Sopcast
Susan-334
Post Tue Jan 10, 2012 9:23 pm
Sopcast
I have managed to get a stream working from Sopcast, but some other Sopcast streams don't work. Can someone work out why some don't work?
This is what I did.
1. Launched the Sopcast application on the PC and selected a channel to test.
2. On the Sopcast player, right click, select properties and 'copy' the Location URL that starts http://
3. Within Serviio, 'paste' the URL as a live stream under online resources, then access via the TV.
A stream that works is:
Channel - 6022. HuNaN TV
Video Codec: Windows Media Video 9
Audio Codec: Windows Media Audio 9
32 kbps, 44 kHz, stereo (A/V) 1-pass CBR
An example of a Sopcast stream that won't work (The Samsung C series TV gives a 'file type not supported' message:
Channel - 116230
Audio Codec: Windows Media Audio 9.2
32 kbps, 44 kHz, mono 1-pass CBR
Video Codec: VC-1 VC-1 Advanced Profile
Can anyone please help to get more of the Sopcast streams to work from Serviio?
Post Tue Jan 10, 2012 9:37 pm
Re: Sopcast
great. can you post reult of
ffmpeg -i stream_url
for the stream that doesn't work?
It'd also be cool if you wrote the tutorial on our wiki.
Susan-334
Post Wed Jan 11, 2012 2:03 am
Re: Sopcast
zip wrote:great. can you post reult of
Sorry, I don't know how to do that. I would need an Idiot guide of what to do.
Post Wed Jan 11, 2012 8:16 am
Re: Sopcast
HOWTO: Provide details of a video file that doesn't play <-- in our signitures
Susan-334
Post Wed Jan 11, 2012 6:24 pm
Re: Sopcast
When I double click on FFmpeg.exe in C:\Program Files (x86)\Serviio\lib
I can see the black window containing some white text (and yellow text towards the bottom) but it only shows for a second and then the window disappears.
I have found another Sopcast live stream that works:
Channel: web-sport.org [ua]
Video Size: 720 x 576
Video Codec: Windows Media Video 8
Audio Codec: Windows Media Audio (v2) 7, 8 and 9 Series
Post Wed Jan 11, 2012 6:57 pm
Re: Sopcast
you have to run it from CMD window, so that you can then see the info. :)
http://wiki.serviio.org/doku.php?id=howto_win_ffmpeg
crazyfool30
Post Wed Jan 11, 2012 7:26 pm
Re: Sopcast
I just tried out a sports stream and it worked then the HuNan channel and it didn't, even though they both have the same video and audio codecs. While HuNan was still playing on sopcast i exited serviio then started server and opened the console again, hit force library refresh just to be sure and sure enough, HuNan is now working on my Samsung TV! I'm not sure serviio can just start playing a different stream without being refreshed first, and this seamed like the quickest way.
Susan-334
Post Wed Jan 11, 2012 7:35 pm
Re: Sopcast
Here is an example of a Sopcast stream that I can't get to work:
Channel: Channel - 115566
Audio Codec: MPEG Audio Layer 3
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "http://127.0.0.1:8902/
nfig
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
[asf @ 015b81c0] freeing incomplete packet size 4384, new 23397
[asf @ 015b81c0] Estimating duration from bitrate, this may be inaccurate
Seems stream 1 codec frame rate differs from container frame rate: 1000.00 (1000
/1) -> 24.00 (24/1)
Input #0, asf, from 'http://127.0.0.1:8902/':
Duration: N/A, start: 23922.417000, bitrate: 128 kb/s
Stream #0:0: Audio: mp3 (U[0][0][0] / 0x0055), 44100 Hz, 2 channels, s16, 12
8 kb/s
Stream #0:1: Video: wmv2 (WMV2 / 0x32564D57), yuv420p, 432x346, SAR 10:9 DAR
240:173, 24 tbr, 1k tbn, 1k tbc
crazyfool30
Post Wed Jan 11, 2012 7:44 pm
Re: Sopcast
115566? Just about to start spurs v everton? Just started streaming on sopcast, exited and restarted serviio and the stream is working on my tv. Reports the same codecs in properties as you had...
Susan-334
Post Wed Jan 11, 2012 8:09 pm
Re: Sopcast
crazyfool30 wrote:115566? Just about to start spurs v everton? Just started streaming on sopcast, exited and restarted serviio and the stream is working on my tv. Reports the same codecs in properties as you had...
Yes same channel. I've tried restarting Serviio a few times but I keep getting the message 'not supported file format' on my Samsung C series.
crazyfool30
Post Wed Jan 11, 2012 9:43 pm
Re: Sopcast
I've got 2 samsung tv's. Works fine on my smaller one but tried it on my LE46C750 and it doesn't work :cry: guess it's partly down to the tele.
Susan-334
Post Wed Jan 11, 2012 11:33 pm
Re: Sopcast
This is strange... I left Sopcast channel 115566 running on the PC. I have just tried again on the TV and it is now working. I had not changed anything to make it work, I had just left it running.
I wonder if there is some sort of cache going on that does not get cleared or reset for ages. Perhaps something in Serviio is calculating the length of the program and doesn't reset when you change to a different Sopcast program?
My TV is a Samsung C650.
grolschie
Post Thu Jan 12, 2012 12:49 am
Re: Sopcast
I am pretty sure Sopcast was working on PS3 Media Server a while back with a plugin. IIRC, it fires up the Sopcast process on the PC for you (and possibly kills it afterward).
Susan-334
Post Thu Jan 12, 2012 3:14 am
Re: Sopcast
All the channels seem to be playing fine now.
I think that I've worked-out a trick to get it working... the problem is in changing Sopcast channels. To get it to work, I have to exit the live Sopcast stream (on the TV) , then change the channel on Sopcast (on your PC), then select the Sopcast stream on the TV for it to play the new channel.
My problem was that I had left the stream running on the TV whilst changing Sopcast channels. Changing the Sopcast channel (on the PC) resulted in the TV exiting the Sopcast stream. When I again selected the Sopcast stream (via the TV) the TV wouldn't then pick up the new channel and gave the 'file format not supported' error message.
If you keep getting the 'file format not supported' error message on the TV for the Sopcast live stream, try going to a different Serviio live stream on the TV (such as the 4OD live streams). Leave it playing for about 30 seconds, then exit. This seems to clear the problem. Then go back to select the Sopcast live stream. It now seems to work (for me).
I have no idea why this problem happens, but I seem to have it working by using this trick.
Ignatiusjr
Post Wed Feb 15, 2012 4:07 pm
Re: Sopcast
I keep getting 'video codec unsuported' on every sopcast stream on my samsung d series tv
Ignatiusjr
Post Wed Feb 15, 2012 4:28 pm
Re: Sopcast
Ignatiusjr wrote:I keep getting 'video codec unsuported' on every sopcast stream on my samsung d series tv
Oh silly me. I simply had the generic dlna profile selected for my tv i serviio. Works like a charm now with the correct profile
Wingsgb
Post Sun Feb 26, 2012 5:09 pm
Re: Sopcast
Edited as problem solved itself somehow :)
asddsa01
Post Tue Apr 03, 2012 11:38 am
Re: Sopcast
I try on my serviio this adress for sopcast http://127.0.0.1:8902/stream
I put as livestream on my xp and this ok , but whem try this thing in WIN7 don't work
This link http://127.0.0.1:8902/stream don't apear on my win7 but in xp it's ok.
Sory for my language.
Users browsing this forum: Baidu [Spider] and 1 guest
