MacBook Pro sees Viera but Viera says: DLNA server not found
Jelyot
Post Tue Dec 27, 2011 11:20 pm
This is quite frustrating. Finally got Serviio to detect my new Panasonic Viera Plasma, however when I go to Viera Tools on the TV, it tells me there is no DLNA server found. Not much useful information on these postings I'm afraid. Is there anyone who can help me get the MacBook Pro to stream wirelessly to the Viera?
Post Wed Dec 28, 2011 12:29 am
Re: MacBook Pro sees Viera but Viera says: DLNA server not f
FAQ wrote:This could be caused by you having multiple IP addresses on the machine and Serviio binding to a wrong one. Insert IP address of the machine running Serviio into 'Bound IP address' field in Network Settings section in the console
Also please run the commands in this wiki and post the information here: http://wiki.serviio.org/doku.php?id=portinfo_mac
Jelyot
Post Wed Dec 28, 2011 9:47 pm
Tried that before I got into this discussion. IP address for MacBook is entered correctly in "bound IP address" box. After entering that, my Macbook recognized my Viera, but the TV still sees "no server."
I clicked on the Wiki link, but have no idea what it's for or what you're asking me to do on it.
Post Wed Dec 28, 2011 9:57 pm
Can you post your serviio.log file?
Jelyot
Post Wed Dec 28, 2011 10:19 pm
Not seeing any settings or commands on the Serviio Console to find a log file.
Post Wed Dec 28, 2011 10:26 pm
Please run these 3 commands from your mac and post the information here.
wiki wrote:so in the case of serviio:
sudo lsof -i -P | grep LISTEN
sudo lsof -i udp:1900
sudo lsof -i tcp:8895
are the one you maybe asked to run.
Jelyot
Post Wed Dec 28, 2011 10:29 pm
Sorry, but again, I have no clue what you mean.
Jelyot
Post Wed Dec 28, 2011 10:31 pm
I read all these commands on the Wiki before. In my 20 years of owning a Mac I don't think I've ever "run a command." If the only way to get this program to work is to learn programming language, I'd better seek another solution.
Post Wed Dec 28, 2011 11:02 pm
Jelyot wrote:I read all these commands on the Wiki before. In my 20 years of owning a Mac I don't think I've ever "run a command." If the only way to get this program to work is to learn programming language, I'd better seek another solution.
nothng to do with programming at all they are terminal commands.
Jelyot
Post Thu Dec 29, 2011 12:42 am
Meaning?
Return to Panasonic
