Newbie here need help
ramzz
Post Mon May 07, 2012 3:40 pm
I have installed serviio on my laptop all went fine. I start my Sammy 7000 55inch Tv my Tv picks up Serviio no problem. I typed in a link for music worked no problem. I downloaded Grovey to the serviio plugin folder but when I check my serviio on my laptop or my tv I see nothing in any of the folders. What am I doing wrong?
I also tried to copy and paste links to the online folder from the links in the links section but It wont let me copy and paste. Also is there a way I can download big file so i DONT have to type all the links in the online folder when I get this working. I have looked high and low but can't find anything here to help me. Can someone point me in the right direction or a howto vidio?? Thanks.
Post Mon May 07, 2012 4:55 pm
Re: Newbie here need help
Which plugin (.groovy file) are you trying to use.
You should be able to paste links into the console by press CTRL + V
As for adding the links, we are working on that with http://www.serviidb.com/ so far you can use my android app to search and add content from it, in the future there will be a way to add the content directly from your computer either directly in the serviio console, or using a standable app/web app. So far it is mostly UK links, so we need other users to add more content.
ramzz
Post Mon May 07, 2012 11:16 pm
I am using the most recent one. Or is there a special one I should use?? I downloaded a zip file and I to it to unzip it in the plugin folder.
ramzz
Post Tue May 08, 2012 5:25 pm
I am totally at a loss.. now i am getting failed to access the device. Please check the device and try again on my Tv everytime I start serviio in allshare :shock: Also under Videos and pictures I get after the first error msg I get There is no video file currently available.
Post Tue May 08, 2012 5:37 pm
Do you mean you downloaded the pack with all of the plugins in? I ment are you trying to use say 4oD or Hulu etc...
Can you turn on detailed logging (see my sig), restart the service (start -> serviio -> stop serviio service (or something named like that), then start serviio service), and then browse serviio using your device and once you have seen all the errors, post the log.
ramzz
Post Wed May 09, 2012 11:23 am
I was able to get to where the file is to change to debug but it wont let me change value to debug!! How do I change this??
ramzz
Post Wed May 09, 2012 3:35 pm
Re: Newbie here need help now I have posted my debug log
I hope this helps I was able to use the debug
2012-05-09 07:26:01,930 INFO [MediaServer] ------------------------------------------------------------------------
2012-05-09 07:26:01,931 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.2 (rev. aec3abd196d6+)
2012-05-09 07:26:01,931 INFO [MediaServer] Petr Nejedly 2009-2011
2012-05-09 07:26:01,931 INFO [MediaServer] http://www.serviio.org
2012-05-09 07:26:01,932 INFO [MediaServer]
2012-05-09 07:26:01,932 INFO [MediaServer] Java 1.6.0_31-Sun Microsystems Inc.
2012-05-09 07:26:01,932 INFO [MediaServer] OS Windows Vista x86 6.0
2012-05-09 07:26:01,932 INFO [MediaServer] File encoding: windows-1252
2012-05-09 07:26:01,933 INFO [MediaServer] Headless mode enabled: true
2012-05-09 07:26:01,933 INFO [MediaServer] User home dir: C:\Windows\System32\config\systemprofile
2012-05-09 07:26:01,934 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-05-09 07:26:01,934 INFO [MediaServer] ------------------------------------------------------------------------
2012-05-09 07:26:02,205 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-05-09 07:26:02,339 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-05-09 07:26:05,125 INFO [DBSchemaUpdateExecutor] Updating DB schema
2012-05-09 07:26:08,788 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-05-09 07:26:09,784 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-05-09 07:26:10,432 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-05-09 07:26:10,795 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-05-09 07:26:11,254 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-05-09 07:26:11,517 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-05-09 07:26:11,683 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-05-09 07:26:12,492 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-05-09 07:26:12,546 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-05-09 07:26:13,359 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-05-09 07:26:14,514 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-05-09 07:26:15,098 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-05-09 07:26:15,527 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-05-09 07:26:15,786 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-05-09 07:26:15,850 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-05-09 07:26:16,048 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-05-09 07:26:16,140 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-05-09 07:26:16,456 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-05-09 07:26:16,611 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-05-09 07:26:17,027 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-05-09 07:26:17,317 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-05-09 07:26:25,377 INFO [WebServer] Socket buffer set to 65535 bytes
