Samsung D7000 : Can't use Serviio since update
andrewknight
Post Sat Jan 14, 2012 12:00 am
Hi all,
I'm a complete novice so I apologise for my basic terms. I hope you can help.
I have been using Serviio on my Laptop and connecting to my Samsung D7000 TV with no problem.
However, since updating in the past week, I have not been able to see Serviio on my TV.
I have gone as far as completlly uninstalling Serviio and reinstalling it on my laptop.
My problem now is that on the Serviio console it doesn't recognise any receivers (i.e my TV doesn't appear in the list).
Essentially I may as well not have Serviio on my laptop as it is not recognising the TV and the TV is not recognising it.
As mentioned, this is only since the upgrade.
Any help would be greatfully received...THANK YOO THANK YOU THANK YOU
Post Sat Jan 14, 2012 8:22 am
Re: Samsung D7000 : Can't use Serviio since update
have you set bound IP in teh consoel to ip of pc running serviio ?
SilentSeven
Post Sat Jan 14, 2012 7:55 pm
0.6.1 works fine with my D7000
andrewknight
Post Sat Jan 14, 2012 9:36 pm
HI,
Thanks for the replies.
I'm not sure what you mean by set the bound IP address of laptop.
If you mean, have I added the IP address of my laptop to the "Bound IP" box in the Status tab of the console, then yes.
In the previous version though, the status screen would autiomatically pick up all my devices and show them on this sreen.
Currently that screen is just blank.
Are you able to advise me using Non-Techie words (sorry, Im a bit slow)
Thanks so much
Post Sat Jan 14, 2012 9:58 pm
Can you post your serviio.log file please.
andrewknight
Post Sat Jan 14, 2012 9:59 pm
Can you advise me how to go about running the log?
Post Sat Jan 14, 2012 10:03 pm
it will be in the serviio folder in the folder called log
andrewknight
Post Sat Jan 14, 2012 10:13 pm
I don't seem to have a LOG file ?!?!!?
Just
READ ME
RELEASE NOTES
SERVIIO CONSOLE
START SERVIIO SERVICE
STOP SERVIIO SERVICE
UNINSTALL
Post Sat Jan 14, 2012 10:14 pm
what os are you using?
andrewknight
Post Sat Jan 14, 2012 10:25 pm
Sorry, I'm an idiot. Just found the log file.
The log file is 497609 characters (too big to post here)
Can I email it somewhere or attach the file?
Post Sat Jan 14, 2012 10:27 pm
You and zip it up and post it here, or rename the current log file and then restart serviio and a new smaller log will be created.
andrewknight
Post Sat Jan 14, 2012 11:00 pm
You guys are incredibly helpful !!!...
Here is the log
2012-01-14 22:56:39,990 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-01-14 22:56:39,990 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-14 22:56:44,455 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-14 22:56:44,798 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-14 22:57:11,043 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-14 22:57:11,730 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-14 22:57:12,291 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-14 22:57:12,697 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-14 22:57:12,978 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-14 22:57:13,258 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-14 22:57:13,399 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-14 22:57:13,882 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-14 22:57:13,914 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-14 22:57:14,428 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-14 22:57:15,286 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-14 22:57:15,598 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-14 22:57:15,957 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-14 22:57:16,191 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-14 22:57:16,394 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-14 22:57:16,659 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-14 22:57:16,722 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-14 22:57:17,080 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-14 22:57:17,190 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-14 22:57:17,502 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-14 22:57:17,673 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-14 22:57:17,829 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-14 22:57:17,829 INFO [Device] Created UPnP Device with UUID: 845849ff-fb73-3682-9791-500c0f07784e, bound address: 192.168.1.68
2012-01-14 22:57:18,157 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-01-14 22:57:18,157 INFO [PluginCompilerThread] Started looking for plugins
2012-01-14 22:57:19,336 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-14 22:57:19,501 INFO [WebServer] WebServer starting on port 8895
2012-01-14 22:57:19,506 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-14 22:57:19,516 INFO [EventDispatcher] Starting EventDispatcher
2012-01-14 22:57:19,516 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-14 22:57:19,516 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-14 22:57:19,516 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-14 22:57:19,601 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net3 (Dell Wireless 1395 WLAN Mini-Card) and address 192.168.1.68, timeout = 0
2012-01-14 22:57:46,186 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-14 22:57:46,193 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-14 22:57:46,205 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-14 22:58:12,451 INFO [UpdateChecker] Checking if a new version is available
2012-01-14 22:58:18,003 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-01-14 22:58:18,693 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
Post Sun Jan 15, 2012 11:35 am
Need a little more of the log. Need about the next 75-100 lines. That is where it starts looking for renderers.
