ALAC
mbzh11
Post Sat May 21, 2011 3:00 pm
ALAC
Hi, I suspect I know the answer to this already given how few mentions of ALAC i can find... but will serviio transcode .m4a ALAC files to LPCM? I initially thought i had profile issues (Sony BDV-e370) but I found they are not being added to my library (see example below), am I doing something wrong or is there no way to add ALAC. The ffmpeg that intalls with serviio happily converts the ALAC files itself. Could serviio do this in the future?
2011-05-17 21:22:20,113 DEBUG [LibraryAdditionsCheckerThread] Found file '02 Gods and Monsters.m4a', checking if it's already in the Library
2011-05-17 21:22:20,113 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item 02 Gods and Monsters.m4a
2011-05-17 21:22:20,118 DEBUG [MediaItemDAOImpl] Media item 02 Gods and Monsters.m4a doesn't exist in DB yet
2011-05-17 21:22:20,118 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2011-05-17 21:22:20,220 DEBUG [MediaItemDAOImpl] Getting file of media item 1083
2011-05-17 21:22:20,234 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1083) and extractor EMBEDDED
2011-05-17 21:22:20,283 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 1083) and extractor COVER_IMAGE_IN_FOLDER
2011-05-17 21:22:20,556 DEBUG [LibraryManager] Skipping processing metadata for an unsupported file. Message: MP4 file '\\LS-MINI\share\iTunes\Music\I Am Kloot\Gods and Monsters\02 Gods and Monsters.m4a' has unsupported codec (Apple Lossless)
Post Sat May 21, 2011 4:55 pm
Re: ALAC
Could you provide "ffmpeg -i" result of your .m4a file ?
mbzh11
Post Sat May 21, 2011 6:08 pm
Re: ALAC
yep, an example is:
ffmpeg -i test1.m4a
686-mingw32-
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'test1.m4a':
    major_brand     : M4A
    minor_version   : 0
    compatible_brands: M4A mp42isom
    creation_time   : 2005-10-10 23:39:22
    title           : Opera Singer
    artist          : Cake
    composer        : J. McCrea & M. Kornweibel
    album           : Comfort Eagle
    genre           : Alternative & Punk
    track           : 1
    date            : 2002
    encoder         : iTunes v5.0.1.4
  Duration: 00:04:06.56, start: 0.000000, bitrate: 884 kb/s
    Stream #0.0(und): Audio: alac, 44100 Hz, 2 channels, s16, 883 kb/s
and if i specify output files it goes on to create working wav, mp3, etc:
ffmpeg -i test1.m4a test1.mp3
686-mingw32-
    major_brand     : M4A
    minor_version   : 0
    artist          : Cake
    track           : 1
    date            : 2002
Output #0, mp3, to 'test1.mp3':
    major_brand     : M4A
    minor_version   : 0
    TDEN            : 2005-10-10 23:39:22
    TIT2            : Opera Singer
    TPE1            : Cake
    TCOM            : J. McCrea & M. Kornweibel
    TALB            : Comfort Eagle
    TCON            : Alternative & Punk
    TRCK            : 1
    TDRL            : 2002
    TSSE            : Lavf52.92.0
    Stream #0.0(und): Audio: libmp3lame, 44100 Hz, 2 channels, s16, 64 kb/s
Stream mapping:
  Stream #0.0 -> #0.0
Press [q] to stop encoding
size=    1927kB time=246.60 bitrate=  64.0kbits/s
video:0kB audio:1927kB global headers:0kB muxing overhead 0.022811%
Post Sat May 21, 2011 6:36 pm
Re: ALAC
Zip will confirm, but ALAC is not supported yet by Serviio but could probably added to the next 0.6 release.
There were an open ticket for lossless audio file : https://bitbucket.org/xnejp03/serviio/i ... e-lossless
Post Sun May 22, 2011 10:57 am
Re: ALAC
Not supported yet, but add it to the ticket above and I'll see what can be done ;)
mbzh11
Post Mon May 23, 2011 7:20 pm
Re: ALAC
Thanks for that (and the fast replies), hope it goes well :)
The Hemulen
Post Sat Apr 21, 2012 1:57 pm
Re: ALAC
Did ALAC file support get added in the end? I use 0.6.2 for video files and mp3 files both of which work fine but can't get apple lossless files to show up on Roku Soundbridges or Sony Bluray players. Thanks.
