correct configuration for LE40A756
tuareg64ve
Post Wed Mar 28, 2012 4:53 am
Hello, I have a LE40A756R1M Samsung TV, series 7.
Does anyone of you have the correct configuration for this TV ?
The problems I have at the moment are:
1. Some clips are not transcoded. For instance, see the attachment above.
2. Youtube plugin displays some clips badly but other are ok.
3. I can see RSS streming but I cannot see any RTMP streaming.
Thanks a lot. Bye.
$ ffmpeg -i test.avi
FFmpeg version SVN-r26402, Copyright (c) 2000-2011 the FFmpeg developers
built on Feb 6 2012 19:15:22 with gcc 4.4.3
configuration: --enable-libmp3lame
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 1 / 0.16. 1
libavformat 52.93. 0 / 52.93. 0
libavfilter 1.74. 0 / 1.74. 0
libswscale 0.12. 0 / 0.12. 0
Input #0, avi, from 'test.avi':
encoder : Nandub v1.0rc2
title : *****
ISBJ : *****
artist : *****
copyright : *****
comment : SBC 953 Two Passes Precise Bicubic Audio AC3 5 Ch. 72ms. delay
Duration: 02:22:45.40, start: 0.000000, bitrate: 1348 kb/s
Stream #0.0: Video: msmpeg4, yuv420p, 640x288, 25 tbr, 25 tbn, 25 tbc
Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
Post Wed Mar 28, 2012 12:53 pm
Re: correct configuration for LE40A756
did you select Samsung A series profile?
tuareg64ve
Post Sat Mar 31, 2012 9:54 pm
Yes, I did!
And I also tried to change many profiles without any result!
For instance, I can see very well on youtube the following channel:
http://gdata.youtube.com/feeds/api/user ... rs/uploads
but I have a lot of problems with this:
http://gdata.youtube.com/feeds/api/users/irb/uploads
and I can't understand the reason... :?
Post Sun Apr 01, 2012 6:14 pm
enable detailed log and try to play the file again. then post the ffmpeg command it's using. Also try to execute the ffmpeg command manually to see if it fails with an error.
Users browsing this forum: No registered users and 49 guests