andrewknight
Post Mon Jan 16, 2012 10:41 am
Thanks will have a look again tonight, but that was the full log at the time of posting.
andrewknight
Post Tue Jan 17, 2012 9:52 am
2012-01-14 23:01:10,935 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:01:11,253 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:01:17,915 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:01:18,251 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:01:25,914 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:01:26,250 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:01:34,912 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:01:35,248 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:01:44,912 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:01:45,247 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:02:04,905 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:02:05,241 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:02:44,900 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:02:45,247 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:04:04,886 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:04:05,223 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:06:44,859 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:06:45,195 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:11:44,814 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:11:45,149 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:16:44,769 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:16:45,121 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:21:44,723 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:21:45,067 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:22:49,964 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-01-14 23:22:49,969 INFO [EventDispatcher] Leaving EventDispatcher
2012-01-14 23:22:49,969 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-01-14 23:22:49,968 INFO [WebServer] WebServer shutting down
2012-01-14 23:22:53,086 INFO [Device] Updated bound IP address of Device with UUID: 845849ff-fb73-3682-9791-500c0f07784e, bound address: 192.168.1.68
2012-01-14 23:22:53,088 INFO [WebServer] WebServer starting on port 8895
2012-01-14 23:22:53,090 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-14 23:22:53,090 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-14 23:22:53,095 INFO [EventDispatcher] Starting EventDispatcher
2012-01-14 23:22:53,099 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-14 23:22:53,142 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net3 (Dell Wireless 1395 WLAN Mini-Card) and address 192.168.1.68, timeout = 0
2012-01-14 23:22:54,512 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-01-14 23:26:44,630 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-01-14 23:26:45,013 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:31:44,629 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:31:44,965 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:36:44,585 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:36:44,921 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:41:44,540 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:41:44,876 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:42:29,123 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-14 23:42:29,150 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-01-14 23:42:29,150 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-01-14 23:42:29,221 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-14 23:42:29,321 INFO [FeedUpdaterThread] Finished looking for online resources information
2012-01-14 23:42:29,421 INFO [PluginCompilerThread] Finished looking for plugins
2012-01-14 23:42:29,555 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-01-14 23:42:29,556 INFO [WebServer] WebServer shutting down
2012-01-14 23:42:29,556 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-01-14 23:42:29,557 INFO [EventDispatcher] Leaving EventDispatcher
2012-01-14 23:42:32,229 INFO [DatabaseManager] Shutting down database
2012-01-14 23:42:32,917 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-14 23:42:34,537 INFO [ServiioConsole] Leaving Serviio Console
2012-01-14 23:43:28,049 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-14 23:43:28,050 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-14 23:43:28,050 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-14 23:43:28,050 INFO [MediaServer] http://www.serviio.org
2012-01-14 23:43:28,050 INFO [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2012-01-14 23:43:28,050 INFO [MediaServer] OS Windows Vista x86 6.0
2012-01-14 23:43:28,050 INFO [MediaServer] File encoding: windows-1252
2012-01-14 23:43:28,051 INFO [MediaServer] Headless mode enabled: true
2012-01-14 23:43:28,051 INFO [MediaServer] User home dir: C:\
2012-01-14 23:43:28,051 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-01-14 23:43:28,051 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-14 23:43:28,258 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-14 23:43:28,437 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-14 23:43:37,904 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-14 23:43:38,431 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-14 23:43:38,782 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-14 23:43:38,993 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-14 23:43:39,191 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-14 23:43:39,344 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-14 23:43:39,448 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-14 23:43:39,897 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-14 23:43:39,932 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-14 23:43:40,357 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-14 23:43:41,022 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-14 