2012-05-09 07:26:25,378 INFO [Device] Created UPnP Device with UUID: ee42199b-6787-3b82-bd84-f024ac5cda48, bound address: 192.168.0.102
2012-05-09 07:26:25,409 INFO [PluginCompilerThread] Looking for plugins at C:\serviio\bin\..\plugins
2012-05-09 07:26:25,410 INFO [PluginCompilerThread] Started looking for plugins
2012-05-09 07:26:25,742 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-05-09 07:26:25,790 INFO [WebServer] WebServer starting on port 8895
2012-05-09 07:26:25,800 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-05-09 07:26:25,815 INFO [EventDispatcher] Starting EventDispatcher
2012-05-09 07:26:25,816 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-05-09 07:26:25,821 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-05-09 07:26:25,821 INFO [RendererSearchSender] Searching for Renderer devices
2012-05-09 07:26:25,989 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net3 (Dell Wireless 1505 Draft 802.11n WLAN Mini-Card) and address 192.168.0.1xx, timeout = 0
2012-05-09 07:26:36,134 INFO [RendererManager] Stored a new renderer: uuid='4c802ea1-ee14-4bd1-ba10-29a0ceff180b', name = 'Unrecognized device', ipAddress='192.168.0.10', profile = '1'
2012-05-09 07:26:36,165 INFO [RendererManager] Stored a new renderer: uuid='b521f892-4593-bb26-3d66-70eb6321d5b7', name = 'UN55D7000', ipAddress='192.168.0.10', profile = '7'
2012-05-09 07:26:58,843 INFO [ServiioConsole] Starting Serviio Console
2012-05-09 07:26:59,032 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-05-09 07:27:00,045 INFO [Messages] Loaded console message bundle for locale: en
2012-05-09 07:27:00,105 INFO [UpdateChecker] Checking if a new version is available
2012-05-09 07:27:00,369 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-05-09 07:27:00,380 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-05-09 07:27:00,403 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-05-09 07:27:02,319 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-05-09 07:27:03,322 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-05-09 10:29:50,443 WARN [DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
2012-05-09 10:53:52,790 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-05-09 10:53:52,790 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-05-09 10:53:52,793 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-05-09 10:53:52,890 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-05-09 10:53:52,990 INFO [FeedUpdaterThread] Finished looking for online resources information
2012-05-09 10:53:53,090 INFO [PluginCompilerThread] Finished looking for plugins
2012-05-09 10:53:53,192 INFO [WebServer] WebServer shutting down
2012-05-09 10:53:53,193 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-05-09 10:53:53,193 INFO [EventDispatcher] Leaving EventDispatcher
2012-05-09 10:53:53,193 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-05-09 10:53:54,581 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-05-09 10:54:00,137 INFO [DatabaseManager] Shutting down database
2012-05-09 10:54:00,353 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-05-09 10:54:00,685 INFO [ServiioConsole] Leaving Serviio Console
2012-05-09 11:02:29,697 INFO [ServiioConsole] Starting Serviio Console
2012-05-09 11:02:29,934 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-05-09 11:02:40,224 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2012-05-09 11:02:50,235 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2012-05-09 11:02:50,251 INFO [Messages] Loaded console message bundle for locale: en
2012-05-09 11:03:00,263 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2012-05-09 11:04:15,452 INFO [ServiioConsole] Starting Serviio Console
2012-05-09 11:04:15,641 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-05-09 11:04:25,918 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2012-05-09 11:04:35,929 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2012-05-09 11:04:35,938 INFO [Messages] Loaded console message bundle for locale: en
2012-05-09 11:04:45,952 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2012-05-09 11:04:48,630 INFO [ServiioConsole] Leaving Serviio Console
2012-05-09 11:07:45,136 INFO [MediaServer] ------------------------------------------------------------------------
2012-05-09 11:07:45,167 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.2 (rev. aec3abd196d6+)
2012-05-09 11:07:45,167 INFO [MediaServer] Petr Nejedly 2009-2011
2012-05-09 11:07:45,167 INFO [MediaServer] http://www.serviio.org
2012-05-09 11:07:45,167 INFO [MediaServer] Java 1.6.0_31-Sun Microsystems Inc.
