Using UpnPlay cannot play wma
tgckpg
Post Fri Mar 09, 2012 4:22 am
It said could not find audio format: ms-wma
how do I fix it ?
Sent from my LG-P920 using Tapatalk
tgckpg
Post Mon Mar 26, 2012 1:31 am
Re: Using UpnPlay cannot play wma
Still looking for a solution:(
Post Mon Mar 26, 2012 9:36 am
Could you provide "ffmpeg -i <file>" result ? see signature links.
tgckpg
Post Tue Apr 03, 2012 6:26 pm
here you go:)
Input #0, asf, from '03. Good Is Good.wma':
WMFSDKVersion : 12.0.8250.0
WMFSDKNeeded : 0.0.0.0000
IsVBR : 1
foobar2000/catalog: 0602498848005
album : Wildflower
WM/ISRC : USUM70501011
track : 3
TotalTracks : 12
title : Good Is Good
artist : Sheryl Crow
Duration: 00:04:18.57, start: 0.000000, bitrate: 108 kb/s
Stream #0.0: Audio: wmav2, 44100 Hz, 2 channels, s16, 10
7 kb/s
Post Wed Apr 04, 2012 4:59 pm
What is the profile selected on serviio console for your device ?
tgckpg
Post Sat Apr 07, 2012 11:28 pm
It is set to "Generic DLNA profile"
Post Sun Apr 08, 2012 6:49 pm
Its probably because your device does not support asf/wmav2 audio format.
Try : Select another profile on Serviio Console, one that transcode asf to mp3 or lpcm : Philips, Sharp Aquos, Toshiba REGZA, Panasonic Viera or Sony Bravia TV.
Post Sun Apr 08, 2012 6:50 pm
or the one that transcodes everything directTV dvr
tgckpg
Post Sun Apr 08, 2012 7:38 pm
but then I put the wma files into my phone、I could play it even using the default player:\
Post Mon Apr 09, 2012 10:08 am
embedded player and DLNA player could not be compared, the DLNA firmware probably not include the proper mime-type, etc.
Do you try with other profile on serviio console?
tgckpg
Post Tue Apr 10, 2012 2:10 pm
Ok I tried other profiles and most of them does not work. Only some profile produce weired sound.
PS: I found that VPlayer could play wma but it is a video player and it treats wma as video...(so it keeps the screen on when playing:\
Regards,
Penguin
Return to General discussion
