HD Video Quality setting
tombert
Post Mon Nov 15, 2010 7:58 pm
I would like to propose to use the video quality options available in ffmpeg.
Some player can not handle such super-high-quality HD videos and therefore stutter.
I'am not an expert in ffmpeg but -qmin -qmax could be a good start to improve playback quality.
thx
Ryster
Post Mon Nov 15, 2010 8:34 pm
Re: HD Video Quality setting
I second this request. I'd like these settings linkable to each device type though, so it would auto-switch quality setting depending which device was streaming.
Perhaps each time a device connects to Serviio, it's registered on the server. You can then allocate device specific settings to that device, including the quality level.
Serviio Pro Purchaser - 24/07/2012
Post Mon Nov 15, 2010 10:34 pm
you can limit max bitrate on the transcoding element in profiles.xml. This will obviously not affect files that you stream natively.
tombert
Post Tue Nov 16, 2010 6:50 am
For testing purposes I tried the following:
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" maxVBitrate="2000">
<Matches container="asf" />
<Matches container="avi" />
<Matches container="mp4" />
<Matches container="mpegvideo" />
<Matches container="mpegts" />
<Matches container="mpeg" />
Unfort. ffmpeg is not called, there is no debug log about this - it seems that serviio is not re-encoding regardless of what I configure here. My file is already AVC ... am I doing anything wrong?
thx
tombert
Post Tue Nov 16, 2010 6:52 am
I also check the transcoding-temp-9-MPEG2TS.stf ... it still has ~8000 Kbps.
thx
Post Tue Nov 16, 2010 8:08 am
tombert wrote:Unfort. ffmpeg is not called, there is no debug log about this - it seems that serviio is not re-encoding regardless of what I configure here. My file is already AVC ... am I doing anything wrong?...
Are you sure serviio select your modified profile? you could force profile selection on console.
Post Tue Nov 16, 2010 9:07 am
also it might just do remuxing in which case the bitrate is not changed (the stream is just copied)
tombert
Post Tue Nov 16, 2010 3:04 pm
Yes it's doing remuxing only ... I restarted serviio in order to be completely sure and deleted the temp file. The profile is automatic but there is only one Bravia and I see in the log which profile is selected ... so it's ok.
Also the log file shows an ffmpeg copy statement only ... no bitrates visible here ...
What I don't get is how PS3 Media Server is doing this ... it's remuxing as well but reduces video quality in the same time with nearly no cpu usage ...
Would it be worth trying to call ffmpeg with a copy statement and a bitrate limitation (or any other switch)? Just to try?
Post Tue Nov 16, 2010 4:59 pm
you can give it a go. they might also use other sw than ffmpeg, like tsmuxer.
tombert
Post Tue Nov 16, 2010 5:08 pm
Yes they use tsmuxer.
This sounds good: "FFmpeg can also convert from any sample rate to any other, and resize video on the fly with a high quality polyphase filter."
I'll try ...
tombert
Post Wed Nov 17, 2010 12:36 am
Well, it was a hard time If you look at the clock - fought my way through nearly all ffmpeg options ...
-muxrate is the option we're looking for - this works if the -vcodec is set to copy and limits the bitrate with no cpu load ...
So I propose this option for the next serviio release as a kind of maximum bitrate when re-muxing. But we don't want to increase the bitrate but only lower it.
What I mean: when the average video bitrate is lower then the configured muxrate do nothing, else apply the muxrate and thus limit the rate.
thx
Post Wed Nov 17, 2010 8:30 am
Ok good, but its an advanced setting not very easy to manage.
-muxrate option set mux rate, mean average mux rate, it is not a maximum bitrate that "clip" the bitrate...
This requires advanced testing
PS: Sorry for my poor English
tombert
Post Wed Nov 17, 2010 9:00 am
I agree ... and the first thing is:
You mus't not use the -r option (change the frame rate) ... otherwise Audio and Video goes out of sync. Anything else I left unchanged as serviio logs the ffmpeg command line (changing the audio from DTS to AC3 and change the audio rate).
I already converted a complete 3 hours HD Film without problem. To disable this re-muxing completely (If the Developer(s) decide to implement such a feature in the new release) I leave to the Developer(s) ...
As there are lots of people having problems (also in this forum) with HD streaming and stuttering playback I personally think this could solve many problems.
Clip the bitrate: The bitrate is not clipped, if I set it to 10000k it well goes up to 11000k seen during re-muxing ... it could be similar like tsMuxer does it - and it does it very well - but I can't say any word on how it does it ... ;)
thx
Post Wed Nov 17, 2010 9:19 am
great. Thanks for investigating. Can you post examples of ffmpeg -i <file> for a file before remuzing and after remuxing with a bitrate lower than the original and higher than the original?