2012-05-09 11:07:45,167 INFO [MediaServer] OS Windows Vista x86 6.0
2012-05-09 11:07:45,183 INFO [MediaServer] File encoding: windows-1252
2012-05-09 11:07:45,183 INFO [MediaServer] Headless mode enabled: true
2012-05-09 11:07:45,183 INFO [MediaServer] User home dir: C:\Windows\System32\config\systemprofile
2012-05-09 11:07:45,183 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-05-09 11:07:45,183 INFO [MediaServer] ------------------------------------------------------------------------
2012-05-09 11:07:46,119 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-05-09 11:07:46,306 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-05-09 11:07:55,120 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-05-09 11:07:56,789 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-05-09 11:07:57,616 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-05-09 11:07:58,084 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-05-09 11:07:58,583 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-05-09 11:07:58,958 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-05-09 11:07:59,192 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-05-09 11:08:00,190 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-05-09 11:08:00,252 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-05-09 11:08:01,828 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-05-09 11:08:04,620 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-05-09 11:08:05,556 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-05-09 11:08:06,524 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-05-09 11:08:07,023 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-05-09 11:08:07,116 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-05-09 11:08:07,678 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-05-09 11:08:08,269 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-05-09 11:08:08,862 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-05-09 11:08:09,154 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-05-09 11:08:09,871 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-05-09 11:08:10,277 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-05-09 11:08:31,165 INFO [WebServer] Socket buffer set to 65535 bytes
2012-05-09 11:08:31,212 INFO [Device] Created UPnP Device with UUID: ee42199b-6787-3b82-bd84-f024ac5cda48, bound address: 192.168.0.102
2012-05-09 11:08:31,462 INFO [PluginCompilerThread] Looking for plugins at C:\serviio\bin\..\plugins
2012-05-09 11:08:31,508 INFO [PluginCompilerThread] Started looking for plugins
2012-05-09 11:08:37,936 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-05-09 11:08:40,385 INFO [WebServer] WebServer starting on port 8895
2012-05-09 11:08:40,400 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-05-09 11:08:40,400 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-05-09 11:08:40,400 INFO [EventDispatcher] Starting EventDispatcher
2012-05-09 11:08:40,447 INFO [RendererSearchSender] Searching for Renderer devices
2012-05-09 11:08:40,463 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-05-09 11:08:40,665 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net3 (Dell Wireless 1505 Draft 802.11n WLAN Mini-Card) and address 192.168.0.xxx, timeout = 0
2012-05-09 11:09:15,843 INFO [ServiioConsole] Starting Serviio Console
2012-05-09 11:09:16,670 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-05-09 11:09:16,670 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-05-09 11:09:16,701 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-05-09 11:09:25,921 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-05-09 11:09:27,216 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-05-09 11:09:29,337 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-05-09 11:09:32,940 INFO [Messages] Loaded console message bundle for locale: en
