No audio, video is fine
faspina
Post Sun Jul 25, 2010 3:39 am
Trying to stream to a DIRECTV HD DVR. MP3 work great, two video types both come over as video but no audio. Running standard version of software on the DVR not a CE version . Any ideas where to start.
Post Sun Jul 25, 2010 10:33 am
Re: No audio, video is fine
I presume you selected DirecTV profile?
faspina
Post Sun Jul 25, 2010 1:46 pm
Yep. One thing to not. No sound card on the PC running Serviio, it is running WHS as its OS.
faspina
Post Sun Jul 25, 2010 2:08 pm
I got it. Changed the audio codec from Ac3 to MP3 on the directTV profile. Worked like a charm. This is great.
iys
Post Sat Aug 07, 2010 2:02 am
I have 2 DirectTV HD boxes and neither will play audio.
One is an H21-200
And the other is an H23-600.
In Device Spy, both show
Device URN: urn:schemas-upnp-org:device:MediaRenderer:1
Model Name: MediaRenderer
Model Number: 1.0
As for SinkProtocolInfo, both show "http-get:*:image/jpeg:*,http-get:*:image/png:*,http-get:*:audio/L16:*,http-get:*:video/mpeg:*"
I've tried targetACodec values of the default "ac3", "mp3" and "pcm_s16le" (based on SinkProtocolInfo reporting L16). None of these options work. Any suggestions?
iys
Post Sun Sep 26, 2010 11:39 pm
Still fighting with this...
iys
Post Wed Sep 29, 2010 10:51 pm
DirecTV boxes seem to be getting ignored by all of the DLNA media server software guys but I'll continue posting on this anyway...
I've figured out through various searches and trial and error that the DirecTV boxes will play audio along with video provided that they are in an MPEG container and the audio is in MP2 format (MPEG-1 Audio Layer II or MPEG-2 Audio Layer II). For whatever reason, it does not work for MP3 (MPEG-1 Audio Layer III or MPEG-2 Audio Layer III).
So far, I've accomplished this by running my VOBs through a program called MPEG Streamclip and using the "Convert to MPEG with MP2 Audio..." option. Once converted, sound and video work great.
Can MP2 be enabled in Serviio's transcoding? I believe that will fix the problems for DirecTV boxes.
Post Wed Sep 29, 2010 11:11 pm
That should be possible. Even though some people confirmed mp3 works too, so I'm not sure if that could be on a per-file basis. I'll add mp2 encoding in 0.5, if possible.
Can you confirm you can transcode your video to mpeg2ps with mpeg2video video codec and mp2 audio codec and the file is playable?
iys
Post Tue Oct 05, 2010 11:56 am
I think the difference for people that have gotten MP3 to work is that they have DVR boxes while my 2 boxes are simply HD with Media Share. No DVR. Aside from that, it's possible that my boxes may simply be older. I'm not sure.
Here are screen captures of the settings for one of my videos.
The original (which doesn't work on the DTV box) still in its DVD ready VOB(MPEG2PS)/MPEG2/AC3 format
The converted MPEG2PS/MPEG2/MP2 which works on the DTV box.
Post Tue Oct 05, 2010 2:35 pm
snapperhead
Post Fri Oct 08, 2010 1:39 am
Can someone post the solution/code to change the audio codec from AC3 to MP3 on the DirecTV Profile ... have no clue how to edit the profile renderer (i'm a newbie here) and I don't want to mess anything up. I too am able to view video but not playback any accompanying audio.
thx
Post Fri Oct 08, 2010 7:16 am
Change targetACodec="ac3" to targetACodec="mp3"
I also add <Matches container="avi" /> to transcode avi containers
   <Profile id="6" name="DirecTV HD-DVR" extendsProfileId="1">
      <Detection>
         <User-Agent>.*DIRECTV.*</User-Agent>
      </Detection>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="mp3" maxVBitrate="8192">
                <Matches container="mp4" />
                <Matches container="asf" />
josh208
Post Thu Feb 10, 2011 9:50 pm
A number of people have found that change targetACodec to 'mp3' does not work, this was the case for me. However, 0.5 now supports target of 'mp2'. This works!
Gleaned this from: http://www.serviio.org/index.php?option ... icle&id=24
Sidenote: I also had to set downmix to stereo under video settings on the Transcoding Tab otherwise FFMPEG would croak claiming impossible bitrate (Before doing this, I would not even get video).
Post Thu Feb 10, 2011 11:20 pm
josh208 wrote:A number of people have found that change targetACodec to 'mp3' does not work, this was the case for me. However, 0.5 now supports target of 'mp2'. This works!
cant you just force the abitrate to 192k in the profile rather than setting downmix ????
josh208
Post Mon Mar 07, 2011 10:23 pm
Did not try, but I'm not convinced that would be a valid workaround as I believe the complaint had more to do with the fact that mp2 only supports 2-channel audio. But I could be mistaken. :?:
