Static IP to DLNA (fixed)
kubbaz
Post Fri Apr 06, 2012 2:43 am
Im not savvy with network jargon, so ill keep this simple as possible
I have a billion 7800n and a sammy C series
My pc is 168.1, My C650 is 168.2 and are both static.
Once i changed my Pc's network ipv4 protocol from auto assign(DHCP) to manual(No DHCP), applying the change, my pc decided that there was cause for trouble and asked me to apply a network fix...
Heres the issue...
If i apply the fix, DHCP is switched on (NOT what want) And everything is normal
If skip this fix ( pc : 168.1 - C650 : 168.2), I can browse the net, but serviio doesnt work. On my c650 i can still however access the internet, just doesnt wanna play with my pc.
Why cant get serviio to work if my pc has static ip?
kubbaz
Post Fri Apr 06, 2012 3:48 am
Re: Static IP to DLNA
Fixed it !!!
For anyone intersted i used
auto config for IP setups all round
advanced/config/dhcp server/fixed (on my router)
entered fixed ip here
