[SOLVED] There are no files in this folder
lagacer
Post Tue Nov 29, 2011 1:17 am
Hello everyone,
I currently have a SONY BDPS370 connected on my serviio server under Ubuntu and everything works fine.
I just bought a Panasonic DMP-BD75 and try to play same files I can play with my SONY, but when a browse the server with the Panasonic, for every folder i got this message:
I try mp3 music file, works perfect on both BD.
This is the output of one of my file:
FFmpeg version SVN-r0.5.1-4:0.5.1-1ubuntu1.2, Copyright (c) 2000-2009 Fabrice Bellard, et al.
  configuration: --extra-version=4:0.5.1-1ubuntu1.2 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --disable-stripping --disable-vhook --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
  libavutil     49.15. 0 / 49.15. 0
  libavcodec    52.20. 1 / 52.20. 1
  libavformat   52.31. 0 / 52.31. 0
  libavdevice   52. 1. 0 / 52. 1. 0
  libavfilter    0. 4. 0 /  0. 4. 0
  libswscale     0. 7. 1 /  0. 7. 1
  libpostproc   51. 2. 0 / 51. 2. 0
  built on Sep 16 2011 17:04:18, gcc: 4.4.3
Input #0, avi, from 'The.Big.Bang.Theory.S05E01.avi':
  Duration: 00:21:11.78, start: 0.000000, bitrate: 1154 kb/s
    Stream #0.0: Video: mpeg4, yuv420p, 624x352 [PAR 1:1 DAR 39:22], 23.98 tbr, 23.98 tbn, 23.98 tbc
    Stream #0.1: Audio: mp3, 48000 Hz, stereo, s16, 160 kb/s
Hope my information is helpful and sorry for the english :D
I do my best
Post Tue Nov 29, 2011 7:55 am
Re: There are no files in this folder
have u assigned the correct profile for your panasonic in the console :)
lagacer
Post Tue Nov 29, 2011 7:45 pm
That's a good question :D Yes ;)
I just realize this box only play mkv... make sens to you?
I'll probably return this Blue-ray, all my library are in avi
Post Wed Nov 30, 2011 7:36 am
yer buy a sony or samsung they are the best imho
lagacer
Post Wed Nov 30, 2011 1:01 pm
Thanks you very much Cerberus for you support.
I bought a Samsung and is working perfect! The menu is not so userfriendly than a Sony, but it's work ;)
Thanks again and you can consider my "case" close.
I don't know how to change the status of my post to fix.
tim1964
Post Wed Dec 28, 2011 12:45 am
Re: [SOLVED] There are no files in this folder
Just seen this thread after posting about my new Panasonic DMP-BD75.
Can you confirm that the player does NOT play back AVI's ?
All of my files are these.
lagacer wrote:That's a good question :D Yes ;)
Also, lagacer, how did you get it to work at all as I've been trying now for 2 days and still can't get it to work???????
Edit-- Just spotted on the Panasonic site it says the player supports "AVCHD, WMV, DivX, JPEG, MP3 and WMA on your PC or AVCHD files, recorded programmes and JPEG......" Aren't DivX and AVIs the same sort of file ???
Thanks,
tim1964
Post Wed Dec 28, 2011 12:50 am
Cerberus,
I cannot see the correct profile for my BD75 player on the console so I selected Generic. Will this still work?
Thanks,
Post Wed Dec 28, 2011 12:54 am
see attached image above on how to select profiles. Although please answer my questions in your own topic rather than this one.
Return to Panasonic
