IPTV unicast
alex6600
Post Mon Feb 13, 2012 3:25 pm
IPTV unicast
Hi.
Try to view iptv unicast stream from provider (TV broadcasting by mumudvb).
But nothing.
java.io.IOException: Cannot parse resource from http://172.31.1.8:7204. Message: No plugin for web resource http://172.31.1.8:7204 has been found.
        at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:177)
        at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:184)
        at org.serviio.library.online.metadata.FeedUpdaterThread.getOnlineItems(FeedUpdaterThread.java:158)
        at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:95)
Post Mon Feb 13, 2012 4:24 pm
Re: IPTV unicast
Select Live stream as the online resource type
alex6600
Post Mon Feb 13, 2012 8:45 pm
Re: IPTV unicast
Thanks!
Now I can see name this stream in playlist in player's online folder (Sony BDP-370), but can't play it.
Sony say that stream is m2ts.
Vlc in PC shows Video codeck is MPEG-1/2 (mpgv),Audio codeck is MPEG Layer 1/2/3 (mpga).
Post Mon Feb 13, 2012 9:16 pm
Re: IPTV unicast
post detailed log of the playback
alex6600
Post Mon Feb 13, 2012 9:52 pm
Re: IPTV unicast
In attacment- media information in vlc.
PS.In more detailed log output ("DEBUG") :
2012-02-14 00:11:11,510 DEBUG [WebServer] Incoming connection from /192.168.1.6:56745
2012-02-14 00:11:11,607 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1000000000070001/MEDIA_ITEM/MPEG_TS_SD_NA_ISO*0 HTTP/1.1, headers = [Host: 192.168.1.1:8895,Accept: */*,getcontentFeatures.dlna.org: 1,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0"]]
2012-02-14 00:11:11,608 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.6
2012-02-14 00:11:11,609 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.6, Profile=Sony BD Player / SMP'
2012-02-14 00:11:11,610 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000070001 and type 'MEDIA_ITEM' received
2012-02-14 00:11:11,610 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000070001 (online)
2012-02-14 00:11:11,611 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2012-02-14 00:11:11,613 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000070001, format MPEG_TS_SD_NA_ISO and profile Sony BD Player / SMP
2012-02-14 00:11:11,613 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-02-14 00:11:11,614 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Mon, 13 Feb 2012 22:11:11 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-02-14 00:11:11,621 DEBUG [ResourceTransportRequestHandler] GET /resource/1000000000070001/MEDIA_ITEM/MPEG_TS_SD_NA_ISO*0 HTTP/1.1, headers = [Host: 192.168.1.1:8895,Accept: */*,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0"]]
2012-02-14 00:11:11,622 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.6
2012-02-14 00:11:11,626 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.6, Profile=Sony BD Player / SMP'
2012-02-14 00:11:11,627 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000070001 and type 'MEDIA_ITEM' received
2012-02-14 00:11:11,629 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000070001 (online)
2012-02-14 00:11:11,629 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2012-02-14 00:11:11,635 DEBUG [VideoDeliveryEngine] Delivering item '1000000000070001' for client 'IPAddress=/192.168.1.6, Profile=Sony BD Player / SMP'
2012-02-14 00:11:11,635 DEBUG [VideoDeliveryEngine] Delivering file 'http://172.31.1.8:7101/' in native format
2012-02-14 00:11:11,636 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2012-02-14 00:11:11,637 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-02-14 00:11:11,637 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Mon, 13 Feb 2012 22:11:11 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-02-14 00:11:11,638 DEBUG [OnlineInputStream] Reading 1512000 bytes starting at 0
