ffmpeg.exe encoutered a problem
jbfarin
Post Tue Nov 29, 2011 11:41 pm
i keep getting "ffmpeg.exe has encountered a problem and needs to close. We are sorry fot he inconvience" all the time.....Help...
Post Wed Nov 30, 2011 8:03 am
Re: ffmpeg.exe encoutered a problem
jbfarin wrote:i keep getting "ffmpeg.exe has encountered a problem and needs to close. We are sorry fot he inconvience" all the time.....Help...
This is a short question.
What is your OS?
What is your ffmpeg version?
When did this message appears, OS start-up, dlna browsing, movie streaming?
jbfarin
Post Wed Nov 30, 2011 4:46 pm
sorry....guess that would help....I am using windows xp, the ffmpeg is what i downloaded with the newest Servioo, and this happens when really nothing is going on except the servio service is running. I am not even streaming any movies, it starts about 5 minutes after I restart the computer. Sometimes I ill literally have 100 of those messages stacked up on my computer if I leave it alone for a period of time...This is an older computer i use it with could that be a problem? Thanks...
Post Wed Nov 30, 2011 5:03 pm
OK thanks,
What is your Java version?
Could you check the serviio logging file, post here ? (see signature link)
If log is too big, stop serviio service, clean/remove the log file, then restart serviio service and post log here.
jbfarin
Post Wed Nov 30, 2011 5:07 pm
ok will do when I get home.....about 8 hours from now
WildRushSykes
Post Fri Dec 02, 2011 6:18 pm
Try this
Update your java Version to 7 Update 1 from here...
http://download.oracle.com/otn-pub/java ... s-i586.exe
Also download the latest ffmpeg version for windows from here...
http://ffmpeg.zeranoe.com/builds/win32/ ... -static.7z
As some of the BBC Iplayer videos need the updated version to work properly
jbfarin
Post Sat Dec 03, 2011 5:26 pm
ok will try thanks....
dualc
Post Sat Dec 03, 2011 5:41 pm
I will also .. try .. out the files linked to.. cose i have the same problem..
/M
BlurayPlayer: Samsung BD-C5500
TV: Samsung LE40B535
WildRushSykes
Post Sat Dec 03, 2011 5:46 pm
Just in case you have a 64 bit machine use these links...
Java 7 Update 1
http://download.oracle.com/otn-pub/java ... ws-x64.exe
Latest FFmpeg Version here
http://ffmpeg.zeranoe.com/builds/win64/ ... -static.7z
The ffmpeg is located in the bin directory after you extract from the above file just copy and paste it over the one located in program files of serviio in the lib folder and restart the serviio service
dualc
Post Sat Dec 03, 2011 6:05 pm
Thx.. WildRush, .. i have 32Bit XP.. so i tried the first ones.. :) hope it works...
WildRushSykes
Post Sat Dec 03, 2011 6:08 pm
if it dosent work please repost with more info and ill try and help :D
jbfarin
Post Sun Dec 04, 2011 12:02 am
ok dl the latest Java with no issues but how do i do the latest FFmpeg. It says it an unknown file ( but doesnt servio6.02 have the latest FFMPEG?) again thanks...
WildRushSykes
Post Sun Dec 04, 2011 1:12 am
Download WinRAR here and install it then right click the file and choose extract here after its done locate the bin folder and copy the ffmpeg inside to your serviio lib folder and replace the old one
Im assuming its a custom built ffmpeg as its half the size of the new one with alot of the services disabled although zip could tell you more :D
jbfarin
Post Sun Dec 04, 2011 3:24 am
apprecite your help...i was able to replace the ffmpeg but now it says that ffmpeg.exe is not an excutable windows 32 application...I am running this on windows XP...old computer....works great on my laptop ...is just that the my desktop is too old?...I did update java but was still gettingt he same error...
WildRushSykes
Post Sun Dec 04, 2011 3:39 am
dont run it just stop and start the serviio service within the start menu and your all set or do a full reboot of your pc :D also are u using serviio 0.6.0.1 which has a ffmpeg fix?
jbfarin
Post Sun Dec 04, 2011 7:22 am
I am running 6.01 so thought that had the latest FFmpg....I restarted the compter and still got that same message......again thanks for the help....
WildRushSykes
Post Sun Dec 04, 2011 8:17 am
try this
remove all your online feeds then add them one by one and let them populate till you see the ffmpeg error
then let me know which feed is causing the issue
jbfarin
Post Sun Dec 04, 2011 5:04 pm
I dont have any online feeds. It seems to happen when it is refreshing the library.
WildRushSykes
Post Sun Dec 04, 2011 7:12 pm
What does your library mainly consist of format wise?
Post Sun Dec 04, 2011 8:31 pm
Please post the serviio DEBUG log file (see my signiture for a how to)...