23:43:41,317 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-14 23:43:41,574 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-14 23:43:41,719 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-14 23:43:41,753 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-14 23:43:41,882 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-14 23:43:41,942 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-14 23:43:42,147 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-14 23:43:42,260 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-14 23:43:42,511 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-14 23:43:42,670 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-14 23:43:43,251 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-14 23:43:43,252 INFO [Device] Created UPnP Device with UUID: 845849ff-fb73-3682-9791-500c0f07784e, bound address: 192.168.1.68
2012-01-14 23:43:43,277 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-01-14 23:43:43,277 INFO [PluginCompilerThread] Started looking for plugins
2012-01-14 23:43:44,883 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-14 23:43:44,996 INFO [WebServer] WebServer starting on port 8895
2012-01-14 23:43:45,002 INFO [EventDispatcher] Starting EventDispatcher
2012-01-14 23:43:45,007 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-14 23:43:45,007 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-14 23:43:45,009 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-14 23:43:45,010 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-14 23:43:45,057 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net3 (Dell Wireless 1395 WLAN Mini-Card) and address 192.168.1.68, timeout = 0
2012-01-14 23:43:56,424 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-01-14 23:43:56,425 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-01-14 23:43:56,435 INFO [PluginCompilerThread] Finished looking for plugins
2012-01-14 23:43:56,769 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-01-14 23:43:56,770 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-01-14 23:43:56,771 INFO [WebServer] WebServer shutting down
2012-01-14 23:43:56,771 INFO [EventDispatcher] Leaving EventDispatcher
2012-01-14 23:43:59,476 INFO [DatabaseManager] Shutting down database
2012-01-14 23:43:59,490 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-01-14 23:44:00,010 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-01-14 23:44:00,756 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-14 23:45:18,642 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-14 23:45:18,704 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-14 23:45:18,704 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-14 23:45:18,704 INFO [MediaServer] http://www.serviio.org
2012-01-14 23:45:18,704 INFO [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2012-01-14 23:45:18,704 INFO [MediaServer] OS Windows Vista x86 6.0
2012-01-14 23:45:18,704 INFO [MediaServer] File encoding: windows-1252
2012-01-14 23:45:18,704 INFO [MediaServer] Headless mode enabled: true
2012-01-14 23:45:18,704 INFO [MediaServer] User home dir: C:\
2012-01-14 23:45:18,704 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-01-14 23:45:18,704 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-14 23:45:19,142 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-14 23:45:19,220 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-14 23:45:27,113 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-14 23:45:28,503 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-14 23:45:29,174 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-14 23:45:29,501 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-14 23:45:29,766 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-14 23:45:29,985 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-14 23:45:30,141 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-14 23:45:30,828 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-14 23:45:30,875 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-14 23:45:31,469 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-14 23:45:32,452 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-14 23:45:32,795 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-14 23:45:33,107 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-14 23:45:33,278 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-14 23:45:33,295 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-14 23:45:33,467 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-14 23:45:33,529 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-14 23:45:33,747 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-14 23:45:33,872 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-14 23:45:34,169 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-14 23:45:34,418 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-14 23:45:35,557 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-14 23:45:35,557 INFO [Device] Created UPnP Device with UUID: 845849ff-fb73-3682-9791-500c0f07784e, bound address: 192.168.1.68
2012-01-14 23:45:35,963 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-01-14 23:45:35,963 INFO [PluginCompilerThread] Started looking for plugins
2012-01-14 23:45:48,725 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-14 23:45:49,100 INFO [WebServer] WebServer starting on port 8895
2012-01-14 23:45:49,143 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-14 23:45:49,168 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-14 23:45:49,249 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-14 23:45:49,262 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-14 23:45:49,262 INFO [EventDispatcher] Starting EventDispatcher
2012-01-14 23:45:49,270 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net3 (Dell Wireless 1395 WLAN Mini-Card) and address 192.168.1.68, timeout = 0