2012-02-14 00:11:11,655 DEBUG [OnlineInputStream] Byte range not supported for http://172.31.1.8:7101/, returning the whole stream
2012-02-14 00:11:11,986 DEBUG [WebServer] Incoming connection from /192.168.1.6:56746
2012-02-14 00:11:12,034 DEBUG [WebServer] I/O error: Broken pipe
2012-02-14 00:11:12,034 DEBUG [OnlineInputStream] Closing stream
2012-02-14 00:11:12,084 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1000000000070001/MEDIA_ITEM/MPEG_TS_SD_NA_ISO*0 HTTP/1.1, headers = [Host: 192.168.1.1:8895,Accept: */*,getcontentFeatures.dlna.org: 1,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0"]]
2012-02-14 00:11:12,085 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.6
2012-02-14 00:11:12,087 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.6, Profile=Sony BD Player / SMP'
2012-02-14 00:11:12,088 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000070001 and type 'MEDIA_ITEM' received
2012-02-14 00:11:12,088 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000070001 (online)
2012-02-14 00:11:12,088 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2012-02-14 00:11:12,091 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000070001, format MPEG_TS_SD_NA_ISO and profile Sony BD Player / SMP
2012-02-14 00:11:12,091 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-02-14 00:11:12,092 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Mon, 13 Feb 2012 22:11:12 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-02-14 00:11:12,104 DEBUG [ResourceTransportRequestHandler] GET /resource/1000000000070001/MEDIA_ITEM/MPEG_TS_SD_NA_ISO*0 HTTP/1.1, headers = [Host: 192.168.1.1:8895,Accept: */*,getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0"]]
2012-02-14 00:11:12,105 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.6
2012-02-14 00:11:12,106 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.6, Profile=Sony BD Player / SMP'
2012-02-14 00:11:12,107 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000070001 and type 'MEDIA_ITEM' received
2012-02-14 00:11:12,107 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000070001 (online)
2012-02-14 00:11:12,108 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2012-02-14 00:11:12,110 DEBUG [VideoDeliveryEngine] Delivering item '1000000000070001' for client 'IPAddress=/192.168.1.6, Profile=Sony BD Player / SMP'
2012-02-14 00:11:12,110 DEBUG [VideoDeliveryEngine] Delivering file 'http://172.31.1.8:7101/' in native format
2012-02-14 00:11:12,111 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2012-02-14 00:11:12,112 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-02-14 00:11:12,112 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Mon, 13 Feb 2012 22:11:12 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-02-14 00:11:12,113 DEBUG [OnlineInputStream] Reading 1512000 bytes starting at 0
2012-02-14 00:11:12,128 DEBUG [OnlineInputStream] Byte range not supported for http://172.31.1.8:7101/, returning the whole stream
2012-02-14 00:11:43,095 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-02-14 00:11:43,095 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-02-14 00:11:43,097 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2012-02-14 00:11:43,099 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 9)
2012-02-14 00:11:43,101 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 10)
2012-02-14 00:11:43,103 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 11)
2012-02-14 00:11:43,105 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 12)
2012-02-14 00:11:54,835 DEBUG [WebServer] I/O error: Broken pipe
2012-02-14 00:11:54,835 DEBUG [OnlineInputStream] Closing stream
Serviio 0.6.2 running on Centos Linux.