2012-05-09 11:09:32,959 INFO [UpdateChecker] Checking if a new version is available
2012-05-09 11:09:33,416 WARN [ContentDirectory] Object with id V_L doesn't exist
2012-05-09 11:09:34,002 WARN [ContentDirectory] Object with id V_L doesn't exist
2012-05-09 11:14:50,614 INFO [ServiioConsole] Leaving Serviio Console
2012-05-09 11:17:43,867 INFO [PluginCompilerThread] Added Web Resouce plugin AlloCine (AlloCine.groovy)
2012-05-09 11:17:43,927 INFO [PluginCompilerThread] Added Feed plugin AnOriantUrlExtractor (AnOriant.groovy)
2012-05-09 11:17:44,054 INFO [PluginCompilerThread] Added Web Resouce plugin APVideo (APVideo.groovy)
2012-05-09 11:17:44,135 INFO [PluginCompilerThread] Added Feed plugin ARD Mediathek RSS Extractor (ARDMediathek.groovy)
2012-05-09 11:17:44,310 INFO [PluginCompilerThread] Added Feed plugin Arte (Arte.groovy)
2012-05-09 11:17:44,417 INFO [PluginCompilerThread] Added Feed plugin BlipTVUrlExtractor (BlipTVUrlExtractor.groovy)
2012-05-09 11:17:44,739 INFO [PluginCompilerThread] Added Web Resouce plugin CanalPlus (CanalPlus.groovy)
2012-05-09 11:17:44,933 INFO [PluginCompilerThread] Added Web Resouce plugin Castalba (Castalba.groovy)
2012-05-09 11:17:45,082 INFO [PluginCompilerThread] Added Web Resouce plugin CBS.com (CBS.groovy)
2012-05-09 11:17:45,664 INFO [PluginCompilerThread] Added Web Resouce plugin 4OD (UK only) (Channel4od.groovy)
2012-05-09 11:17:46,014 INFO [PluginCompilerThread] Added Feed plugin CNN (CNN.groovy)
2012-05-09 11:17:46,061 INFO [PluginCompilerThread] Added Feed plugin Crackle (Crackle.groovy)
2012-05-09 11:17:46,143 INFO [PluginCompilerThread] Added Feed plugin DailyMotion (DailyMotion.groovy)
2012-05-09 11:17:46,339 INFO [PluginCompilerThread] Added Web Resouce plugin DI.FM - SKY.FM - JAZZRADIO.COM v1.0 (digitallyimported.groovy)
2012-05-09 11:17:46,428 INFO [PluginCompilerThread] Added Web Resouce plugin Escapist (Escapist.groovy)
2012-05-09 11:17:46,487 INFO [PluginCompilerThread] Added Feed plugin Gamespot (Gamespot.groovy)
2012-05-09 11:17:46,543 INFO [PluginCompilerThread] Added Feed plugin GameTrailers (GameTrailers.groovy)
2012-05-09 11:17:46,637 INFO [PluginCompilerThread] Added Feed plugin Gulli (Gulli.groovy)
2012-05-09 11:17:46,884 INFO [PluginCompilerThread] Added Web Resouce plugin HaHaSport (HaHaSport.groovy)
2012-05-09 11:17:47,086 INFO [PluginCompilerThread] Added Feed plugin Hulu (US only) (Hulu.groovy)
2012-05-09 11:17:47,154 INFO [PluginCompilerThread] Added Feed plugin Hypem (Hypem.groovy)
2012-05-09 11:17:47,295 INFO [PluginCompilerThread] Added Web Resouce plugin ILive (ILive.groovy)
2012-05-09 11:17:47,832 INFO [PluginCompilerThread] Added Feed plugin BBC iPlayer (UK only) (IPlayer.groovy)
2012-05-09 11:17:48,634 INFO [PluginCompilerThread] Added Web Resouce plugin ITVPlayer (UK only) (ITVPlayer.groovy)
2012-05-09 11:17:48,696 INFO [PluginCompilerThread] Added Feed plugin LiveFeeds (LiveFeeds.groovy)
2012-05-09 11:17:48,930 INFO [PluginCompilerThread] Added Web Resouce plugin M6replay (M6replay.groovy)
2012-05-09 11:17:49,008 INFO [PluginCompilerThread] Added Feed plugin NBA (NBA.groovy)
2012-05-09 11:17:49,055 INFO [PluginCompilerThread] Added Feed plugin Orf (Orf.groovy)
2012-05-09 11:17:49,117 INFO [PluginCompilerThread] Added Feed plugin Packers (Packers.groovy)
2012-05-09 11:17:49,273 INFO [PluginCompilerThread] Added Feed plugin PennyArcade (PennyArcade.groovy)
2012-05-09 11:17:51,395 INFO [PluginCompilerThread] Added Web Resouce plugin Playlist extractor (Playlist.groovy)
2012-05-09 11:17:51,520 INFO [PluginCompilerThread] Added Feed plugin Pluzz (Pluzz.groovy)