2012-01-14 23:46:15,329 INFO [ServiioConsole] Starting Serviio Console
2012-01-14 23:46:16,976 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-14 23:46:16,983 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-14 23:46:16,998 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-14 23:46:23,809 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-01-14 23:46:25,927 INFO [Messages] Loaded console message bundle for locale: en
2012-01-14 23:46:25,986 INFO [UpdateChecker] Checking if a new version is available
2012-01-14 23:46:30,643 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-01-14 23:46:31,339 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-01-14 23:46:44,969 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:46:45,306 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:51:44,917 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:51:45,253 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.64:52235/dmr/SamsungMRDesc.xml
2012-01-14 23:54:11,871 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-14 23:54:11,872 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-01-14 23:54:11,873 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-01-14 23:54:11,972 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-14 23:54:12,124 INFO [FeedUpdaterThread] Finished looking for online resources information
2012-01-14 23:54:12,224 INFO [PluginCompilerThread] Finished looking for plugins
2012-01-14 23:54:12,336 INFO [WebServer] WebServer shutting down
2012-01-14 23:54:12,336 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-01-14 23:54:12,340 INFO [EventDispatcher] Leaving EventDispatcher
2012-01-14 23:54:12,342 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-01-14 23:54:14,267 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-01-14 23:54:20,640 INFO [DatabaseManager] Shutting down database
2012-01-14 23:54:21,419 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-14 23:54:27,323 INFO [ServiioConsole] Leaving Serviio Console
2012-01-14 23:54:35,618 WARN [RepositoryView$LibraryStatusCheckerThread] Error retrieving library update status: Connection Error (1000) - Connection refused: connect
2012-01-14 23:59:50,562 INFO [ServiioConsole] Starting Serviio Console
2012-01-14 23:59:54,237 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-01-15 00:00:05,384 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2012-01-15 00:00:15,395 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2012-01-15 00:00:15,401 INFO [Messages] Loaded console message bundle for locale: en
2012-01-15 00:00:25,406 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2012-01-15 00:00:31,068 INFO [ServiioConsole] Leaving Serviio Console
2012-01-15 11:10:25,537 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-15 11:10:25,568 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-15 11:10:25,568 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-15 11:10:25,568 INFO [MediaServer] http://www.serviio.org
2012-01-15 11:10:25,568 INFO [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2012-01-15 11:10:25,568 INFO [MediaServer] OS Windows Vista x86 6.0
2012-01-15 11:10:25,568 INFO [MediaServer] File encoding: windows-1252
2012-01-15 11:10:25,568 INFO [MediaServer] Headless mode enabled: true
2012-01-15 11:10:25,568 INFO [MediaServer] User home dir: C:\
2012-01-15 11:10:25,568 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-01-15 11:10:25,568 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-15 11:10:38,687 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-15 11:10:43,867 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-15 11:11:18,673 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-15 11:11:19,672 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-15 11:11:20,358 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-15 11:11:20,592 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-15 11:11:20,810 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-15 11:11:21,091 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-15 11:11:21,217 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-15 11:11:21,794 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-15 11:11:21,841 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-15 11:11:22,387 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-15 11:11:23,073 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-15 11:11:23,370 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-15 11:11:23,697 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-15 11:11:23,853 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-15 11:11:23,885 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-15 11:11:24,009 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-15 11:11:24,072 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-15 11:11:24,276 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-15 11:11:24,369 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-15 11:11:24,634 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-15 11:11:24,806 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-15 11:11:28,270 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-15 11:11:28,317 INFO [Device] Created UPnP Device with UUID: 845849ff-fb73-3682-9791-500c0f07784e, bound address: 192.168.1.68
2012-01-15 11:11:29,362 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-01-15 11:11:29,471 INFO [PluginCompilerThread] Started looking for plugins
2012-01-15 11:11:46,803 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-15 11:11:47,630 INFO [WebServer] WebServer starting on port 8895
2012-01-15 11:11:47,630 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-15 11:11:47,630 INFO [EventDispatcher] Starting EventDispatcher