Post Tue Feb 14, 2012 1:01 pm
Re: IPTV unicast
can you post results of
ffmpeg -i http://172.31.1.8:7101/
alex6600
Post Tue Feb 14, 2012 9:19 pm
Re: IPTV unicast
zip wrote:can you post results of
FFmpeg version 0.6.5, Copyright (c) 2000-2010 the FFmpeg developers
  built on Jan 29 2012 17:52:15 with gcc 4.4.5 20110214 (Red Hat 4.4.5-6)
  configuration: --prefix=/usr --libdir=/usr/lib64 --shlibdir=/usr/lib64 --mandi        r=/usr/share/man --incdir=/usr/include --disable-avisynth --extra-cflags='-O2 -g        -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-        buffer-size=4 -m64 -mtune=generic -fPIC' --enable-avfilter --enable-avfilter-lav        f --enable-libdc1394 --enable-libdirac --enable-libfaac --enable-libfaad --enabl        e-libfaadbin --enable-libgsm --enable-libmp3lame --enable-libopencore-amrnb --en        able-libopencore-amrwb --enable-librtmp --enable-libschroedinger --enable-libspe        ex --enable-libtheora --enable-libx264 --enable-gpl --enable-nonfree --enable-po        stproc --enable-pthreads --enable-shared --enable-swscale --enable-vdpau --enabl        e-version3 --enable-x11grab
  libavutil     50.15. 1 / 50.15. 1
  libavcodec    52.72. 2 / 52.72. 2
  libavformat   52.64. 2 / 52.64. 2
  libavdevice   52. 2. 0 / 52. 2. 0
  libavfilter    1.19. 0 /  1.19. 0
  libswscale     0.11. 0 /  0.11. 0
  libpostproc   51. 2. 0 / 51. 2. 0
[mpeg2video @ 0x2053ae0]mpeg_decode_postinit() failure
    Last message repeated 6 times
[mpegts @ 0x2038670]max_analyze_duration reached
[mpegts @ 0x2038670]Estimating duration from bitrate, this may be inaccurate
Input #0, mpegts, from 'http://172.31.1.8:7101/':
  Duration: N/A, start: 58136.414789, bitrate: 15128 kb/s
  Program 6500 Emmanuel
      provider_name   : Svitle Radio
  Program 6507 1079
      provider_name   :
  Program 6510 NEWS ONE
      provider_name   : News One
  Program 6520 1 Auto
      provider_name   : Svit TV
    Stream #0.0[0x1979]: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], 15000 kb/s, 26.02 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0.1[0x197a](ukr): Audio: mp2, 48000 Hz, 2 channels, s16, 128 kb/s
  Program 6530 RU MUSIC
      provider_name   : RU Music
  Program 6540 Ukrainian Fashion
      provider_name   : Ukrainian Fashion
  Program 6545 A-One UA
      provider_name   : A-One
  Program 6555 Dobro TV
      provider_name   : Dobro TV
  Program 6560 Star TV UKR
      name            : Star TV UKR
      provider_name   : Star TV UKR
  Program 6565 PogodaTV
      provider_name   : PogodaTV
  Program 6575 ENGLISH CLUB TV
      name            : ENGLISH CLUB TV
      provider_name   : ENGLISH CLUB
  Program 6580 Business
      provider_name   : TV-100
  Program 6585 YHT
      provider_name   : Ukrainian People's TV
  Program 6590 SHOPping TV
      provider_name   : SHOPping TV
Post Tue Feb 14, 2012 9:24 pm
Re: IPTV unicast
you can try to add this to the generic profile's OnlineTranscoding
<Video targetContainer="mpegts" forceInheritance="true">
  <Matches container="mpegts"/>
alex6600
Post Wed Feb 15, 2012 8:54 am
Re: IPTV unicast
zip wrote:you can try to add this to the generic profile's OnlineTranscoding
Did you mean add in section?
<------><Profile id="1" name="Generic DLNA profile">
But section exist:
<Matches container="mp4"/>
<Matches container="flv" vCodec="h264"/>
<Matches container="applehttp" vCodec="h264"/><>
Replace it?
Post Wed Feb 15, 2012 9:48 am
Re: IPTV unicast
Could you also update your FFMPEG program ?
alex6600
Post Wed Feb 15, 2012 11:15 am
Re: IPTV unicast
Illico wrote:Could you also update your FFMPEG program ?
0.6.5 in official centos 6.2 repo.
On ffmpeg site 0.10 is the last on major release.
Install 0.10? Or any different version?
Post Wed Feb 15, 2012 11:25 am
Re: IPTV unicast
Note sure to understand...what is your OS?
The official FFmpeg version used by Serviio 0.6.2 is : 0.9
But you can try with latest FFmpeg version
alex6600
Post Wed Feb 15, 2012 11:41 am
Re: IPTV unicast
Illico wrote:Note sure to understand...what is your OS?
Centos 6.2.
