Unable to decode AAC audio on Samsung B
stephendhill
Post Mon Oct 31, 2011 6:38 pm
Samsung B650 TV (using B series profile) reports audio failure (although happily plays video) when attempting to play MPEG file.
Doesn't look like serviio attempts to transcode it for some reason (have transcoding enabled).
My PS3 is able to play it no problem using Serviio.
Output from ffmpeg as follows:
Seems stream 1 codec frame rate differs from container frame rate: 47.95 (5000000/104271) -> 23.98 (24000/1001)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/shared_data/video/test.mp4':
    major_brand     : isom
    minor_version   : 1
    compatible_brands: isomavc1
    creation_time   : 2011-05-06 10:08:34
  Duration: 00:43:47.54, start: 0.000000, bitrate: 511 kb/s
    Stream #0.0(und): Audio: aac, 44100 Hz, stereo, s16, 56 kb/s
    Stream #0.1(und): Video: h264 (High), yuv420p, 704x400 [PAR 1:1 DAR 44:25], 451 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
      creation_time   : 2011-05-06 10:08:35
Avid Serviio user
Pure Flow One | Samsung LE40B650 | Samsung UE40F6320 | Sony PS3 | Ubuntu 14.04
Post Tue Nov 01, 2011 11:31 am
Re: Unable to decode AAC audio on Samsung B
AAC is normally playable by the TV so no need to transcode. You might try to remux the file to have the video stream on the first track (search the forum on how to do that, there are some tools)
drago17
Post Tue Nov 01, 2011 12:35 pm
if i play a video with AAC audio the tv show "audio codec not supported".
with DTS and AC3 works great (without transcoding).
is there a solution to see an AAC un a samsung c6000?
thanks
Post Wed Nov 02, 2011 1:16 pm
56 kb/s is a very low bitrate for aac, no ?
Do you have another movies with AAC audio track ?
