Sopcast freezing when streaming to devices
siriusblack
Post Tue May 15, 2012 6:13 pm
The problem I'm having is trying to live stream sopcast to tv
Samsung (ue46c8000) + ps3's
If I watch them on laptop its ok, however if I stream them to
The devices it stutters + freezes
I'm using intel i5 + 6gb
Wireless Bt infinity
Thanks any advice would be appreciated
Beta Tester
Post Tue May 15, 2012 6:27 pm
Re: Sopcast freezing when streaming to devices
could be the router, I didn't hear much good things about the Infinity router
siriusblack
Post Tue May 15, 2012 7:15 pm
Thanks for replying
Are there any tests to check if its the router or what router do you recommend plz
Beta Tester
Post Tue May 15, 2012 10:43 pm
http://wiki.serviio.org/doku.php?id=routers&s[]=router
best if you could borrow one before buying
siriusblack
Post Wed May 16, 2012 6:48 am
Thanks for info
Will purchase this router (netgear-dgnd4000-wireless-n750-adsl-modem-router)
When it comes out, in the uk
Thanks again
Beta Tester
Users browsing this forum: No registered users and 62 guests
