New profile needed for Panasonic Viera
HipHopAnonymous5116
Post Sun Dec 18, 2011 5:28 pm
I just got a Panasonic Viera (Model number TC-P46X3) that isn't functional with the default "Panasonic Viera" profile.
The supported video codecs for this tv that are listed in the manual are:
Video *MP4 (Video codec H.264 | Audio codec MP3/AC-3/LPCM)
*MKV (Video codec H.264 | Audio codec MP3/AC-3/LPCM)
*MPEG-2 PS and TS
It seems the default Panasonic Viera profile allows direct streaming of avi's with no transcoding, resulting in a "cannot read" error on the TV.
I've found a semi-solution http://forum.serviio.org/viewtopic.php?f=13&t=3152#p20484 <--there with a slight modification listed further down in the post but am still having "cannot read" errors with particular videos while using this profile.
Anyway, I didn't see the specs of this TV up here yet so figured the info would be useful to the developers.
Thanks for your work, this is a great program.
Post Sun Dec 18, 2011 9:53 pm
Re: New profile needed for Panasonic Viera
Can you supply the information on the supported formats of a device (see signature)?
HipHopAnonymous5116
Post Mon Dec 19, 2011 3:31 am
moltra wrote:Can you supply the information on the supported formats of a device (see signature)?
Thanks for the quick reply. I made sure UPnP was enabled in my routers settings, then attempted to pull that information for you with DeviceSpy, but the device was not listed. I then searched the DLNA product database, but came up empty handed on an exact match. They have an X3L and an X3H listed, but not just an X3 and neither are listed as a 46 inch.
Post Mon Dec 19, 2011 8:53 am
http://certification.dlna.org/certs/REG31047323.pdf
This is the minimal supported format, but we know that T30 series doesn't support avi/divx/wmv but E30 series does
HipHopAnonymous5116
Post Mon Dec 19, 2011 2:31 pm
Illico wrote:http://certification.dlna.org/certs/REG31047323.pdf
Yes! This is my model panasonic. And I can confirm that avi/divx/xvid/wmv does not stream natively. Transcoding is necessary. And as I posted earlier, the Owner's manual lists the only supported video formats as:
*MPEG-2 PS and TS
Post Tue Dec 20, 2011 1:01 pm
So a new Panasonic profile is needed for models that does not support avi in native format
HipHopAnonymous5116
Post Wed Dec 21, 2011 4:30 am
Illico wrote:So a new Panasonic profile is needed for models that does not support avi in native format
So it would seem.
Post Wed Dec 21, 2011 12:13 pm
could you run this and post the result?
viewtopic.php?f=5&t=19
HipHopAnonymous5116
Post Wed Dec 21, 2011 2:37 pm
zip wrote:could you run this and post the result?
Ok, I made sure UPnP was enabled on my router, then attempted to pull that information for you with DeviceSpy, but my tv was not listed. Of course I manually refreshed, turned the tv off and on a few times, and tried playing something from my computer. No go. Sorry man.
huyz
Post Tue Jan 31, 2012 6:21 pm
So it would seem.
For a new profile, see viewtopic.php?f=7&t=5091
Post Tue Jan 31, 2012 8:11 pm
So it would seem.
depends on your model if that profile is needed as some panasonics will play AVI files natively, so wont need them transcoded. Also Perl scripts are NOT a solution to a problem they are just used for TESTING and should not be used by basic users.
I have taken your profile made a couple of changes (AVI support and LPCM rather than MP3 for better quality) and put in a new thread for you so that the confusing bit is no longer present and we can get users feedback. ( viewtopic.php?f=13&t=5119 )
Return to Panasonic
Users browsing this forum: Baidu [Spider] and 13 guests