2012-01-15 11:11:47,630 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-15 11:11:47,631 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-15 11:11:47,631 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-15 11:11:47,751 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net3 (Dell Wireless 1395 WLAN Mini-Card) and address 192.168.1.68, timeout = 0
2012-01-15 11:11:53,601 INFO [RendererManager] Stored a new renderer: uuid='2db8e8d6-5b44-4de6-9b9a-7182821772d1', name = 'Unrecognized device', ipAddress='192.168.1.68', profile = '1'
2012-01-15 11:12:15,535 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-15 11:12:15,551 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-15 11:12:15,566 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-15 11:41:37,466 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-01-15 11:41:37,467 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-01-15 11:41:37,517 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-15 11:41:41,940 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-15 11:41:41,966 INFO [FeedUpdaterThread] Finished looking for online resources information
2012-01-15 11:41:42,066 INFO [PluginCompilerThread] Finished looking for plugins
2012-01-15 11:41:42,166 INFO [EventDispatcher] Leaving EventDispatcher
2012-01-15 11:41:42,167 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-01-15 11:41:42,174 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-01-15 11:41:42,175 INFO [WebServer] WebServer shutting down
2012-01-15 11:41:42,543 INFO [DatabaseManager] Shutting down database
2012-01-15 11:41:42,655 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-01-15 11:41:45,193 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-15 11:57:10,842 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-15 11:57:10,873 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-15 11:57:10,873 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-15 11:57:10,873 INFO [MediaServer] http://www.serviio.org
2012-01-15 11:57:10,873 INFO [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2012-01-15 11:57:10,873 INFO [MediaServer] OS Windows Vista x86 6.0
2012-01-15 11:57:10,873 INFO [MediaServer] File encoding: windows-1252
2012-01-15 11:57:10,873 INFO [MediaServer] Headless mode enabled: true
2012-01-15 11:57:10,873 INFO [MediaServer] User home dir: C:\
2012-01-15 11:57:10,873 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-01-15 11:57:10,873 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-15 11:57:17,550 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-15 11:57:17,597 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-15 11:58:04,119 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-15 11:58:05,398 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-15 11:58:06,178 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-15 11:58:06,412 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-15 11:58:06,646 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-15 11:58:06,802 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-15 11:58:07,005 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-15 11:58:07,551 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-15 11:58:07,582 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-15 11:58:08,019 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-15 11:58:08,674 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-15 11:58:08,986 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-15 11:58:09,236 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-15 11:58:09,392 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-15 11:58:09,423 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-15 11:58:09,548 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-15 11:58:09,610 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-15 11:58:09,813 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-15 11:58:09,907 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-15 11:58:10,156 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-15 11:58:10,297 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-15 11:58:12,886 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-15 11:58:12,933 INFO [Device] Created UPnP Device with UUID: 845849ff-fb73-3682-9791-500c0f07784e, bound address: 192.168.1.68
2012-01-15 11:58:13,854 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-01-15 11:58:13,947 INFO [PluginCompilerThread] Started looking for plugins
2012-01-15 11:58:18,924 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-15 11:58:19,579 INFO [WebServer] WebServer starting on port 8895
2012-01-15 11:58:19,594 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-15 11:58:19,594 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-15 11:58:19,594 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-15 11:58:19,595 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-15 11:58:19,595 INFO [EventDispatcher] Starting EventDispatcher
2012-01-15 11:58:19,851 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net3 (Dell Wireless 1395 WLAN Mini-Card) and address 192.168.1.68, timeout = 0
2012-01-15 11:58:46,808 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-15 11:58:46,823 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-15 11:58:46,839 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-15 12:19:08,794 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-01-15 12:19:08,795 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-01-15 12:19:08,796 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-15 12:19:08,894 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-15 12:19:08,994 INFO [FeedUpdaterThread] Finished looking for online resources information
2012-01-15 12:19:09,094 INFO [PluginCompilerThread] Finished looking for plugins
2012-01-15 12:19:09,491 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-01-15 12:19:09,491 INFO [EventDispatcher] Leaving EventDispatcher
2012-01-15 12:19:09,492 INFO [WebServer] WebServer shutting down
