Serviio will not scan folder
JimSonyTV
Post Sat Apr 21, 2012 1:33 pm
I have a very large folder on my PC called "Photos" containing numerous folders of jpegs which I have in the past been able to view via Serviio on my Sony KDL46HX803 without problem.
Something seems to have changed of late and I am no longer able to view any of the contents of the Photos folder on my TV - it says "There are no items to display" when I open it. I have uninstalled and reinstalled Serviio but this has made no difference. I have also tried "Force refresh" but the "checking for new files" button under "show status" just remains red and nothing appears to be scanned.
If I copy an individual folder from the Photos folder to another location on my PC and then add it to my Serviio library, it works fine, and I can see it on my TV. Similarly, other folders containing mp3s also work fine with Serviio.
Can anyone suggest what the problem may be?
The only thing I can think of is that I have recently started using Livedrive on-line backup for my Photos folder. The Livedrive software detects any changes in the Photos folder and replicates them in the on-line backup. Is it possible that this is somehow preventing Serviio from scanning the folder?
A copy of my Serviio log is attached.
I should be very grateful for any help.
(337.66 KiB) Downloaded 844 times
Post Sat Apr 21, 2012 5:40 pm
Re: Serviio will not scan folder
It doesn't even start looking in the images folder. It looks like it's either not added in the console or you selected a wrong file type to look for.
JimSonyTV
Post Sat Apr 21, 2012 6:59 pm
Here's a screen shot of the Library tab in the console and a fresh copy of the log. I reinstalled the program and deleted the plugins as they (or something) seemed to be making the log rapidly exceed 500kb maximum for upload. "E:\Photos" is definitely the correct path. I hope that this helps and very much appreciate your taking time to look at this.
Console settings.doc
(272 KiB) Downloaded 767 times
(69.42 KiB) Downloaded 829 times
Post Sun Apr 22, 2012 5:37 pm
Looks like access rights problem to me. Is E path to a remote drive? If yes look at the FAQ. Make sure the user running the serviio service has read access to the folders and files. If it's a remote drive you should use UNC path rather than drive letter.
JimSonyTV
Post Mon Apr 23, 2012 8:35 pm
E is not a remote drive - it's a partition on a hard drive.
JimSonyTV
Post Tue Apr 24, 2012 2:01 pm
I have managed to cure the problem by going into the security settings for E:\Photos and making them match those of another folder which worked with Serviio.
I'm not sure which of the changes cured the problem, but I noticed that there were two "Group or user names" missing from E:\Photos, namely "System" and "Administrators".
Thank you for your help.
Post Tue Apr 24, 2012 5:18 pm
that would be it, as the server usually runs under a System account.
Users browsing this forum: Google [Bot] and 112 guests