I've created a ticket: http://bitbucket.org/xnejp03/serviio/is ... r-remuxing
tombert
Post Wed Nov 17, 2010 9:34 am
You mean I should upload three files? original, lower and higher?
PS: created an account in bitbucket - now I'am able to upload files ...
Post Wed Nov 17, 2010 9:35 am
Try transcoding with and without -muxrate option:
FFmpeg(Serviio) version SVN-r23012
ffmpeg -i C:\Sample\Sintel_DivXPlusHD_2Titles_6500kbps.mkv
C:\Serviio\lib>C:\Serviio\lib\ffmpeg.exe -i C:\Sample\Sintel_DivXPlusHD_2Titles_6500kbps.mkv
FFmpeg version SVN-r23012, Copyright (c) 2000-2010 the FFmpeg developers
  built on May  3 2010 19:05:24 with gcc 3.4.5 (mingw-vista special r3)
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-w32threads --extra-ldflags=-L/static/lib --extra-cflags=-I/static/include
  libavutil     50.15. 0 / 50.15. 0
  libavcodec    52.66. 0 / 52.66. 0
  libavformat   52.62. 0 / 52.62. 0
  libavdevice   52. 2. 0 / 52. 2. 0
  libswscale     0.10. 0 /  0.10. 0
[matroska @ 013fcf60]Unknown entry 0xC0
[matroska @ 013fcf60]Unknown entry 0xC1
[matroska @ 013fcf60]Unknown entry 0xC6
    Last message repeated 3 times
[matroska @ 013fcf60]Unknown entry 0x7446
[matroska @ 013fcf60]Unknown entry 0x4661
[matroska @ 013fcf60]Unknown entry 0x4662
[matroska @ 013fcf60]Unknown entry 0x2AD1D3
[matroska @ 013fcf60]max_analyze_duration reached
[matroska @ 013fcf60]Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 48.00 (48/1)-> 24.00 (48/2)
Input #0, matroska, from 'C:\Sample\Sintel_DivXPlusHD_2Titles_6500kbps.mkv':
    title           : Sintel
    TITLE           : Sintel
    TITLE/URL       : http://durian.blender.org/about/
    ARTIST          : Durian Blender Open Movie Project
    PRODUCER        : Ton Roosendaal
    COPYRIGHT       : Copyright Blender Foundation | durian.blender.org
    TERMS_OF_USE    : Creative Commons Attribution 3.0 License
    TERMS_OF_USE/URL: http://creativecommons.org/licenses/by/3.0/
    COMMENT         : Encoded in DivX Plus HD!
    License_newathu.ttf: Open Font License for New Athena Unicode, version 3.40, January 2009 (and laterversions)
Copyright (c) 2004-2009, American Philological Association(http://apaclassics.org, apaclassics@sas/upenn.edu),with Reserved Font Name <New Athena Unicode>.
Information and download available at http://apagreekkeys.org.
This Font Software is licensed under the SIL Open Font License, Version 1.1.
This license is copied below, and is also available with a FAQ at:
http://scripts.sil.org/OFL
SIL OPEN FONT LICENSE Version 1.1 - 26 February 2007
PREAMBLE
The goals of the Open Font License (OFL) are to stimulate worldwide development of collaborative font projects, to support the font creation efforts of academic and linguistic communities, and to provide a free and open framework in which fonts may be shared and improved in partnership with others.
The OFL allows the licensed    License_AlteHaasGroteskRegular.ttf: Alte Haas Grotesk is a typeface that look like an helvetica printed in an old Muller-Brockmann Book.
These fonts are freeware and can be distributed as long as they aretogether with this text file.
I would appreciate very much to see what you have done with it anyway.
yann le coroller
www.yannlecoroller.com
yann@lecoroller.com
  Duration: 00:15:08.91, start: 0.000000, bitrate: 192 kb/s
    Chapter #0.0: start 11.167000, end 40.417000
      title           : Pr+¦logo
    Chapter #0.1: start 40.417000, end 51.875000
      title           : campo de nieve
    Chapter #0.2: start 51.875000, end 112.167000
      title           : Ataque!
