Sopcast plugin
madlac1970
Post Wed Mar 21, 2012 7:37 pm
Sopcast plugin
Any way to play channels like sop://broker.sopcast.com:3912/111617 and be able to change channels from my LG Smart TV ?
These channels play ok with Sopcast player or WMP with sopcast filter.
Any help would be greatly appreciated.
Wingsgb
Post Fri Mar 23, 2012 10:32 am
Re: Sopcast plugin
Yes you can play sop channels through serviio so there available to watch on your tv. This is something I regularly do. I will post the step by step guide I create for one of the lads in work in a couple of hours when home.
Post Fri Mar 23, 2012 3:53 pm
Re: Sopcast plugin
would be good to post it on the wiki too :-)
Wingsgb
Post Sat Mar 24, 2012 2:13 pm
Re: Sopcast plugin
madlac1970
Post Sat Mar 24, 2012 4:04 pm
Re: Sopcast plugin
Thank you for taking the time to do this write-up. I've been using this workaround solution also but I was hoping to find a way to control channels thru DLNA like Wild Media Server does by calling Sopcast or WMP and catch the stream automatically without the need to start the stream on the server manually 1st.
Post Sat Mar 24, 2012 7:07 pm
Re: Sopcast plugin
thanks, added the link to the wiki
siriusblack
Post Tue May 08, 2012 8:49 pm
Re: Sopcast plugin
I hope I'm using the right place if I'm not sorry
I bought a new laptop Sony vaio i5 & 6Gb of ram
Just wondering why when using sopcast it still freezes
And stutters
I'm using wireless Bt infinity
Can any one help with an answer
Beta Tester
henri
Post Sun Aug 05, 2012 7:17 am
Re: Sopcast plugin
First of all, I would like to thank you for the Wiki. I was able to get the Sopcast VIDEO stream to my Samsung TV within 2 minutes. The only thing which I did not get was AUDIO. It would be great if you could give me some hint where the problem could be since a stream without audio does not really make sense :roll: Thank you!
Wingsgb
Post Sun Aug 05, 2012 11:53 am
Re: Sopcast plugin
henri wrote:First of all, I would like to thank you for the Wiki. I was able to get the Sopcast VIDEO stream to my Samsung TV within 2 minutes. The only thing which I did not get was AUDIO. It would be great if you could give me some hint where the problem could be since a stream without audio does not really make sense :roll: Thank you!
Do you have audio on the stream when its on the PC/ server side?
henri
Post Sun Aug 05, 2012 4:22 pm
Re: Sopcast plugin
Hi, I think I solved the issue. Once I disabled the transcoding it worked :roll: :D
Xmantium
Post Tue Aug 07, 2012 9:29 pm
Re: Sopcast plugin
henri wrote:Hi, I think I solved the issue. Once I disabled the transcoding it worked :roll: :D
You shouldnt have to manually disable transcoding to make audio work, may be a bug or you need to edit your Samsung device profile
Post Fri Aug 31, 2012 12:05 am
Re: Sopcast plugin
I've posted a SOPCAST plugin along with an explanation of how it addresses and solutions the various problems in playing SOPCAST streams. viewtopic.php?f=20&t=7249
Return to Plugin requests
