problem with panasonic TX-P42GT20E
erikblade
Post Mon Feb 06, 2012 10:07 pm
hi:
i have a problem with my tv an some avi files.
first say that the list of devices never appeared to me my TV with the green dot.
point has always been red and near the point puts panasonic viera but the movies are well reproduced.
until now had not had any problems with the movies but I've realized that having a size of 352x288 I get an error message "file not supported"
instead they are with any other resolution are reproduced without problems.
can help me with this problem?
need to configure something?
thanks
the tv is Panasonic Viera TX-42GT20E
all my video files are avi an with XVID5 codec
Post Mon Feb 06, 2012 10:19 pm
Re: problem with panasonic TX-P42GT20E
1. Please provide information on the file that will not play (howto in signiture)
2. Please provide support information on your device ? (howto in signiture)
3. Which profile are you testing with ? (default or new modified)
erikblade
Post Mon Feb 06, 2012 10:24 pm
i am not at home now so i can´t obtain that information now but as soon as i go home i´ll post that
erikblade
Post Tue Feb 07, 2012 2:45 pm
well with upnp tools i can´t obtain anything so i post the results of the other option:
REG07614065.pdf
this is the tv information
(96.55 KiB) Downloaded 764 times
and for the file information:
Nuevo Documento de texto.txt
file information
(833 Bytes) Downloaded 850 times
in case of it´ll be insuficient i post the mediainfo
Destino final -2.avi.txt
mediainfo
(5.49 KiB) Downloaded 829 times
abaut the profile, i usually use the panasonic viera profile.
note that only happens with movies whose dimension is 352x288 the rest are perfectly played
thanks
Post Tue Feb 07, 2012 5:59 pm
erikblade wrote:first say that the list of devices never appeared to me my TV with the green dot.
thats normal as it doesnt support UPNP search so serviio doesnt know if its on or off
we can possibley force a resolution for all movies but thats abit of overkill and your best bet is to reencode the failing ones in a new Res or get them from different source.
yep that would make sense, and would confirm what i said above.
erikblade
Post Tue Feb 07, 2012 7:55 pm
well
have been reviewing and comparing files that did not breed with which they would reproduce and I realized that the problem was the codec used for tomorrow will try to recode some files to another codec.
I have come to this conclusion because if there is any 352x288 sized movie that plays well.
proves to recode with another codec and I will comment to see how it turns out.
on the other hand, the point in red has no importance, hasn´t it?
Post Tue Feb 07, 2012 8:22 pm
erikblade wrote:well
nope fact is red is meaning less fro a user point of view. :)
Return to Panasonic