    Chapter #0.3: start 112.167000, end 162.625000
      title           : Rescatados
    Chapter #0.4: start 162.625000, end 214.459000
      title           : Ciudad
    Chapter #0.5: start 214.459000, end 360.000000
      title           : Nuevo Amigo
    Chapter #0.6: start 360.000000, end 447.667000
      title           : De Salida
    Chapter #0.7: start 447.667000, end 483.000000
      title           : De Nuevo en la Choza
    Chapter #0.8: start 483.000000, end 670.000000
      title           : Cueva
    Chapter #0.9: start 670.000000, end 755.000000
      title           : Escapar
    Chapter #0.10: start 755.000000, end 908.000000
      title           : Cr+¬ditos
    Stream #0.0(eng): Video: h264, yuv420p, 1920x872 [PAR 1:1 DAR 240:109], 24.39 fps, 24 tbr, 1k tbn, 48 tbc
      title           : Sintel
    Stream #0.1(eng): Audio: mp3, 48000 Hz, 2 channels, s16, 192 kb/s
      title           : MP3 Stereo
    Stream #0.2(eng): Audio: aac, 48000 Hz, 5.1, s16
      title           : AAC Surround
    Stream #0.3(eng): Subtitle: 0x0000
      title           : English
    Stream #0.4(ger): Subtitle: 0x0000
      title           : German
    Stream #0.5(spa): Subtitle: 0x0000
      title           : Spanish
    Stream #0.6(fre): Subtitle: 0x0000
      title           : French
    Stream #0.7(dut): Subtitle: 0x0000
      title           : Dutch
    Stream #0.8(por): Subtitle: 0x0000
      title           : Portuguese
    Stream #0.9: Attachment: 0x0000
      filename        : AlteHaasGroteskRegular.ttf
    Stream #0.10: Attachment: 0x0000
    Stream #0.11: Attachment: 0x0000
    Stream #0.12: Attachment: 0x0000
    Stream #0.13: Attachment: 0x0000
    Stream #0.14: Attachment: 0x0000
ffmpeg -i C:\Sample\Sintel_DivXPlusHD_2Titles_6500kbps.mkv -vcodec copy -acodec ac3 -ab 192k -vbsf h264_mp4toannexb -f mpegts C:\SampleTest_without.ts
Resulting:
C:\Serviio\lib>C:\Serviio\lib\ffmpeg.exe -i C:\Sample\Test_without.ts
Seems stream 0 codec frame rate differs from container frame rate: 48.00 (48/1)-> 1000.00 (1000/1)
Input #0, mpegts, from 'C:\Sample\Test_without.ts':
Duration: 00:15:08.87, start: 1.400000, bitrate: 7051 kb/s
Program 1 Service01
provider_name : FFmpeg
Stream #0.0[0x100]: Video: h264, yuv420p, 1920x872 [PAR 1:1 DAR 240:109], 24 fps, 1k tbr, 90k tbn, 48 tbc
Stream #0.1[0x101](eng): Audio: ac3, 48000 Hz, 5.1, s16, 192 kb/s
ffmpeg -i C:\Sample\Sintel_DivXPlusHD_2Titles_6500kbps.mkv -vcodec copy -acodec ac3 -ab 192k -vbsf h264_mp4toannexb -muxrate 10000k -f mpegts C:\Sample\Test.ts
Resulting:
C:\Serviio\lib>C:\Serviio\lib\ffmpeg.exe -i C:\Sample\Test_with.ts
Input #0, mpegts, from 'C:\Sample\Test_with.ts':
Duration: 00:15:08.87, start: 1.400000, bitrate: 10590 kb/s
Program 1 Service01
The bitrate is forced not "clipped"
with lower bitrate 4000k than original:
ffmpeg -i C:\Sample\Sintel_DivXPlusHD_2Titles_6500kbps.mkv -vcodec copy -acodec ac3 -ab 192k -vbsf h264_mp4toannexb -muxrate 4000k -f mpegts C:\Sample\Test.ts
C:\Serviio\lib>C:\Serviio\lib\ffmpeg.exe -i C:\Sample\Test.ts
Input #0, mpegts, from 'C:\Sample\Test.ts':
Duration: 00:15:08.87, start: 1.400000, bitrate: 6806 kb/s
Program 1 Service01
The result is strange for lower bitrate
tombert
Post Wed Nov 17, 2010 9:45 am
Hi Illico ... can you upload these files to zip or shall I do it (then I would download a trailer from the internet somewhere)?
Post Wed Nov 17, 2010 9:48 am
You can found the Sintel movie here:
http://www.divx.com/en/electronics/solu ... s-hd/video
Direct link
So you and zip could also test this...
tombert
Post Wed Nov 17, 2010 9:52 am
Ok - I'll do ...
thx for the movie link.
Post Wed Nov 17, 2010 9:55 am
tombert wrote:You mean I should upload three files? original, lower and higher?
Nope, I don't need the files, just output from the ffmpeg commands run on your machine.
Return to Feature requests
Users browsing this forum: Baidu [Spider] and 17 guests