2012-01-15 12:19:09,492 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-01-15 12:19:09,639 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-01-15 12:19:10,206 INFO [DatabaseManager] Shutting down database
2012-01-15 12:19:13,113 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-16 16:37:35,924 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-16 16:37:35,986 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-16 16:37:35,986 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-16 16:37:35,986 INFO [MediaServer] http://www.serviio.org
2012-01-16 16:37:35,986 INFO [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2012-01-16 16:37:35,986 INFO [MediaServer] OS Windows Vista x86 6.0
2012-01-16 16:37:35,986 INFO [MediaServer] File encoding: windows-1252
2012-01-16 16:37:35,986 INFO [MediaServer] Headless mode enabled: true
2012-01-16 16:37:35,986 INFO [MediaServer] User home dir: C:\
2012-01-16 16:37:35,986 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-01-16 16:37:35,986 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-16 16:37:36,345 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-16 16:37:38,562 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-16 16:37:48,898 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-16 16:37:54,202 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-16 16:37:54,919 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-16 16:37:55,138 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-16 16:37:55,340 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-16 16:37:55,512 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-16 16:37:55,621 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-16 16:37:56,932 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-16 16:37:56,963 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-16 16:37:57,478 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-16 16:37:58,211 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-16 16:37:58,523 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-16 16:37:58,788 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-16 16:37:58,960 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-16 16:37:58,991 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-16 16:37:59,131 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-16 16:37:59,194 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-16 16:37:59,474 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-16 16:37:59,568 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-16 16:37:59,818 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-16 16:37:59,974 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-16 16:38:02,392 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-16 16:38:02,423 INFO [Device] Created UPnP Device with UUID: 845849ff-fb73-3682-9791-500c0f07784e, bound address: 192.168.1.68
2012-01-16 16:38:03,172 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-01-16 16:38:03,312 INFO [PluginCompilerThread] Started looking for plugins
2012-01-16 16:38:07,477 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-16 16:38:08,101 INFO [WebServer] WebServer starting on port 8895
2012-01-16 16:38:08,101 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-16 16:38:08,101 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-16 16:38:08,117 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-16 16:38:08,117 INFO [EventDispatcher] Starting EventDispatcher
2012-01-16 16:38:08,117 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-16 16:38:08,257 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net3 (Dell Wireless 1395 WLAN Mini-Card) and address 192.168.1.68, timeout = 0
2012-01-16 16:38:19,366 INFO [RendererManager] Stored a new renderer: uuid='34436589-7eb5-4238-aad3-ad4db04306f0', name = 'Unrecognized device', ipAddress='192.168.1.64', profile = '1'
2012-01-16 16:38:19,366 INFO [RendererManager] Stored a new renderer: uuid='2c28ecb8-6bfd-229b-5fd9-de995c0b13eb', name = 'UE46D7000', ipAddress='192.168.1.64', profile = '1'
2012-01-16 16:38:43,297 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-16 16:38:43,297 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-16 16:38:43,312 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-16 17:34:21,534 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-01-16 17:34:21,567 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-01-16 17:34:21,848 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-16 17:34:21,984 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-16 17:34:22,066 INFO [FeedUpdaterThread] Finished looking for online resources information
2012-01-16 17:34:22,225 INFO [PluginCompilerThread] Finished looking for plugins
2012-01-16 17:34:24,555 ERROR [IndexedDiskCache] Region [online_technical_metadata] Not alive and dispose was called, filename: online_technical_metadata
2012-01-16 17:34:24,586 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-01-16 17:34:27,067 INFO [WebServer] WebServer shutting down
2012-01-16 17:34:27,068 INFO [EventDispatcher] Leaving EventDispatcher
2012-01-16 17:34:27,068 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-01-16 17:34:28,343 INFO [DatabaseManager] Shutting down database
2012-01-16 17:34:28,526 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-01-16 17:34:35,155 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-16 18:47:03,506 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-16 18:47:03,537 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-16 18:47:03,552 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-16 18:47:03,552 INFO [MediaServer] http://www.serviio.org
2012-01-16 18:47:03,552 INFO [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2012-01-16 18:47:03,552 INFO [MediaServer] OS Windows Vista x86 6.0
2012-01-16 18:47:03,552 INFO [MediaServer] File encoding: windows-1252
2012-01-16 18:47:03,552 INFO [MediaServer] Headless mode enabled: true
2012-01-16 18:47:03,552 INFO [MediaServer] User home dir: C:\