In centos repository last version of ffmpeg is 0.6.5.
Ok. Try to install 0.9. Thanks!
alex6600
Post Wed Feb 15, 2012 10:30 pm
Re: IPTV unicast
I update ffmpeg.
Put Zip's changes to config file. But nothing :(
Here is the log file:
2012-02-16 00:28:23,374 DEBUG [WebServer] Incoming connection from /192.168.1.5:56158
2012-02-16 00:28:23,472 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1000000000070001/MEDIA_ITEM/MPEG_TS_SD_NA_ISO*0 HTTP/1.1, headers = [Host: 192.168.1.1:8895,Accept: */*,getcontentFeatures.dlna.org: 1,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0"]]
2012-02-16 00:28:23,472 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2012-02-16 00:28:23,473 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.5, Profile=Sony BD Player / SMP'
2012-02-16 00:28:23,474 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000070001 and type 'MEDIA_ITEM' received
2012-02-16 00:28:23,474 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000070001 (online)
2012-02-16 00:28:23,474 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2012-02-16 00:28:23,476 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000070001, format MPEG_TS_SD_NA_ISO and profile Sony BD Player / SMP
2012-02-16 00:28:23,476 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://172.31.1.8:7101/
2012-02-16 00:28:23,477 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_EU_ISO
2012-02-16 00:28:23,477 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_NA_ISO
2012-02-16 00:28:23,477 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_KO_ISO
2012-02-16 00:28:23,478 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-02-16 00:28:23,478 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Wed, 15 Feb 2012 22:28:23 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-02-16 00:28:23,483 DEBUG [ResourceTransportRequestHandler] GET /resource/1000000000070001/MEDIA_ITEM/MPEG_TS_SD_NA_ISO*0 HTTP/1.1, headers = [Host: 192.168.1.1:8895,Accept: */*,getcontentFeatures.dlna.org: 1,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0"]]
2012-02-16 00:28:23,483 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2012-02-16 00:28:23,485 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.5, Profile=Sony BD Player / SMP'
2012-02-16 00:28:23,485 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000070001 and type 'MEDIA_ITEM' received
2012-02-16 00:28:23,486 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000070001 (online)
2012-02-16 00:28:23,486 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2012-02-16 00:28:23,488 DEBUG [VideoDeliveryEngine] Delivering item '1000000000070001' for client 'IPAddress=/192.168.1.5, Profile=Sony BD Player / SMP'
2012-02-16 00:28:23,488 DEBUG [VideoDeliveryEngine] Delivering file 'http://172.31.1.8:7101/' using transcoding
2012-02-16 00:28:23,489 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.5, Profile=Sony BD Player / SMP'
2012-02-16 00:28:23,490 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: http://172.31.1.8:7101/
2012-02-16 00:28:23,490 DEBUG [ProcessExecutor] Starting ffmpeg -i http://172.31.1.8:7101/ -y -async 1 -vcodec copy -copyts -acodec copy -map 0:0 -map 0:1 -sn -f mpegts pipe:
2012-02-16 00:28:28,991 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_EU_ISO
2012-02-16 00:28:28,992 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_NA_ISO
2012-02-16 00:28:28,992 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_KO_ISO
2012-02-16 00:28:28,992 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2012-02-16 00:28:28,992 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-02-16 00:28:28,993 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-02-16 00:28:28,993 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Wed, 15 Feb 2012 22:28:28 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-02-16 00:28:29,000 DEBUG [WebServer] I/O error: Broken pipe
2012-02-16 00:28:29,006 DEBUG [WebServer] Incoming connection from /192.168.1.5:56159
2012-02-16 00:28:29,103 DEBUG [ResourceTransportRequestHandler] GET /resource/1000000000070001/MEDIA_ITEM/MPEG_TS_SD_NA_ISO*0 HTTP/1.1, headers = [Host: 192.168.1.1:8895,Accept: */*,getcontentFeatures.dlna.org: 1,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0"]]
2012-02-16 00:28:29,103 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2012-02-16 00:28:29,105 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.5, Profile=Sony BD Player / SMP'