2012-05-09 11:17:51,598 INFO [PluginCompilerThread] Added Feed plugin Radio Bremen RSS Extractor (RadioBremen.groovy)
2012-05-09 11:17:51,691 INFO [PluginCompilerThread] Added Web Resouce plugin Refresh (Refresh.groovy)
2012-05-09 11:17:51,738 INFO [PluginCompilerThread] Added Feed plugin ReutersCom (ReutersCom.groovy)
2012-05-09 11:17:51,847 INFO [PluginCompilerThread] Added Feed plugin RTVE (RTVE.groovy)
2012-05-09 11:17:51,956 INFO [PluginCompilerThread] Added Feed plugin SC2CastUrlExctractor (SC2Casts.groovy)
2012-05-09 11:17:52,409 INFO [PluginCompilerThread] Added Web Resouce plugin Shoutcast (Shoutcast.groovy)
2012-05-09 11:17:52,456 INFO [PluginCompilerThread] Added Feed plugin SnotrUrlExtractor (Snotr.groovy)
2012-05-09 11:17:53,204 INFO [PluginCompilerThread] Added Web Resouce plugin Stepashka (Stepashka.groovy)
2012-05-09 11:17:53,267 INFO [PluginCompilerThread] Added Feed plugin SvtPlay (SvtPlay.groovy)
2012-05-09 11:17:53,360 INFO [PluginCompilerThread] Added Web Resouce plugin TED (TED.groovy)
2012-05-09 11:17:53,454 INFO [PluginCompilerThread] Added Feed plugin TF1 (TF1.groovy)
2012-05-09 11:17:53,548 INFO [PluginCompilerThread] Added Feed plugin TrailerAddictRss (TrailerAddictRss.groovy)
2012-05-09 11:17:53,641 INFO [PluginCompilerThread] Added Web Resouce plugin Tune In (TuneIn.groovy)
2012-05-09 11:17:53,735 INFO [PluginCompilerThread] Added Feed plugin Tv3Play (Tv3Play.groovy)
2012-05-09 11:17:53,797 INFO [PluginCompilerThread] Added Feed plugin Tv4Play (Tv4Play.groovy)
2012-05-09 11:17:53,844 INFO [PluginCompilerThread] Added Feed plugin Tv6Play (Tv6Play.groovy)
2012-05-09 11:17:53,922 INFO [PluginCompilerThread] Added Feed plugin Tv8Play (Tv8Play.groovy)
2012-05-09 11:17:54,094 INFO [PluginCompilerThread] Added Feed plugin Vimeo (Vimeo.groovy)
2012-05-09 11:17:54,218 INFO [PluginCompilerThread] Added Web Resouce plugin W9replay (W9replay.groovy)
2012-05-09 11:17:54,296 INFO [PluginCompilerThread] Added Feed plugin WAT (WAT.groovy)
2012-05-09 11:17:54,359 INFO [PluginCompilerThread] Added Feed plugin WimpCom (WimpCom.groovy)
2012-05-09 11:17:54,468 INFO [PluginCompilerThread] Added Feed plugin YouTube (Youtube.groovy)
2012-05-09 11:26:32,373 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-05-09 11:26:32,375 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-05-09 11:26:32,377 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-05-09 11:26:32,475 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-05-09 11:26:32,575 INFO [FeedUpdaterThread] Finished looking for online resources information
2012-05-09 11:26:32,675 INFO [PluginCompilerThread] Finished looking for plugins
2012-05-09 11:26:35,008 ERROR [IndexedDiskCache] Region [thumbnails] Not alive and dispose was called, filename: thumbnails
2012-05-09 11:26:35,010 INFO [WebServer] WebServer shutting down
2012-05-09 11:26:35,010 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-05-09 11:26:35,010 INFO [EventDispatcher] Leaving EventDispatcher
2012-05-09 11:26:35,025 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-05-09 11:26:35,868 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-05-09 11:26:40,985 INFO [DatabaseManager] Shutting down database
2012-05-09 11:26:41,203 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-05-09 11:28:01,280 INFO [MediaServer] ------------------------------------------------------------------------
2012-05-09 11:28:01,343 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.2 (rev. aec3abd196d6+)
2012-05-09 11:28:01,343 INFO [MediaServer] Petr Nejedly 2009-2011
2012-05-09 11:28:01,343 INFO [MediaServer] http://www.serviio.org
2012-05-09 11:28:01,343 INFO [MediaServer] Java 1.6.0_31-Sun Microsystems Inc.