2012-01-16 18:47:03,552 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-01-16 18:47:03,552 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-16 18:47:03,741 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-16 18:47:03,850 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-16 18:47:08,155 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-16 18:47:08,717 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-16 18:47:09,559 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-16 18:47:09,762 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-16 18:47:09,981 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-16 18:47:10,152 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-16 18:47:10,246 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-16 18:47:10,761 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-16 18:47:10,807 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-16 18:47:11,260 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-16 18:47:11,931 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-16 18:47:12,227 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-16 18:47:12,492 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-16 18:47:12,648 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-16 18:47:12,679 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-16 18:47:12,804 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-16 18:47:12,867 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-16 18:47:13,069 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-16 18:47:13,179 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-16 18:47:13,475 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-16 18:47:13,678 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-16 18:47:17,890 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-16 18:47:17,921 INFO [Device] Created UPnP Device with UUID: 845849ff-fb73-3682-9791-500c0f07784e, bound address: 192.168.1.68
2012-01-16 18:47:19,092 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-01-16 18:47:19,186 INFO [PluginCompilerThread] Started looking for plugins
2012-01-16 18:47:30,670 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-16 18:47:31,201 INFO [WebServer] WebServer starting on port 8895
2012-01-16 18:47:31,216 INFO [EventDispatcher] Starting EventDispatcher
2012-01-16 18:47:31,216 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-16 18:47:31,216 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-16 18:47:31,216 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-16 18:47:31,217 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-16 18:47:31,395 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net3 (Dell Wireless 1395 WLAN Mini-Card) and address 192.168.1.68, timeout = 0
2012-01-16 18:47:58,108 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-16 18:47:58,124 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-16 18:47:58,139 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-16 19:19:49,974 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-01-16 19:19:50,257 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-01-16 19:19:50,257 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-16 19:19:50,387 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-16 19:19:50,486 INFO [FeedUpdaterThread] Finished looking for online resources information
2012-01-16 19:19:50,586 INFO [PluginCompilerThread] Finished looking for plugins
2012-01-16 19:19:52,299 ERROR [IndexedDiskCache] Region [online_technical_metadata] Not alive and dispose was called, filename: online_technical_metadata
2012-01-16 19:19:52,463 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-01-16 19:19:52,517 INFO [WebServer] WebServer shutting down
2012-01-16 19:19:52,517 INFO [EventDispatcher] Leaving EventDispatcher
2012-01-16 19:19:52,517 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-01-16 19:19:53,472 INFO [DatabaseManager] Shutting down database
2012-01-16 19:19:56,245 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-01-16 19:19:58,243 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-17 09:02:22,985 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-17 09:02:23,047 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.1 (rev. c81bc5334890)
2012-01-17 09:02:23,047 INFO [MediaServer] Petr Nejedly 2009-2011
2012-01-17 09:02:23,047 INFO [MediaServer] http://www.serviio.org
2012-01-17 09:02:23,047 INFO [MediaServer] Java 1.6.0_24-Sun Microsystems Inc.
2012-01-17 09:02:23,047 INFO [MediaServer] OS Windows Vista x86 6.0
2012-01-17 09:02:23,047 INFO [MediaServer] File encoding: windows-1252
2012-01-17 09:02:23,047 INFO [MediaServer] Headless mode enabled: true
2012-01-17 09:02:23,047 INFO [MediaServer] User home dir: C:\
2012-01-17 09:02:23,047 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-01-17 09:02:23,047 INFO [MediaServer] ------------------------------------------------------------------------
2012-01-17 09:02:36,512 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-01-17 09:02:36,575 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-01-17 09:03:04,155 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-01-17 09:03:04,733 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-01-17 09:03:05,280 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-01-17 09:03:05,529 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-01-17 09:03:05,748 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-01-17 09:03:05,935 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-01-17 09:03:06,044 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-01-17 09:03:06,621 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-01-17 09:03:06,684 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-01-17 09:03:07,136 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-01-17 09:03:07,869 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-01-17 09:03:08,181 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-01-17 09:03:08,462 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-01-17 09:03:08,618 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-01-17 09:03:08,649 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-01-17 09:03:08,790 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-01-17 09:03:08,852 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-01-17 09:03:09,070 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-01-17 09:03:09,195 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-01-17 09:03:09,476 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-01-17 09:03:09,632 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-01-17 09:03:10,506 INFO [WebServer] Socket buffer set to 65535 bytes
