Samsung B Series TV - Online Feeds
JKJudgeX
Post Sat Feb 04, 2012 11:27 pm
I have added the Online Feeds into the Serviio console as maintained from the wiki, and put plugins in the plugins folder....
But, I cannot find any links to the feeds on my TV (A Samsung series B TV)... the "Online" folder is just always empty... I've rebooted, stopped and started the service, everything...
Nothing ever shows up, whether I put in one feed or all of the feeds listed in the wiki.
Does anyone know why I might be having this problem?
Thanks!
Post Sat Feb 04, 2012 11:52 pm
Re: Samsung B Series TV - Online Feeds
You need to trigger the log to display what is happening.
I haven't created a wiki entry yet on how to do that so here is the first draft:
First insert the following in
C:\Program Files\Serviio\config\log4j.xml
 <category name="org.serviio.library.online">
      <priority value="DEBUG"/>
   </category>
following this section:
  <category name="org.serviio">
      <priority value="INFO"/>
   </category>
Then Restart Serviio so the log is now in DEBUG mode and the Online Folders will reload
Then Check the log messages to see what Serviio did and post it here for help.
JKJudgeX
Post Sun Feb 05, 2012 2:29 am
I've done this and given an initial combing of the log file, but I don't see any errors directly. Am I correct that on my TV, I should be going to my DLNA server (Serviio), and going into video, and then Online, and I should see something there?
It's empty, no matter how many feeds I put in or if I call them atom/rss feeds or online sources, etc...
Is there anything specific I should look for in the log file? It says loading plugins, no errors, and then moves right along...
I've unzipped the plugin pack from this forum into my plugins directory...
Nothing. Any help would be appreciated, this sounds like an awesome feature.
Post Sun Feb 05, 2012 3:13 am
Two things:
It's also a good idea to verify that your Serviio setup can play a livestream before you attempt to use these folders, so first setup these sky and nhk news links as livestreams in Serviio as a test. If they won't play then ask elsewhere in the forum for help with your setup.
"mmsh://live1.wm.skynews.servecast.net/skynews_wmlz_live300k"
"rtmp://216.155.128.59:1935/2e2cd swfUrl=http://www3.nhk.or.jp/nhkworld/r/movie/fivecool_player.0.3.6.2.swf pageURL=http://www3.nhk.or.jp/nhkworld/r/movie/index.html playpath=nhkworldhd.sdp swfVfy=0 live=1"
JKJudgeX
Post Sun Feb 05, 2012 3:42 am
I've put those in, and nothing happens as a result...
Here's some of the log:
2012-02-04 02:26:37,531 INFO  [PluginCompilerThread] Added Feed plugin AnOriantUrlExtractor (AnOriant.groovy)
2012-02-04 02:26:37,640 INFO  [PluginCompilerThread] Added Feed plugin ARD Mediathek RSS Extractor (ARDMediathek.groovy)
2012-02-04 02:26:38,000 INFO  [PluginCompilerThread] Added Feed plugin Arte (Arte.groovy)
2012-02-04 02:26:38,125 INFO  [PluginCompilerThread] Added Feed plugin BlipTVUrlExtractor (BlipTVUrlExtractor.groovy)
2012-02-04 02:26:38,640 INFO  [PluginCompilerThread] Added Web Resouce plugin 4OD (UK only) (Channel4od.groovy)
2012-02-04 02:26:38,828 INFO  [PluginCompilerThread] Added Feed plugin CNN (CNN.groovy)
2012-02-04 02:26:38,875 INFO  [PluginCompilerThread] Added Feed plugin Crackle (Crackle.groovy)
2012-02-04 02:26:38,937 INFO  [PluginCompilerThread] Added Feed plugin DailyMotion (DailyMotion.groovy)
2012-02-04 02:26:39,015 INFO  [PluginCompilerThread] Added Web Resouce plugin Escapist (Escapist.groovy)
2012-02-04 02:26:39,062 INFO  [PluginCompilerThread] Added Feed plugin Gamespot (Gamespot.groovy)
2012-02-04 02:26:39,109 INFO  [PluginCompilerThread] Added Feed plugin GameTrailers (GameTrailers.groovy)
2012-02-04 02:26:39,203 INFO  [PluginCompilerThread] Added Feed plugin Gulli (Gulli.groovy)
2012-02-04 02:26:39,359 INFO  [PluginCompilerThread] Added Feed plugin Hulu (US only) (Hulu.groovy)
2012-02-04 02:26:39,421 INFO  [PluginCompilerThread] Added Feed plugin Hypem (Hypem.groovy)