2012-05-09 11:28:01,343 INFO [MediaServer] OS Windows Vista x86 6.0
2012-05-09 11:28:01,343 INFO [MediaServer] File encoding: windows-1252
2012-05-09 11:28:01,343 INFO [MediaServer] Headless mode enabled: true
2012-05-09 11:28:01,343 INFO [MediaServer] User home dir: C:\Windows\System32\config\systemprofile
2012-05-09 11:28:01,343 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-05-09 11:28:01,343 INFO [MediaServer] ------------------------------------------------------------------------
2012-05-09 11:28:02,450 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-05-09 11:28:02,622 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-05-09 11:28:15,039 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-05-09 11:28:19,656 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-05-09 11:28:20,701 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-05-09 11:28:21,341 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-05-09 11:28:22,355 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-05-09 11:28:23,104 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-05-09 11:28:24,898 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-05-09 11:28:27,113 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-05-09 11:28:27,175 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-05-09 11:28:29,016 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-05-09 11:28:30,795 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-05-09 11:28:31,403 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-05-09 11:28:31,918 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-05-09 11:28:32,277 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-05-09 11:28:32,339 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-05-09 11:28:32,573 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-05-09 11:28:32,698 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-05-09 11:28:33,088 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-05-09 11:28:33,275 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-05-09 11:28:33,774 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-05-09 11:28:34,039 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-05-09 11:28:45,724 INFO [ServiioConsole] Starting Serviio Console
2012-05-09 11:28:51,184 INFO [WebServer] Socket buffer set to 65535 bytes
2012-05-09 11:28:51,543 INFO [Device] Created UPnP Device with UUID: ee42199b-6787-3b82-bd84-f024ac5cda48, bound address: 192.168.0.102
2012-05-09 11:28:52,525 INFO [PluginCompilerThread] Looking for plugins at C:\serviio\bin\..\plugins
2012-05-09 11:28:55,162 INFO [PluginCompilerThread] Started looking for plugins
2012-05-09 11:29:04,194 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-05-09 11:29:05,692 INFO [WebServer] WebServer starting on port 8895
2012-05-09 11:29:05,707 INFO [EventDispatcher] Starting EventDispatcher
2012-05-09 11:29:05,707 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-05-09 11:29:05,707 INFO [RendererSearchSender] Searching for Renderer devices
2012-05-09 11:29:05,723 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-05-09 11:29:05,723 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-05-09 11:29:05,984 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net3 (Dell Wireless 1505 Draft 802.11n WLAN Mini-Card) and address 192.168.0.1xx, timeout = 0
2012-05-09 11:29:06,015 INFO [PluginCompilerThread] Added Web Resouce plugin AlloCine (AlloCine.groovy)
2012-05-09 11:29:06,202 INFO [PluginCompilerThread] Added Feed plugin AnOriantUrlExtractor (AnOriant.groovy)