2012-02-16 00:28:29,106 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000070001 and type 'MEDIA_ITEM' received
2012-02-16 00:28:29,106 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000070001 (online)
2012-02-16 00:28:29,106 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2012-02-16 00:28:29,108 DEBUG [VideoDeliveryEngine] Delivering item '1000000000070001' for client 'IPAddress=/192.168.1.5, Profile=Sony BD Player / SMP'
2012-02-16 00:28:29,109 DEBUG [VideoDeliveryEngine] Delivering file 'http://172.31.1.8:7101/' using transcoding
2012-02-16 00:28:29,109 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.5, Profile=Sony BD Player / SMP'
2012-02-16 00:28:30,110 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_EU_ISO
2012-02-16 00:28:30,110 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_NA_ISO
2012-02-16 00:28:30,110 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_KO_ISO
2012-02-16 00:28:30,110 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2012-02-16 00:28:30,110 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-02-16 00:28:30,111 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-02-16 00:28:30,111 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Wed, 15 Feb 2012 22:28:30 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-02-16 00:28:30,313 DEBUG [WebServer] I/O error: Broken pipe
2012-02-16 00:28:30,320 DEBUG [WebServer] Incoming connection from /192.168.1.5:56160
2012-02-16 00:28:30,418 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1000000000070001/MEDIA_ITEM/MPEG_TS_SD_NA_ISO*0 HTTP/1.1, headers = [Host: 192.168.1.1:8895,Accept: */*,getcontentFeatures.dlna.org: 1,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0"]]
2012-02-16 00:28:30,418 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2012-02-16 00:28:30,419 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.5, Profile=Sony BD Player / SMP'
2012-02-16 00:28:30,420 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000070001 and type 'MEDIA_ITEM' received
2012-02-16 00:28:30,420 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000070001 (online)
2012-02-16 00:28:30,420 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2012-02-16 00:28:30,424 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000000070001, format MPEG_TS_SD_NA_ISO and profile Sony BD Player / SMP
2012-02-16 00:28:30,424 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file http://172.31.1.8:7101/
2012-02-16 00:28:30,424 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_EU_ISO
2012-02-16 00:28:30,424 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_NA_ISO
2012-02-16 00:28:30,425 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_KO_ISO
2012-02-16 00:28:30,425 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-02-16 00:28:30,426 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Wed, 15 Feb 2012 22:28:30 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-02-16 00:28:30,432 DEBUG [ResourceTransportRequestHandler] GET /resource/1000000000070001/MEDIA_ITEM/MPEG_TS_SD_NA_ISO*0 HTTP/1.1, headers = [Host: 192.168.1.1:8895,Accept: */*,getcontentFeatures.dlna.org: 1,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0"]]
2012-02-16 00:28:30,433 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2012-02-16 00:28:30,434 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.5, Profile=Sony BD Player / SMP'
2012-02-16 00:28:30,435 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000070001 and type 'MEDIA_ITEM' received
2012-02-16 00:28:30,435 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000070001 (online)
2012-02-16 00:28:30,435 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2012-02-16 00:28:30,437 DEBUG [VideoDeliveryEngine] Delivering item '1000000000070001' for client 'IPAddress=/192.168.1.5, Profile=Sony BD Player / SMP'
2012-02-16 00:28:30,438 DEBUG [VideoDeliveryEngine] Delivering file 'http://172.31.1.8:7101/' using transcoding
2012-02-16 00:28:30,438 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.5, Profile=Sony BD Player / SMP'
2012-02-16 00:28:31,439 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_EU_ISO
2012-02-16 00:28:31,439 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_NA_ISO
2012-02-16 00:28:31,439 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_KO_ISO
