Serviio and XBMC: stack movies
filippobesana
Post Sat Mar 24, 2012 3:33 pm
I use XBMC and Serviio for trascoding (using .nfo XBMC's files). But I have a problem: some movies is composed from many files like "Avatar - CD1.avi" and "Avatar - CD2.avi".
XBMC collapses stack movies and show only "Avatar.avi". When I play the movie XBMC shows "Avatar - CD1.avi" and after "Avatar - CD2.avi" without user interaction.
Servviio shows both "Avatar - CD1.avi" and "Avatar - CD2.avi".
It is possible collaps stack movies in Serviio?
Post Mon Mar 26, 2012 8:25 am
Re: Serviio and XBMC: stack movies
It's not possible.
filippobesana
Post Mon Mar 26, 2012 10:13 am
zip wrote:It's not possible.
So, Serviio can't manage file list showed through uPNP?
Post Mon Mar 26, 2012 11:49 am
it can, but it doesn't know the 2 files are related - therefore doesn't stack them.
iheartninjas
Post Tue Mar 27, 2012 10:56 pm
What then is the proper way to handle these files? I mean file/folder setup and naming? Or where should i post this question if this is not the proper place?
Thx
Post Wed Mar 28, 2012 12:39 pm
I keep them with the same name, they appear with the same title in Movies folder but ordered properly.
iheartninjas
Post Wed Mar 28, 2012 11:51 pm
Thanx thats what i have done
Return to Feature requests