2012-02-04 02:26:39,718 INFO  [PluginCompilerThread] Added Feed plugin BBC iPlayer (UK only) (IPlayer.groovy)
2012-02-04 02:26:39,781 INFO  [PluginCompilerThread] Added Feed plugin LiveFeeds (LiveFeeds.groovy)
2012-02-04 02:26:39,875 INFO  [PluginCompilerThread] Added Web Resouce plugin M6replay (M6replay.groovy)
2012-02-04 02:26:40,015 INFO  [PluginCompilerThread] Added Feed plugin MegavideoPlugin (MegavideoPlugin.groovy)
2012-02-04 02:26:40,046 INFO  [PluginCompilerThread] Added Feed plugin Orf (Orf.groovy)
2012-02-04 02:26:40,093 INFO  [PluginCompilerThread] Added Feed plugin Packers (Packers.groovy)
2012-02-04 02:26:40,359 INFO  [PluginCompilerThread] Added Feed plugin PennyArcade (PennyArcade.groovy)
2012-02-04 02:26:40,453 INFO  [PluginCompilerThread] Added Feed plugin Pluzz (Pluzz.groovy)
2012-02-04 02:26:40,500 INFO  [PluginCompilerThread] Added Feed plugin ReutersCom (ReutersCom.groovy)
2012-02-04 02:26:40,562 INFO  [PluginCompilerThread] Added Feed plugin RTVE (RTVE.groovy)
2012-02-04 02:26:40,625 INFO  [PluginCompilerThread] Added Feed plugin SC2CastUrlExctractor (SC2Casts.groovy)
2012-02-04 02:26:40,687 INFO  [PluginCompilerThread] Added Web Resouce plugin Shoutcast (Shoutcast.groovy)
2012-02-04 02:26:40,718 INFO  [PluginCompilerThread] Added Feed plugin SnotrUrlExtractor (Snotr.groovy)
2012-02-04 02:26:40,781 INFO  [PluginCompilerThread] Added Feed plugin SvtPlay (SvtPlay.groovy)
2012-02-04 02:26:40,875 INFO  [PluginCompilerThread] Added Feed plugin TF1 (TF1.groovy)
2012-02-04 02:26:40,953 INFO  [PluginCompilerThread] Added Web Resouce plugin Tune In (TuneIn.groovy)
2012-02-04 02:26:41,015 INFO  [PluginCompilerThread] Added Feed plugin Tv3Play (Tv3Play.groovy)
2012-02-04 02:26:41,078 INFO  [PluginCompilerThread] Added Feed plugin Tv4Play (Tv4Play.groovy)
2012-02-04 02:26:41,109 INFO  [PluginCompilerThread] Added Feed plugin Tv6Play (Tv6Play.groovy)
2012-02-04 02:26:41,156 INFO  [PluginCompilerThread] Added Feed plugin Tv8Play (Tv8Play.groovy)
2012-02-04 02:26:41,421 INFO  [PluginCompilerThread] Added Feed plugin Vimeo (Vimeo.groovy)
2012-02-04 02:26:41,468 INFO  [PluginCompilerThread] Added Web Resouce plugin W9replay (W9replay.groovy)
2012-02-04 02:26:41,531 INFO  [PluginCompilerThread] Added Feed plugin WAT (WAT.groovy)
2012-02-04 02:26:41,578 INFO  [PluginCompilerThread] Added Feed plugin WimpCom (WimpCom.groovy)
2012-02-04 02:26:41,671 INFO  [PluginCompilerThread] Added Feed plugin Yahoo Movies (YahooMovies.groovy)
2012-02-04 02:26:41,765 INFO  [PluginCompilerThread] Added Feed plugin YouTube (Youtube.groovy)
Then a bit later, this:
2012-02-04 02:27:01,578 INFO  [FeedUpdaterThread] Started looking for information about online resources
But it never comes back and says anything else about that...
No warnings or errors to speak of, and nothing in the online folders...
Post Sun Feb 05, 2012 3:44 am
after you added the debug section did you restart serviio to actiavte it ?
JKJudgeX
Post Sun Feb 05, 2012 3:46 am
Cerberus wrote:after you added the debug section did you restart serviio to actiavte it ?
Yes... saved the file, hopped over to serviio console, stopped, started.
Post Sun Feb 05, 2012 3:48 am
Then forget about the Live feed folders and work out why your standalone live streams will not play.
JKJudgeX
Post Sun Feb 05, 2012 3:56 am
Well that's what I was asking about... I'm totally lost... been messing around in these forums since last night, and nothing is really helping, which is why I started the thread.
Am I incorrect about how to access them on a samsung B-series? You choose your DLNA server, choose "movie", choose "video" folder, and then something should appear in the "Online" folder? Or am I completely in the wrong place?
Post Sun Feb 05, 2012 4:01 am
your in the right place, will look into this shortly for you.
please attach your full log file to this thread and run FFmpeg -i on one of the feed urls
