Library refresh on system startup/logon
YTMY
Post Fri Feb 24, 2012 12:54 pm
Hi, been searching forum, but did not find anything similar. For better stability while streaming, I have my library auto-refresh set to disabled. I do manual refresh if I need to. However what would be nice is to have an option (or a cmd line switch) to refresh library on system startup or user login (or any other event using task scheduler). This way newly added files would be added to the library once computer is turned on and would be more comfortable if one tends to forget of library refresh when auto is off. It is not a big feature, however maybe it would be useful for some users.
Not urgent or completely necessary though.
Thanks for the great 0.6.2!
| Samsung UE32C6500 LED | Windows 7 x64 | 5Ghz wi-fi N 300Mbps setup |
Post Fri Feb 24, 2012 12:57 pm
Re: Library refresh on system startup/logon
viewtopic.php?f=17&t=1572 will allow you to force a library refresh using serviio's REST API
Create a script and add it to windows task scheduler to run on login
curl for windows http://curl.haxx.se/download.html think you will want the Win32 - Generic or Win64 - Generic
YTMY
Post Fri Feb 24, 2012 12:59 pm
Thanks! Will look at it.
Return to Feature requests
