DTS transcoding with LG 47LD690
tom619
Post Sat Feb 04, 2012 12:50 am
Hello everyone
relative newbie and Im having trouble watching any mkv's that are DTS encoded.
I've tried checking downmix to stero but i still get 'unsupported audio format' message on my tv.
Im using LG TV/Player profile.
Post Sun Feb 05, 2012 12:54 pm
Re: DTS transcoding with LG 47LD690
Make sure you have the latest firmware. If yes try adding this to the LG profile:
Post Sun Feb 05, 2012 8:24 pm
can you please provide FFmpeg -i readout for this file (see signiture for howto) as i have a feeling i know whats causing this.
tom619
Post Tue Feb 07, 2012 4:06 pm
Petr, do I add your lines of code, to the LG Profile like so.
<Profile id="8" name="LG TV / player" extendsProfileId="1">
      <Detection>
         <HttpHeaders>
            <friendlyName.dlna.org>LG.*</friendlyName.dlna.org>
         </HttpHeaders>
      </Detection>
      <MediaFormatProfiles>
         <MediaFormatProfile mime-type="video/mp4" name="">AVI</MediaFormatProfile>
      </MediaFormatProfiles>
      Transcoding doesn't seem to work and some files can be played natively:
      http://forum.serviio.org/viewtopic.php?f=12&t=3914#p26273
         <Video targetContainer="mpegts" targetACodec="mp3">
            <Matches container="matroska" aCodec="ac3" />
      </Transcoding> -->
tom619
Post Tue Feb 07, 2012 10:50 pm
I havent yet updated profile but this is the ffmpeg readout:
*v*t*r.2009.1080p.BluRay.X264-AMIABLE...iHD...mkv"
nfig
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/
1001) -> 48.00 (48/1)
Input #0, matroska,webm, from ******************************A*a*
a*.2009.1080p.BluRay.X264-AMIABLE...iHD...mkv':
  Duration: 02:41:41.65, start: 0.000000, bitrate: 9674 kb/s
    Chapter #0.0: start 0.000000, end 377.961000
      title           : 00:00:00.000
    Chapter #0.1: start 377.961000, end 473.598000
      title           : 00:06:17.961
    Chapter #0.2: start 473.598000, end 724.891000
      title           : 00:07:53.598
    Chapter #0.3: start 724.891000, end 840.465000
      title           : 00:12:04.891
    Chapter #0.4: start 840.465000, end 1200.574000
      title           : 00:14:00.465
    Chapter #0.5: start 1200.574000, end 1440.230000
      title           : 00:20:00.574
    Chapter #0.6: start 1440.230000, end 1613.278000
      title           : 00:24:00.230
    Chapter #0.7: start 1613.278000, end 1901.900000
      title           : 00:26:53.278
    Chapter #0.8: start 1901.900000, end 2013.428000
      title           : 00:31:41.900
    Chapter #0.9: start 2013.428000, end 2143.850000
      title           : 00:33:33.428
    Chapter #0.10: start 2143.850000, end 2611.859000
      title           : 00:35:43.850
    Chapter #0.11: start 2611.859000, end 2963.627000
      title           : 00:43:31.859
    Chapter #0.12: start 2963.627000, end 3269.975000
      title           : 00:49:23.627
    Chapter #0.13: start 3269.975000, end 3596.051000
      title           : 00:54:29.975
    Chapter #0.14: start 3596.051000, end 3910.198000
      title           : 00:59:56.051
    Chapter #0.15: start 3910.198000, end 4296.417000
      title           : 01:05:10.198
    Chapter #0.16: start 4296.417000, end 4511.006000
      title           : 01:11:36.417
    Chapter #0.17: start 4511.006000, end 4829.116000
      title           : 01:15:11.006
    Chapter #0.18: start 4829.116000, end 5081.910000
      title           : 01:20:29.116
    Chapter #0.19: start 5081.910000, end 5764.801000
      title           : 01:24:41.910
    Chapter #0.20: start 5764.801000, end 5875.786000
      title           : 01:36:04.801
    Chapter #0.21: start 5875.786000, end 6273.100000
      title           : 01:37:55.786
    Chapter #0.22: start 6273.100000, end 6495.489000
      title           : 01:44:33.100
    Chapter #0.23: start 6495.489000, end 6833.868000
      title           : 01:48:15.489
    Chapter #0.24: start 6833.868000, end 6932.884000
      title           : 01:53:53.868
    Chapter #0.25: start 6932.884000, end 7118.820000
      title           : 01:55:32.884
    Chapter #0.26: start 7118.820000, end 7325.568000
      title           : 01:58:38.820
    Chapter #0.27: start 7325.568000, end 7533.859000