2012-02-16 00:28:31,440 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2012-02-16 00:28:31,440 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-02-16 00:28:31,440 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-02-16 00:28:31,440 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Wed, 15 Feb 2012 22:28:31 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-02-16 00:28:31,448 DEBUG [WebServer] Incoming connection from /192.168.1.5:56161
2012-02-16 00:28:31,472 DEBUG [WebServer] I/O error: Broken pipe
2012-02-16 00:28:31,552 DEBUG [ResourceTransportRequestHandler] GET /resource/1000000000070001/MEDIA_ITEM/MPEG_TS_SD_NA_ISO*0 HTTP/1.1, headers = [Host: 192.168.1.1:8895,Accept: */*,getcontentFeatures.dlna.org: 1,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0"]]
2012-02-16 00:28:31,552 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2012-02-16 00:28:31,558 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.5, Profile=Sony BD Player / SMP'
2012-02-16 00:28:31,558 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000070001 and type 'MEDIA_ITEM' received
2012-02-16 00:28:31,558 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000070001 (online)
2012-02-16 00:28:31,559 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2012-02-16 00:28:31,563 DEBUG [VideoDeliveryEngine] Delivering item '1000000000070001' for client 'IPAddress=/192.168.1.5, Profile=Sony BD Player / SMP'
2012-02-16 00:28:31,564 DEBUG [VideoDeliveryEngine] Delivering file 'http://172.31.1.8:7101/' using transcoding
2012-02-16 00:28:31,564 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.5, Profile=Sony BD Player / SMP'
2012-02-16 00:28:32,394 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-02-16 00:28:32,394 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-02-16 00:28:32,397 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2012-02-16 00:28:32,401 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 9)
2012-02-16 00:28:32,403 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 10)
2012-02-16 00:28:32,407 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 11)
2012-02-16 00:28:32,409 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 12)
2012-02-16 00:28:32,565 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_EU_ISO
2012-02-16 00:28:32,565 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_NA_ISO
2012-02-16 00:28:32,565 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_KO_ISO
2012-02-16 00:28:32,566 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2012-02-16 00:28:32,566 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-02-16 00:28:32,566 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-02-16 00:28:32,566 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Wed, 15 Feb 2012 22:28:32 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-02-16 00:28:34,233 DEBUG [WebServer] Incoming connection from /192.168.1.5:56162
2012-02-16 00:28:34,328 DEBUG [ResourceTransportRequestHandler] GET /resource/1000000000070001/MEDIA_ITEM/MPEG_TS_SD_NA_ISO*0 HTTP/1.1, headers = [Host: 192.168.1.1:8895,Accept: */*,getcontentFeatures.dlna.org: 1,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0"]]
2012-02-16 00:28:34,329 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2012-02-16 00:28:34,330 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.5, Profile=Sony BD Player / SMP'
2012-02-16 00:28:34,331 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000070001 and type 'MEDIA_ITEM' received
2012-02-16 00:28:34,331 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000070001 (online)
2012-02-16 00:28:34,331 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2012-02-16 00:28:34,334 DEBUG [VideoDeliveryEngine] Delivering item '1000000000070001' for client 'IPAddress=/192.168.1.5, Profile=Sony BD Player / SMP'
2012-02-16 00:28:34,334 DEBUG [VideoDeliveryEngine] Delivering file 'http://172.31.1.8:7101/' using transcoding
2012-02-16 00:28:34,334 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.5, Profile=Sony BD Player / SMP'
2012-02-16 00:28:34,335 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_EU_ISO
2012-02-16 00:28:34,335 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_NA_ISO
2012-02-16 00:28:34,335 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_KO_ISO
2012-02-16 00:28:34,336 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2012-02-16 00:28:34,336 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-02-16 00:28:34,337 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-02-16 00:28:34,337 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Wed, 15 Feb 2012 22:28:34 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-02-16 00:28:34,375 DEBUG [WebServer] I/O error: Broken pipe
