Why not use latest ffmpeg ?
hennys
Post Tue Sep 21, 2010 7:15 am
Why don't you distribute the latest ffmpeg with Serviio?. Has this do to with compatibility / testing ?
Is it possible to update the ffmpeg to the latest version like is suggested somewhere in this forum ?
Regards,
Hen
Post Tue Sep 21, 2010 8:20 am
Re: Why not use latest ffmpeg ?
yes, compatibility. My distribution also includes a patch to enable MKV remuxing. Some people use the latest FFmpeg, you can give it a try if you have problems with the current distributed version.
hennys
Post Tue Sep 21, 2010 1:27 pm
Thank you for your reply. I am not yet using serviio, but my new tv is being shipped right now, so it won't be long before I will.
I just looked in to some things and read on the internet that FFmpeg 23143 now has an option to utilise GPU for transcoding. It would be a shame not to use the GPU if we could :)...
Regards,
Hen
Post Tue Sep 21, 2010 2:06 pm
Cool, can you post a link?
hennys
Post Thu Sep 23, 2010 2:57 pm
This was it: ( I am not a developer, so I hope I interpreted the info correctly)
http://www.gossamer-threads.com/lists/m ... vnz/437343
Regards,
Hen