2012-05-09 11:29:06,795 INFO [PluginCompilerThread] Added Web Resouce plugin APVideo (APVideo.groovy)
2012-05-09 11:29:07,029 INFO [PluginCompilerThread] Added Feed plugin ARD Mediathek RSS Extractor (ARDMediathek.groovy)
2012-05-09 11:29:08,028 INFO [PluginCompilerThread] Added Feed plugin Arte (Arte.groovy)
2012-05-09 11:29:08,371 INFO [PluginCompilerThread] Added Feed plugin BlipTVUrlExtractor (BlipTVUrlExtractor.groovy)
2012-05-09 11:29:09,244 INFO [PluginCompilerThread] Added Web Resouce plugin CanalPlus (CanalPlus.groovy)
2012-05-09 11:29:09,993 INFO [PluginCompilerThread] Added Web Resouce plugin Castalba (Castalba.groovy)
2012-05-09 11:29:11,101 INFO [PluginCompilerThread] Added Web Resouce plugin CBS.com (CBS.groovy)
2012-05-09 11:29:11,647 INFO [PluginCompilerThread] Added Web Resouce plugin 4OD (UK only) (Channel4od.groovy)
2012-05-09 11:29:12,567 INFO [PluginCompilerThread] Added Feed plugin CNN (CNN.groovy)
2012-05-09 11:29:12,786 INFO [PluginCompilerThread] Added Feed plugin Crackle (Crackle.groovy)
2012-05-09 11:29:12,910 INFO [PluginCompilerThread] Added Feed plugin DailyMotion (DailyMotion.groovy)
2012-05-09 11:29:13,784 INFO [PluginCompilerThread] Added Web Resouce plugin DI.FM - SKY.FM - JAZZRADIO.COM v1.0 (digitallyimported.groovy)
2012-05-09 11:29:14,205 INFO [PluginCompilerThread] Added Web Resouce plugin Escapist (Escapist.groovy)
2012-05-09 11:29:14,361 INFO [PluginCompilerThread] Added Feed plugin Gamespot (Gamespot.groovy)
2012-05-09 11:29:14,548 INFO [PluginCompilerThread] Added Feed plugin GameTrailers (GameTrailers.groovy)
2012-05-09 11:29:14,845 INFO [PluginCompilerThread] Added Feed plugin Gulli (Gulli.groovy)
2012-05-09 11:29:15,172 INFO [PluginCompilerThread] Added Web Resouce plugin HaHaSport (HaHaSport.groovy)
2012-05-09 11:29:18,152 INFO [PluginCompilerThread] Added Feed plugin Hulu (US only) (Hulu.groovy)
2012-05-09 11:29:18,698 INFO [PluginCompilerThread] Added Feed plugin Hypem (Hypem.groovy)
2012-05-09 11:29:19,166 INFO [PluginCompilerThread] Added Web Resouce plugin ILive (ILive.groovy)
2012-05-09 11:29:19,977 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-05-09 11:29:20,539 INFO [PluginCompilerThread] Added Feed plugin BBC iPlayer (UK only) (IPlayer.groovy)
2012-05-09 11:29:22,645 INFO [PluginCompilerThread] Added Web Resouce plugin ITVPlayer (UK only) (ITVPlayer.groovy)
2012-05-09 11:29:22,816 INFO [PluginCompilerThread] Added Feed plugin LiveFeeds (LiveFeeds.groovy)
2012-05-09 11:29:23,955 INFO [PluginCompilerThread] Added Web Resouce plugin M6replay (M6replay.groovy)
2012-05-09 11:29:25,219 INFO [PluginCompilerThread] Added Feed plugin NBA (NBA.groovy)
2012-05-09 11:29:25,390 INFO [PluginCompilerThread] Added Feed plugin Orf (Orf.groovy)
2012-05-09 11:29:25,515 INFO [PluginCompilerThread] Added Feed plugin Packers (Packers.groovy)
2012-05-09 11:29:25,780 INFO [PluginCompilerThread] Added Feed plugin PennyArcade (PennyArcade.groovy)
2012-05-09 11:29:25,780 INFO [Messages] Loaded console message bundle for locale: en
2012-05-09 11:29:25,843 INFO [UpdateChecker] Checking if a new version is available
2012-05-09 11:29:27,621 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-05-09 11:29:30,382 INFO [PluginCompilerThread] Added Web Resouce plugin Playlist extractor (Playlist.groovy)
2012-05-09 11:29:30,554 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-05-09 11:29:30,757 INFO [PluginCompilerThread] Added Feed plugin Pluzz (Pluzz.groovy)
2012-05-09 11:29:30,897 INFO [PluginCompilerThread] Added Feed plugin Radio Bremen RSS Extractor (RadioBremen.groovy)