      title           : 02:02:05.568
    Chapter #0.28: start 7533.859000, end 7801.835000
      title           : 02:05:33.859
    Chapter #0.29: start 7801.835000, end 8167.284000
      title           : 02:10:01.835
    Chapter #0.30: start 8167.284000, end 8390.841000
      title           : 02:16:07.284
    Chapter #0.31: start 8390.841000, end 8750.325000
      title           : 02:19:50.841
    Chapter #0.32: start 8750.325000, end 9074.065000
      title           : 02:25:50.325
    Chapter #0.33: start 9074.065000, end 9305.296000
      title           : 02:31:14.065
    Chapter #0.34: start 9305.296000, end 9701.651000
      title           : 02:35:05.296
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x1080, SAR 1:1 DAR 16:9,
23.98 fps, 48 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), s16, 1536 kb/s (def
ault)
      title           : English DTS 1509kbps
    Stream #0:2(eng): Subtitle: text (forced)
Post Tue Feb 07, 2012 11:02 pm
ok so yes ZIP solution will work fine :) can you post the whole LG profile and i will do the edit for you so u can copy it :)
tom619
Post Tue Feb 07, 2012 11:06 pm
Added to LG Profile like so:
      <Detection>
         <HttpHeaders>
         </HttpHeaders>
      </Detection>
      </Transcoding> -->
Still no joy with DTS .mkvs can play video but no sound.
Help! :)
Post Tue Feb 07, 2012 11:12 pm
Yer that wont work you have edited it slightly wrong here is the correct profile. ;)
      <Detection>
         <HttpHeaders>
         </HttpHeaders>
      </Detection>
      <!-- Transcoding doesn't seem to work and some files can be played natively: -->
         <!-- Remux AC3/DCA in MKV to MP3 -->
tom619
Post Tue Feb 07, 2012 11:16 pm
Ok so Ive updated the LG profile. To take effect I just restart serviio from "services" right?
Post Tue Feb 07, 2012 11:20 pm
tom619 wrote:Ok so Ive updated the LG profile. To take effect I just restart serviio from "services" right?
yes or just restart the pc running serviio :)
tom619
Post Tue Feb 07, 2012 11:21 pm
ok brb!
tom619
Post Tue Feb 07, 2012 11:44 pm
Nope no joy, now it wont even play .mkvs at all! Just double check the profile will ya?
            <Detection>
                   <HttpHeaders>
                   </HttpHeaders>
                  </Detection>
Post Wed Feb 08, 2012 1:24 am
well thats a shame it wont even let us remux files for LG, nothing i can do then sorry.
Post Wed Feb 08, 2012 1:38 pm
LG in most cases screwes up when playing transcoded files via Serviio, that's why I removed the transcoding config from the profile. It seems some can play it but most won't. Not sure about models or firmwares. Your best bet now is to transcode audio manually to ac3 and play it then with the original profile.
tom619
Post Wed Feb 08, 2012 11:16 pm
Ok, what is the best way to transcode audio manually?
MaddMan
Post Mon Nov 26, 2012 8:13 pm
Cerberus wrote:Yer that wont work you have edited it slightly wrong here is the correct profile. ;)
      <Detection>
         <HttpHeaders>
         </HttpHeaders>
      </Detection>
This worked perfectly for the 47CM565 I bought on Saturday. I just completely replaced the LG profile with this, saved, restarted service, and saved the profile in console.
j0rd4n
Post Sun Mar 03, 2013 8:59 pm
with the new serviio version it doesnt work.
can someone create a new profile for new serviio version 1.2 for our not supporting dts lg tv?
Post Sun Mar 03, 2013 11:48 pm
      <Detection>
         <HttpHeaders>
         </HttpHeaders>
      </Detection>
      <!-- ResourceTransportProtocolHandler>org.serviio.upnp.protocol.http.transport.LGProtocolHandler</ResourceTransportProtocolHandler -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" >
            <Matches container="flv" />
               <Matches container="asf" vCodec="wmv2"/>
               <Matches container="rm" />
      <Subtitles>
         <SoftSubs mime-type="text/srt" />
      </Subtitles>
j0rd4n
Post Mon Mar 04, 2013 6:10 pm
thank you very much it works :)
Eugen1968
Post Mon Mar 04, 2013 7:27 pm
I have a problem with this settings. Transcoding not works well for my 32LM611S.
This settings works for sample file but not works for entire file.
- the sample have : 107 Mb
- the file have : 16,088 Mb
Return to LG
