Re: ServiiDroid (Android Console) - Get it on Google Play
I can find no more the serviigo profile for serviio.
aloha wrote:Hi everyone,
zip wrote:looks nice
will wrote:I've got a new phone now which means I can finally try and hunt down and fix the FC that is affecting ICS, expect an update hopefully around next weekend.
Xmantium wrote:Which phone did you pick up?
brijoco wrote:Just installed this app on a Sony Tablet S running Android 4. Fantastic!
Much easier to use than Serviio consoles especially if you have two servers.
Wish List .....
Allow tablet users to increase font size and icon size
- better use of screen real estate and ease of use
Online sources backup to file (RSS perhaps?)
- negate the nececessity for the dire warnings when reordering
- Backups are always a good idea!
Load local RSS file containing standard channel definitions
- Restore backups
- allow definitions to be loaded onto different servers
Display selected server name in the top bar
brijoco wrote:Hi,
Tablets: Definately part of the future now prices of Android tabs are dropping. I use my Sony S (amongst other things!) as a universal remote to control my media setup so Droid was a beautiful addition.
Font Size: I tried upping the system font size but only got the display in ServiiDroid I wanted when the system font was 'Huge'. This introduced cropping in long and multiline system logo descriptions. Perhaps possible to increase the font in the app for tablets or introduce font up/down buttons?
Icons: Understand resolution problems. Only way out of that is a new set of icons.
Backup: Now #1 priority after I managed to wipe a long list of online resources from one Serviio. Not sure how I did it. An attack of user digititus me thinks. I should know better.
Server Name: As it appears in switch server or server status. that is "Serviio (PCNAME)" or just PCNAME. I don't 'need' IP or version as they are burnt into my soul but some users might like that.
Reset Search History: (new) A button for this next to the search field in the Search DB screen perhaps.
ServiiDB Search Option: (new) Ability to specify '*' in serch field where scope is limited by setting Media Type, Region and or Title/Plugin to list all entries in the DB for the selection.
Do you know when Serviio v1 is due? Is there a feature list? Do you need testers with my h/w & s/w set?
Users browsing this forum: Baidu [Spider] and 19 guests