2012-01-17 09:03:10,506 INFO [Device] Created UPnP Device with UUID: 845849ff-fb73-3682-9791-500c0f07784e, bound address: 192.168.1.68
2012-01-17 09:03:10,537 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2012-01-17 09:03:10,537 INFO [PluginCompilerThread] Started looking for plugins
2012-01-17 09:03:11,364 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-17 09:03:11,457 INFO [WebServer] WebServer starting on port 8895
2012-01-17 09:03:11,473 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-01-17 09:03:11,473 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-01-17 09:03:11,473 INFO [EventDispatcher] Starting EventDispatcher
2012-01-17 09:03:11,473 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-01-17 09:03:11,473 INFO [RendererSearchSender] Searching for Renderer devices
2012-01-17 09:03:11,534 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net3 (Dell Wireless 1395 WLAN Mini-Card) and address 192.168.1.68, timeout = 0
2012-01-17 09:03:38,072 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-01-17 09:03:38,072 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-01-17 09:03:38,087 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-01-17 09:04:28,462 INFO [ServiioConsole] Starting Serviio Console
2012-01-17 09:04:29,806 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-01-17 09:04:32,261 INFO [Messages] Loaded console message bundle for locale: en
2012-01-17 09:04:32,304 INFO [UpdateChecker] Checking if a new version is available
2012-01-17 09:04:53,280 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-01-17 09:04:54,052 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-01-17 09:07:04,777 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-01-17 09:07:04,777 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-01-17 09:07:04,778 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-01-17 09:07:04,876 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-01-17 09:07:04,976 INFO [FeedUpdaterThread] Finished looking for online resources information
2012-01-17 09:07:05,076 INFO [PluginCompilerThread] Finished looking for plugins
2012-01-17 09:07:05,176 INFO [WebServer] WebServer shutting down
2012-01-17 09:07:05,177 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-01-17 09:07:05,177 INFO [EventDispatcher] Leaving EventDispatcher
2012-01-17 09:07:05,177 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-01-17 09:07:06,483 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-01-17 09:07:07,840 INFO [DatabaseManager] Shutting down database
2012-01-17 09:07:08,120 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-01-17 09:07:09,432 INFO [ServiioConsole] Leaving Serviio Console
Post Tue Jan 17, 2012 12:52 pm
You are getting the following warning in your serviio.log file.
Do you know if there was a firmware update on your Samsung?
Can you try and get the device information and post it here (see signature).
You might be able to add the IP manually, pick the Samsung profile and save it. Restart serviio. I am not sure if this will work, but you can give it a try while we are figuring out what is going on.
andrewknight
Post Tue Jan 17, 2012 1:11 pm
Thank you very much.
I did try and add the IP of my TV manually but still with no luck.
Im not sure it is an issue around the TV as none of my devices are picked up by serviio anymore.
Prior to the upgrade I could see
My Samsung D7000 TV
My PS3
(and I think ???)
My Ipod Touch
My Wifes iPhone
There has been an update to Samsung to accomodate their NetFlix app here in the UK.
My PS3 has also had a firmware upgrade, so not sure if these upgrades are impacting the issue?
Really appreciate the work on this, I love Serviio and would be a massive shame to have to stop using it :cry:
Post Tue Jan 17, 2012 2:39 pm
Re: Samsung D7000 : Can't use Serviio since update
Have you verified that the ports on your computer are still open?
This could be caused by you having multiple IP addresses on the machine and Serviio binding to a wrong one. Insert IP address of the machine running Serviio into 'Bound IP address' field in Network Settings section in the console or pass system variable serviio.boundAddr including the IP address when starting the server.
Also make sure that TCP port 8895 and UDP 1900 are open in your firewall.
If you are on a Linux based OS, make sure you set up multicast routes properly.
If on Windows, you can push Serviio service down in starting order.
andrewknight
Post Tue Jan 17, 2012 3:00 pm
Sadly, yes I have seen that and followed it all.
Enetered the bound IP and ensured the ports are open.
Having uninstalled Serviio and reinstalled I get the same problem.
Would a fresh install resolve the above probelms anyway?
Post Tue Jan 17, 2012 3:37 pm
Yes, what I would do is uninstall serviio.
Delete the serviio directory
restart the computer
Re-download serviio and chech the MD5 hash
Install serviio.
Verify ports open
Verify hardware and software firewalls aer not blocking serviio.
verify IP address that serviio is connecting to.
Users browsing this forum: No registered users and 59 guests
