Getting serviio to work with my tv (again)
xaphan
Post Wed Apr 18, 2012 8:11 pm
Ok, so i first installed serviio back in 2009, and with help from here got it working seamlessly with my tv.
Now having rebuilt my pc, reinstalled serviio, and found the profile i was using (SamsungWiseLinkPro) is missing...
(here is the original thread http://forum.serviio.org/viewtopic.php?f=5&t=54&start=10)
anyone shed some light on where my profile is?
(my tv is an le46b650)
Regards
Post Wed Apr 18, 2012 8:26 pm
Re: Getting serviio to work with my tv (again)
You should find that the Samsung B profile works perfectly for your TV.
xaphan
Post Wed Apr 18, 2012 8:30 pm
Thanks for your quick reply.
I have tried that ( I guessed as the tv is a B650, that it'd be a B series) and yes the menus load correctly, but the majority of the files do not. i either get 'unsupported file format' or the video plays and i get 'unsupported audio format' and i get a mute video.
I remember having to make a change to my profiles.xml, is that still needed?
xaphan
Post Wed Apr 18, 2012 9:31 pm
Anyone got any idea?
Post Thu Apr 19, 2012 3:07 am
Need to know the format of those video and audios that don't play and those that do. Post ffmpeg and mediainfo output for each as per the wiki guide for files that don't play. http://wiki.serviio.org/doku.php?id=file_np
xaphan
Post Mon May 07, 2012 7:51 pm
this plays, but no audio:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\>cd "Program Files\Serviio\lib"
C:\Program Files\Serviio\lib>ffmpeg.exe -i "f:/Movies/Robbie Williams live at th
e albert hall 2001.avi"
nfig
  libavutil    51. 32. 0 / 51. 32. 0
  libavcodec   53. 42. 0 / 53. 42. 0
  libavformat  53. 24. 0 / 53. 24. 0
  libavfilter   2. 53. 0 /  2. 53. 0
[mpeg4 @ 01628ae0] Invalid and inefficient vfw-avi packed B frames detected
[mp3 @ 0162f0a0] Header missing
Input #0, avi, from 'f:/Movies/Robbie Williams live at the albert hall 2001.avi'
  Duration: 01:13:25.90, start: 0.000000, bitrate: 2444 kb/s
    Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv
420p, 1024x582 [SAR 1:1 DAR 512:291], 29.97 fps, 29.97 tbr, 29.97 tbn, 29.97 tbc
    Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 44100 Hz, stereo, s16, 192 kb
/s
      title           : Audio Stream
whereas this refuses to play at all:
C:\Program Files\Serviio\lib>ffmpeg.exe -i "f:/Movies/A-Team.avi"
nfig
[avi @ 015f8120] non-interleaved AVI
Input #0, avi, from 'f:/Movies/A-Team.avi':
  Duration: 01:53:55.16, start: 0.000000, bitrate: 1715 kb/s
420p, 640x272 [SAR 1:1 DAR 40:17], 25 tbr, 25 tbn, 25 tbc
      title           : i-ateama.avi Video #1
    Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, 5.1(side), s16, 384
 kb/s
      title           : i-ateama.avi Audio #1
Post Thu May 10, 2012 8:10 pm
first on:
probably the cause.
The other one, not sure.
Users browsing this forum: Bing [Bot] and 44 guests