2012-05-09 11:29:31,053 INFO [PluginCompilerThread] Added Web Resouce plugin Refresh (Refresh.groovy)
2012-05-09 11:29:31,256 INFO [PluginCompilerThread] Added Feed plugin ReutersCom (ReutersCom.groovy)
2012-05-09 11:29:31,474 INFO [PluginCompilerThread] Added Feed plugin RTVE (RTVE.groovy)
2012-05-09 11:29:31,646 INFO [PluginCompilerThread] Added Feed plugin SC2CastUrlExctractor (SC2Casts.groovy)
2012-05-09 11:29:31,896 INFO [PluginCompilerThread] Added Web Resouce plugin Shoutcast (Shoutcast.groovy)
2012-05-09 11:29:32,145 INFO [PluginCompilerThread] Added Feed plugin SnotrUrlExtractor (Snotr.groovy)
2012-05-09 11:29:32,332 INFO [PluginCompilerThread] Added Web Resouce plugin Stepashka (Stepashka.groovy)
2012-05-09 11:29:32,878 INFO [PluginCompilerThread] Added Feed plugin SvtPlay (SvtPlay.groovy)
2012-05-09 11:29:33,206 INFO [PluginCompilerThread] Added Web Resouce plugin TED (TED.groovy)
2012-05-09 11:29:33,424 INFO [PluginCompilerThread] Added Feed plugin TF1 (TF1.groovy)
2012-05-09 11:29:33,830 INFO [PluginCompilerThread] Added Feed plugin TrailerAddictRss (TrailerAddictRss.groovy)
2012-05-09 11:29:34,126 INFO [PluginCompilerThread] Added Web Resouce plugin Tune In (TuneIn.groovy)
2012-05-09 11:29:34,298 INFO [PluginCompilerThread] Added Feed plugin Tv3Play (Tv3Play.groovy)
2012-05-09 11:29:34,563 INFO [PluginCompilerThread] Added Feed plugin Tv4Play (Tv4Play.groovy)
2012-05-09 11:29:34,688 INFO [PluginCompilerThread] Added Feed plugin Tv6Play (Tv6Play.groovy)
2012-05-09 11:29:35,109 INFO [PluginCompilerThread] Added Feed plugin Tv8Play (Tv8Play.groovy)
2012-05-09 11:29:35,187 INFO [PluginCompilerThread] Added Feed plugin Vimeo (Vimeo.groovy)
2012-05-09 11:29:35,499 INFO [PluginCompilerThread] Added Web Resouce plugin W9replay (W9replay.groovy)
2012-05-09 11:29:35,608 INFO [PluginCompilerThread] Added Feed plugin WAT (WAT.groovy)
2012-05-09 11:29:35,702 INFO [PluginCompilerThread] Added Feed plugin WimpCom (WimpCom.groovy)
2012-05-09 11:29:36,435 INFO [PluginCompilerThread] Added Feed plugin YouTube (Youtube.groovy)
2012-05-09 11:29:39,009 WARN [ContentDirectory] Object with id V_L doesn't exist
2012-05-09 11:29:39,727 WARN [ContentDirectory] Object with id V_L doesn't exist
2012-05-09 11:29:42,613 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-05-09 11:29:42,613 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-05-09 11:29:42,613 INFO [FeedUpdaterThread] Started looking for information about online resources
Post Wed May 09, 2012 4:55 pm
That doesn't show any debug messages, did you restart serviio after you changed the log settings.
Could you stop the service, delete the current log files, start the service, wait a few min, then use serviio on your tv so that you get the errors, then post the log in code tags, and if it is too big, zip it up and add it as an attachment.
ramzz
Post Wed May 09, 2012 6:41 pm
will wrote:That doesn't show any debug messages, did you restart serviio after you changed the log settings.
How do I change log settings??
Post Wed May 09, 2012 7:27 pm
http://wiki.serviio.org/doku.php?id=detail_logging (I think you did that before, but didn't actually restart the serviio service)
ramzz
Post Thu May 10, 2012 8:41 pm
Thanks all, for some reason its working I have no idea why, but all I did was uninstall and reinstalled but all is good. Can someone provide a link to where I can download lots of feeds without having to type them all in manual and in which folder they go in.
Users browsing this forum: Baidu [Spider], Google [Bot] and 73 guests
