airmirror (Ipad2) to DLNA
pdneri
Post Mon Feb 13, 2012 11:50 pm
Is there a way to use the Apple Airplay mirroring feature with Serviio and get my Ipad2 screen mirrored to my Tv, without the Apple TV nor the HDMI cable?
I know there are some windows softwares (E.g. Aerodrome) which act as Airplay server and shows Ipad2 display mirrored to PC display.
I'm wondering if there is a way (plugin?) to use serviio to receive the Airplay protocol and convert it to DLNA.
It would be a fantastic feature ...
Post Tue Feb 14, 2012 12:11 am
Re: airmirror (Ipad2) to DLNA
look here it tells how to stream your desktop, it might work with what you are wanting.
http://wiki.serviio.org/doku.php?id=stream_pc&s[]=vlc
Post Tue Feb 14, 2012 6:28 am
pdneri wrote:Is there a way to use the Apple Airplay mirroring feature with Serviio and get my Ipad2 screen mirrored to my Tv, without the Apple TV nor the HDMI cable?
no there no way to do this as apple restrict there stuff to only work with there own software.
Post Tue Feb 14, 2012 6:42 am
if you captured the desktop you should be able to.
Post Tue Feb 14, 2012 7:19 am
moltra wrote:if you captured the desktop you should be able to.
so VLC runs on IOS???
Post Tue Feb 14, 2012 7:28 am
He is wanting to use a program on his serviio computer to capture the airplay mirroring and show it on the tv. Since it is being shown on his computer by the airplay then a desktop capture should work.
Return to Feature requests
