[SOLVED] Sony KDL-32CX521 does not play video file
• Page 2 of 2 • 1, 2
Re: [SOLVED] Sony KDL-32CX521 does not play video file
I changed the Format profile: High@L5.1 to Format profile: High@L4.1
but the program says that you are using mediainfo Format profile: High@L5.1
video is playing just as bad.
what did I do wrong?
In this file I changed the profile from 5.1 to 4.1
but the file still plays poorly and with jerks
bitrate
peak 17000
average 10000
Unique ID : 253632266821990790702436291631929637403 (0xBECFCC3993434CD3A69D315EA79C3A1B)
Complete name : D:\ServerFolders\Torrent\Otpusk.po.obmenu.2006.x264.BDRip.720p.mkv
Format : Matroska
Format version : Version 1
File size : 7.77 GiB
Duration : 2h 15mn
Overall bit rate : 8 193 Kbps
Encoded date : UTC 2007-04-14 11:58:49
Writing application : mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 15mn
Bit rate : 7 745 Kbps
Width : 1 280 pixels
Height : 688 pixels
Display aspect ratio : 1.860
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.367
Stream size : 7.19 GiB (93%)
Writing library : x264 core 54 svn-614
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=7 / brdo=0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=0 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=240 / keyint_min=24 / scenecut=40(pre) / rc=2pass / bitrate=7745 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Language : English
Default : Yes
Forced : No
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 2h 15mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 435 MiB (5%)
Language : Russian
Default : Yes
Forced : No
bitrate
peak 17000
average 10000
Format : Matroska
Duration : 2h 15mn
Format : AVC
Duration : 2h 15mn
Height : 688 pixels
Color space : YUV
Bit depth : 8 bits
Language : English
Default : Yes
Forced : No
Format : AC-3
Codec ID : A_AC3
Duration : 2h 15mn
Bit rate : 448 Kbps
Bit depth : 16 bits
Language : Russian
Default : Yes
Forced : No
Good day guys
I could not ultimately change the profile, Level 5.1 -> 4.1
After the upgrade version 0.6 to version 1.0.1 revealed an old problem.
I can not watch AVI files, change the profile Bravia 2010 <-> Bravia 2011 does not help.
My TV - Sony KDL 40 EX 720 and Sony KDL 32 CX 521 with the latest firmware available.
When profile Bravia 2011 - the server responds the file format is not supported
When profile Bravia 2010 - AVI file plays, but the picture image is not full screen, but only in the center. This image does not get stretched to full screen using the power of television.
The total area of the screen image is not more than 1/3 of the screen.
What can be done?
What can be done?
lavvash wrote:After the upgrade version 0.6 to version 1.0.1 revealed an old problem.
What can be done?
It seems that you have US version of Sony Bravia TVs, could you confirm ?
Then, on serviio console, select manually "Sony Bravia TV (2011) - US" profile for your devices. (Serviio could not distinguish automatically US vs Europe model)
excellent
I think you want to change the profile name Bravia 2011US -> Bravia 2011 AVI
Thanks, avi files are played