2012-02-16 00:28:37,542 DEBUG [WebServer] Incoming connection from /192.168.1.5:56163
2012-02-16 00:28:37,639 DEBUG [ResourceTransportRequestHandler] GET /resource/1000000000070001/MEDIA_ITEM/MPEG_TS_SD_NA_ISO*0 HTTP/1.1, headers = [Host: 192.168.1.1:8895,Accept: */*,getcontentFeatures.dlna.org: 1,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0"]]
2012-02-16 00:28:37,639 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2012-02-16 00:28:37,641 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.5, Profile=Sony BD Player / SMP'
2012-02-16 00:28:37,642 DEBUG [ResourceTransportRequestHandler] Request for resource 1000000000070001 and type 'MEDIA_ITEM' received
2012-02-16 00:28:37,642 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000070001 (online)
2012-02-16 00:28:37,643 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2012-02-16 00:28:37,650 DEBUG [VideoDeliveryEngine] Delivering item '1000000000070001' for client 'IPAddress=/192.168.1.5, Profile=Sony BD Player / SMP'
2012-02-16 00:28:37,650 DEBUG [VideoDeliveryEngine] Delivering file 'http://172.31.1.8:7101/' using transcoding
2012-02-16 00:28:37,651 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.5, Profile=Sony BD Player / SMP'
2012-02-16 00:28:37,651 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_EU_ISO
2012-02-16 00:28:37,652 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_NA_ISO
2012-02-16 00:28:37,652 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file http://172.31.1.8:7101/: MPEG_TS_SD_KO_ISO
2012-02-16 00:28:37,652 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2012-02-16 00:28:37,653 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-02-16 00:28:37,653 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-02-16 00:28:37,653 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Wed, 15 Feb 2012 22:28:37 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-02-16 00:28:37,820 DEBUG [WebServer] I/O error: Broken pipe
2012-02-16 00:28:39,334 DEBUG [WebServer] I/O error: Broken pipe
2012-02-16 00:28:59,335 DEBUG [NonClosingPipedInputStream] Closing piped input stream and closing related feeder process
2012-02-16 00:28:59,335 DEBUG [ProcessExecutor] Stopping external process: Thread[Thread-297,5,main]
2012-02-16 00:28:59,335 DEBUG [ProcessUtils] Sending kill -9 to the Unix process: 6293
2012-02-16 00:28:59,336 DEBUG [ProcessExecutor] Starting kill -9 6293
2012-02-16 00:28:59,357 WARN  [ProcessExecutor] Process ffmpeg has a return code of 137! This is a possible error.
2012-02-16 00:28:59,357 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2012-02-16 00:28:59,359 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2012-02-16 00:29:05,642 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 10.13.1.131, timeout = 0
2012-02-16 00:29:05,644 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 232e919c-d3d9-3eeb-ac51-8e4209d980af
2012-02-16 00:29:07,447 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth1 (eth1) and address 192.168.1.1, timeout = 0
2012-02-16 00:29:07,449 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 232e919c-d3d9-3eeb-ac51-8e4209d980af
2012-02-16 00:29:09,253 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:01:18
2012-02-16 00:29:32,413 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-02-16 00:29:32,414 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-02-16 00:29:32,417 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 7)
2012-02-16 00:29:32,419 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 9)
2012-02-16 00:29:32,421 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 10)
2012-02-16 00:29:32,422 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 11)
2012-02-16 00:29:32,423 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 12)
alex6600
Post Thu Feb 16, 2012 3:23 pm
Re: IPTV unicast
Any ideas?
IPTV stream work fine on Windows and HomeMediaServer.
But I use linux, and serviio for streaming my media library.
FourCandles
Post Tue Apr 24, 2012 11:11 am
Re: IPTV unicast
Was this ever resolved? I'm having the same issues streaming to my Sony BD 370 - I/O broken pipe.
Thanks!
alex6600
Post Tue Apr 24, 2012 2:38 pm
Re: IPTV unicast
On Linux server I install VirtualBox. In VirtualBox- Windows XP with HomeMediaServer :)
And this issue resolved.
Users browsing this forum: Google [Bot] and 114 guests
