SONY BDP-S780 Config Profile (MKV,AVI,FLV OK!, WMV not OK!)
eclp
Post Thu Jan 26, 2012 10:34 am
I have a problem with wmv files. :(
All other videos play perfectly.
Some wmv trailers are not displayed on my TV. Others play poorly, to ever strong stutter.
The transcoding is off, everything plays natively. I would like to keep.
How and where can I edit my profiles.xml? I unfortunately do not understand and need your help.
It would be nice if someone answers the player has a Sony.
Is displayed, but plays very badly (stuttering strong):
Complete name                    : E:\Media\Eigene Videos\Trailer\star_trek.wmv
Format                           : Windows Media
File size                        : 122 MiB
Duration                         : 2mn 5s
Overall bit rate mode            : Variable
Overall bit rate                 : 8 142 Kbps
Maximum Overall bit rate         : 10.2 Mbps
Encoded date                     : UTC 2008-11-17 19:46:00.100
Format                           : VC-1
Format profile                   : MP@HL
Codec ID                         : WMV3
Codec ID/Info                    : Windows Media Video 9
Codec ID/Hint                    : WMV3
Description of the codec         : Windows Media Video 9 - Professional
Duration                         : 2mn 5s
Bit rate mode                    : Variable
Bit rate                         : 8 000 Kbps
Width                            : 1 920 pixels
Height                           : 800 pixels
Display aspect ratio             : 2.40:1
Frame rate                       : 29.970 fps
Bits/(Pixel*Frame)               : 0.174
Stream size                      : 120 MiB (98%)
NumberOfFrames                   : 3756
Format                           : WMA
Format version                   : Version 2
Codec ID                         : 161
Codec ID/Info                    : Windows Media Audio
Description of the codec         : Windows Media Audio 9.2 - 160 kbps, 44 kHz, stereo 1-pass CBR
Duration                         : 2mn 5s
Bit rate                         : 160 Kbps
Channel(s)                       : 2 channels
Sampling rate                    : 44.1 KHz
Bit depth                        : 16 bits
Stream size                      : 2.40 MiB (2%)
Will not be displayed:
Complete name                    : E:\Media\Eigene Videos\Trailer\Coral_Reef_Adventure_1080.wmv
File size                        : 103 MiB
Duration                         : 1mn 45s
Overall bit rate mode            : Constant
Overall bit rate                 : 8 177 Kbps
Maximum Overall bit rate         : 8 447 Kbps
Encoded date                     : UTC 2003-12-22 01:22:47.945
Format                           : VC-1
Codec ID                         : WMV3
Duration                         : 1mn 45s
Width                            : 1 440 pixels
Height                           : 1 080 pixels
Display aspect ratio             : 4:3
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.215
Stream size                      : 101 MiB (98%)
Language                         : English (US)
Format                           : WMA
Format profile                   : Pro
Codec ID                         : 162
Description of the codec         : Windows Media Audio 9 Professional - 384 kbps, 48 kHz, 5.1 channel 24 bit (A/V) 2-pass CBR
Duration                         : 1mn 45s
Bit rate                         : 384 Kbps
Channel(s)                       : 6 channels
Bit depth                        : 24 bits
Stream size                      : 4.83 MiB (5%)
Complete name                    : E:\Media\Eigene Videos\Trailer\Terminator TRL_1080.wmv
File size                        : 86.3 MiB
Duration                         : 1mn 2s
Overall bit rate                 : 11.6 Mbps
Maximum Overall bit rate         : 11.6 Mbps
Encoded date                     : UTC 2008-07-16 03:16:37.000
Writing application              : Flip4Mac WMV Export Component for QuickTime (Mac) 2204
Format                           : VC-1
Format profile                   : AP@L4
Codec ID                         : WMVA
Codec ID/Hint                    : WMV
Description of the codec         : Windows Media Video V9 Advanced - 1920 x 816, 23.97 fps, 8000 kbps (CBR)
Bit rate                         : 11.4 Mbps
Height                           : 816 pixels
Display aspect ratio             : 2.35:1
Frame rate mode                  : Variable
Nominal frame rate               : 23.976 fps
Format                           : WMA
Codec ID                         : 161
Description of the codec         : Windows Media Audio V9 Standard - 192 kbps, 44 kHz, 16 bit, Stereo (CBR)
Duration                         : 1mn 2s
Bit rate                         : 192 Kbps
Bit depth                        : 16 bits
Stream size                      : 1.43 MiB (2%)
Thank you for your help!
eclp
Post Fri Jan 27, 2012 4:21 pm
Re: SONY BDP-S780 Config Profile (MKV,AVI,FLV OK!, WMV not O
Does nobody have an idea? No answer possible?
Post Fri Jan 27, 2012 4:36 pm
yer dont use a shitty format like WMV for your files.
