how to add radio to stream
zit1343
Post Mon Jan 09, 2012 8:29 pm
Hi
I have sony home theater, I want to add live internet radio stream link & play on my home theater how can i do it please, i already have serviio working & updated.
edit
nevermind it got it working, I entered this in url
http://94.23.0.147:8128
it worked thanks
WildRushSykes
Post Mon Jan 09, 2012 8:38 pm
Re: how to add radio to stream
zit1343 wrote:Hi
edit
it worked thanks
lol its nice when users sort out their own problems. Means i can have a cup of tea and put my feet up :lol: :lol: :lol:
zit1343
Post Mon Jan 09, 2012 9:34 pm
got problem this time lol
I add more streams same style ip adress type
but it won't show on my the list I restarted everything even my pc & sony player
dont know what I m doing wrong
help me out
thanks
WildRushSykes
Post Mon Jan 09, 2012 9:48 pm
ive only ever got a few live streams working myself i dont think all streams are supported but zip can verify this
zit1343
Post Mon Jan 09, 2012 9:55 pm
i mean I added other streams but they don't even show up in list
something is not right
Post Mon Jan 09, 2012 10:16 pm
Serviio tests that stream exists before adding it.
Test url's with ffmpeg -1 url before adding to serviio.
If ffmpeg can't get the neither can Serviio so it won't display.
zit1343
Post Mon Jan 09, 2012 10:23 pm
you mean
ffmpeg -1 in my command prompt?
sorry i dont know how to test it
Post Mon Jan 09, 2012 10:46 pm
Yes. Use the ffmpeg in Serviio lib C:\Program Files\Serviio\lib\ffmpeg.exe
zit1343
Post Mon Jan 09, 2012 10:58 pm
thannks
this is wht i get for 1 tht is working
C:\Program Files\Serviio\lib>ffmpeg -i http://94.23.0.147:8128
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffser
ime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-mingw32- -
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
[mp3 @ 02a00ba0] Header missing
[mp3 @ 00398300] max_analyze_duration 5000000 reached at 5015510
[mp3 @ 00398300] Estimating duration from bitrate, this may be inaccurate
Input #0, mp3, from 'http://94.23.0.147:8128':
  Duration: N/A, start: 0.000000, bitrate: 128 kb/s
    Stream #0:0: Audio: mp3, 44100 Hz, stereo, s16, 128 kb/s
& for 1 tht dont even show up
C:\Program Files\Serviio\lib>ffmpeg -i http://stream.bollywoodmusicradio.com
[mp3 @ 033b05a0] Header missing
[mp3 @ 01458300] max_analyze_duration 5000000 reached at 5015510
[mp3 @ 01458300] Estimating duration from bitrate, this may be inaccurate
Input #0, mp3, from 'http://stream.bollywoodmusicradio.com':
WildRushSykes
Post Mon Jan 09, 2012 11:01 pm
http://stream.bollywoodmusicradio.com <-------------
you need to change that to the ip address it uses not the url
Post Mon Jan 09, 2012 11:24 pm
WildRushSykes wrote:http://stream.bollywoodmusicradio.com <-------------
should not be necessary
zit1343
Post Mon Jan 09, 2012 11:26 pm
i triend many other with ip address dont work either
i just happen tht i posted this one lol
Post Mon Jan 09, 2012 11:53 pm
Both streams show valid mp3 content and they both stream fine for me.
Return to General discussion
