Serviio vs Samsung D5500 - WiFi stream problem
PDESD
Post Sun Apr 29, 2012 5:11 pm
Hello everyone,
I have troubles with my Samsung UE40D5500 and Serviio streaming using WiFi.
The problem comes when I open movie on my TV to stream, than black screen with "Loading..." appears and takes too long to start... a few minutes for sure
And when the video starts, immediately gets stuck after 1 sec and again "Loading..." and so all round
I have TP-Link router and 10mbps/100kbps internet.
Hope someone will help :)
Best,
PDESD
YTMY
Post Mon Apr 30, 2012 5:37 am
Re: Serviio vs Samsung D5500 - WiFi stream problem
Seems like video quality is too high for Your wifi setup. Is Your router G standard? If You try to stream 720p and up videos, G is usually not enough. It also depends on the distance from the router to the tv (and pc if it is connected to it wirelessly).
If possible, always connect pc and tv to the router with the cable.
| Samsung UE32C6500 LED | Windows 7 x64 | 5Ghz wi-fi N 300Mbps setup |
PDESD
Post Mon Apr 30, 2012 6:00 am
Thank you for your answer YTMY.
My router is: TP-Link TL-WR740N Lite N, standard: 802.11 b/g/n-light
Distance from Pc to TV is about 11-12 m
Now, Im not sure if that one is enough for 720p videos...
Yes, I tried to stream 720p videos and some high res images (it's very slow with images too)
I thought to buy LAN cable and give it a try...
Post Mon Apr 30, 2012 8:04 am
Look at this thread it might help some.
http://forum.serviio.org/viewtopic.php?f=17&t=2439
PDESD
Post Mon Apr 30, 2012 9:13 pm
everything is fine with LAN cable, just checked... than, i guess, it must be something wrong with wifi router
YTMY
Post Tue May 01, 2012 6:44 pm
PDESD wrote:everything is fine with LAN cable, just checked... than, i guess, it must be something wrong with wifi router
Its nothing wrong I guess, just too big distance and/or too weak signal. If Your router is N standard, all Your clients (tv) must be N too to benefit from increased throughput.
Good luck with the router. ;)
Users browsing this forum: Bing [Bot] and 9 guests
