Media item BBC.Planeta.ludey.(2.iz.8).Pustyni.2011.x264.BDRip.mkv already exists in DB
2011-11-02 11:12:12,386 DEBUG [LibraryAdditionsCheckerThread] Found file 'BBC.Planeta.ludey.(3.iz.8).Arktika.2011.x264.BDRip.mkv', checking if it's already in the Library
2011-11-02 11:12:12,386 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item BBC.Planeta.ludey.(3.iz.8).Arktika.2011.x264.BDRip.mkv
2011-11-02 11:12:12,393 DEBUG [MediaItemDAOImpl] Media item BBC.Planeta.ludey.(3.iz.8).Arktika.2011.x264.BDRip.mkv already exists in DB
2011-11-02 11:12:12,394 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2011-11-02 11:12:12,407 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2011-11-02 11:12:12,408 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type IMAGE
2011-11-02 11:12:12,410 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 223) and extractor EMBEDDED
2011-11-02 11:12:12,429 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 223) and extractor COVER_IMAGE_IN_FOLDER
2011-11-02 11:12:12,431 DEBUG [LibraryAdditionsCheckerThread] Found file 'BBC.Planeta.ludey.(4.iz.8).Dzhungli.2011.x264.BDRip.mkv', checking if it's already in the Library
2011-11-02 11:12:12,431 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item BBC.Planeta.ludey.(4.iz.8).Dzhungli.2011.x264.BDRip.mkv
2011-11-02 11:12:12,433 DEBUG [MediaItemDAOImpl] Media item BBC.Planeta.ludey.(4.iz.8).Dzhungli.2011.x264.BDRip.mkv already exists in DB
2011-11-02 11:12:12,453 DEBUG [LibraryAdditionsCheckerThread] Found file 'BBC.Planeta.ludey.(5.iz.8).Gori.2011.x264.BDRip.mkv', checking if it's already in the Library
2011-11-02 11:12:12,453 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item BBC.Planeta.ludey.(5.iz.8).Gori.2011.x264.BDRip.mkv
2011-11-02 11:12:12,454 DEBUG [MediaItemDAOImpl] Media item BBC.Planeta.ludey.(5.iz.8).Gori.2011.x264.BDRip.mkv already exists in DB
2011-11-02 11:12:12,474 DEBUG [LibraryAdditionsCheckerThread] Found file 'BBC.Planeta.ludey.(6.iz.8).Savanny.(Stepi).2011.x264.BDRip.mkv', checking if it's already in the Library
2011-11-02 11:12:12,474 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item BBC.Planeta.ludey.(6.iz.8).Savanny.(Stepi).2011.x264.BDRip.mkv
2011-11-02 11:12:12,475 DEBUG [MediaItemDAOImpl] Media item BBC.Planeta.ludey.(6.iz.8).Savanny.(Stepi).2011.x264.BDRip.mkv already exists in DB
2011-11-02 11:12:12,479 DEBUG [MediaItemDAOImpl] Getting file of media item 468
2011-11-02 11:12:12,480 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 468) and extractor EMBEDDED
2011-11-02 11:12:12,481 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 468) and extractor COVER_IMAGE_IN_FOLDER
2011-11-02 11:12:12,495 DEBUG [LibraryAdditionsCheckerThread] Found file 'BBC.Planeta.ludey.(7.iz.8).Reki.2011.x264.BDRip.mkv', checking if it's already in the Library
2011-11-02 11:12:12,495 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item BBC.Planeta.ludey.(7.iz.8).Reki.2011.x264.BDRip.mkv
2011-11-02 11:12:12,496 DEBUG [MediaItemDAOImpl] Media item BBC.Planeta.ludey.(7.iz.8).Reki.2011.x264.BDRip.mkv already exists in DB
2011-11-02 11:12:12,516 DEBUG [LibraryAdditionsCheckerThread] Found file 'BBC.Planeta.ludey.(8.iz.8).Goroda.2011.x264.BDRip.mkv', checking if it's already in the Library
2011-11-02 11:12:12,516 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item BBC.Planeta.ludey.(8.iz.8).Goroda.2011.x264.BDRip.mkv
2011-11-02 11:12:12,517 DEBUG [MediaItemDAOImpl] Media item BBC.Planeta.ludey.(8.iz.8).Goroda.2011.x264.BDRip.mkv already exists in DB
2011-11-02 11:12:12,517 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Downloads\HD\Sci-Fi.Movie.Pack.1080p.BluRay.x264
2011-11-02 11:12:12,517 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Downloads\HD\Sci-Fi.Movie.Pack.1080p.BluRay.x264\District.9.1080p.BluRay.x264-METiS
"-------------------" cut
ding a Folder (id = 130)
2011-11-02 11:12:14,039 DEBUG [FolderDAOImpl] Getting number of media items in folder 130
2011-11-02 11:12:14,040 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder 130
2011-11-02 11:12:14,054 DEBUG [FolderDAOImpl] Deleting a Folder (id = 130)
2011-11-02 11:12:14,076 DEBUG [GenreDAOImpl] Getting number of media items for genre 8
2011-11-02 11:12:14,078 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 2)
2011-11-02 11:12:14,113 DEBUG [RepositoryDAOImpl] Marking Repository 2 as scanned with current timestamp
2011-11-02 11:12:17,219 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2011-11-02 11:12:17,221 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2011-11-02 11:12:17,222 DEBUG [LocalContentCacheDecorator] Cleared cache (local_default)
Post Wed Nov 02, 2011 12:19 pm
did you change the IP addresses? I can see incoming requests from .101 (with Samsung B profile). Otherwise it looks ok. Can you try removing <DeviceDescription> element from the Samsung B (and C/D if it's there) profiles?
munia
Post Wed Nov 02, 2011 5:20 pm
I did not change Ip addresses.
What exactly I must delete from B profile?
 </Detection>
        <DeviceDescription>
           <ExtraElements>
              &lt;sec:ProductCap&gt;smi,getMediaInfo.sec,getCaptionInfo.sec&lt;/sec:ProductCap&gt;
            &lt;sec:X_ProductCap&gt;smi,getMediaInfo.sec,getCaptionInfo.sec&lt;/sec:X_ProductCap&gt;
           </ExtraElements>
        </DeviceDescription>
        <MediaFormatProfiles>
            <MediaFormatProfile mime-type="video/x-mkv">MATROSKA</MediaFormatProfile>
            <MediaFormatProfile mime-type="video/x-msvideo" name="">AVI</MediaFormatProfile>
        </MediaFormatProfiles>
Post Wed Nov 02, 2011 5:42 pm
<DeviceDescription>
           <ExtraElements>
           </ExtraElements>
munia
Post Wed Nov 02, 2011 5:50 pm
I deleted <DeviceDescription>, server started, but Samsung B did not open media library.
Samsung C - ok.
Post Thu Nov 03, 2011 1:07 pm
Can you confirm what are the IP addresses of your TVs?
munia
Post Thu Nov 03, 2011 2:49 pm
I did not change adress: 192.168.216.103
Post Thu Nov 03, 2011 3:08 pm
I do not see that IP address in the serviio.log file. Is the TV IP address static or is it dynamic?
munia
Post Fri Nov 04, 2011 7:25 pm
I am not clever on such things, but same ip address is on Samsung PC Share:
Samsung B - 192.168.216.103
Users browsing this forum: Google [Bot] and 6 guests
