Some Stream stopp at 7 Seconds
Eldorado
Post Mon Mar 26, 2012 3:00 pm
Hello
Thanks for this great program. But i have one "big" Problem.
Some Files on my HDD hang off after 7 seconds on my TV an the Error comes :
"Please wait" and after 10-15 second " File not read"
My TV is a Panasonic TX-L37D25E and i go from my PC with LAN to my 54 Mbit Router. From my Router than to my TV.
Some Files are run great - like this :
Typ - Video
Codex - MPEG-4 Video ( XVID )
640x270
Pictures - 23,97
Planar 4:2:0 YUV
But this file ( and other files from online Video Recorder ) run NOT :
Typ - Video
Codex - MPEG-4 Video ( DX50 )
640x360
Pictures - 25
Planar 4:2:0 YUV
Please help !!!!
Eldo
Post Mon Mar 26, 2012 4:52 pm
Re: Some Stream stopp at 7 Seconds
Change DX50 to XVID with FourCC.
http://wiki.serviio.org/doku.php?id=avi4cc
Eldorado
Post Tue Mar 27, 2012 3:50 pm
Ok, thanks
I want to try it BUT when i start AVIC.EXE and open the File with DX50 i can only try :
MP41
MP42
MP43
DIV4
I install all DIVX Driver and the All in one Driver. And the next is - i have more than 100 Files with DX50 from " Online Video Recorder " and i think i must all transform to DIVX or Xvid ?
Q1 : how i can change to xvid with FourCc
Q2 : Batch Transforming ?
Many Thanks
Eldo
Eldorado
Post Tue Mar 27, 2012 4:09 pm
Sorry, i found now the right FourCC Program with xvid.
So i get the DX50 File and put the :
FourCC Description Code to XVID
FourCC Used Code to XVID
The i see at the VLC Player that i change from DX50 to XVID - but the file stop at my Panasonic also at 7 Seconds.
Also the Change to DIVX failt.
Do you know any help ?
Eldo
Post Tue Mar 27, 2012 4:59 pm
is there an error in the log? you could try upgrading ffmpeg.
Eldorado
Post Tue Mar 27, 2012 5:23 pm
This is my Log for one File with the Error:
2012-03-27 17:40:53,328 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file auto_mobil_12.02.26_17-00_vox_75_TVOON_DE.mpg.avi.AVI [VideoDescription [type=FILM, names=[auto mobil 12 02 26 17 00 vox 75, null], year=null, season=null, episode=null]]
2012-03-27 17:41:28,390 INFO [LibraryAdditionsCheckerThread] Added file 'auto_mobil_12.02.26_17-00_vox_75_TVOON_DE.mpg.avi.AVI' (title: auto_mobil_12.02.26_17-00_vox_75_TVOON_DE.mpg.avi) to Library
Eldorado
Post Sun Apr 22, 2012 11:46 am
Ok, i found only one godd solution :
I must convert all fils with "Freemake Video Converter" .
This is not Working :
1. Convert DX50 with FourCC - this change in 1 second the prefix from DX50 to divx ( but the file is not running )
With Freemake Converter is very simple but each File ( 1GB ) is running so round 4 hours and the Size is change - BUT it's running.
Have you other solutions...please Post ist, because my PC is runnung each time ;-)
Eldo
Eldorado wrote:This is my Log for one File with the Error:
Return to Panasonic
