Follow Symlinks?
jlcooke
Post Sat Jun 09, 2012 12:36 pm
Follow Symlinks?
I have a dir a update daily with symlinks to 20 randomly selected albums.
But Serviio doesn't show those albums inside. Can this feature be added please?
Post Sat Jun 09, 2012 3:45 pm
Re: Follow Symlinks?
it should follow symlinks. What OS are you using?
jlcooke
Post Sat Jun 09, 2012 11:28 pm
Fedora release 15 (Lovelock)
Does it matter any that the symlink is to a file potentially scanned elsewhere?
eg.
/mnt/DailyRotation/AlbumA --> /mnt/FLAC/ArtistX/AlbumA
Where /mnt/FLAC and /mnt/DailyRotation are both music source directories configured using Servio PHP Console 0.6
So, basically I'm asking Serviio to list AlbumA/*.flac as under /mnt/FLAC/ArtistX/AlbumA (dnla:Music/FLAC/ArtistX/AlbumA) and /mnt/DailyRotation/AlbumA (dnla:Music/DailyRotation/AlbumX)
Post Sun Jun 10, 2012 12:55 am
you should see the file twice. did you enable detailed log to see if the files are scanned?
jlcooke
Post Sun Jun 10, 2012 3:27 am
I had to edit config/log4j.xml to capture this ... log rotation went by too quickly. :)
<param name="MaxFileSize" value="50MB" />
<param name="MaxBackupIndex" value="100" />
Found my issue. I had a type in the path of my source directory ... missing a space. Duh!
Any chance a outputting a WARN level message when a source dir is:
a) unlistable (read/execute)
b) does not exist (due to braindead user error!)
Post Sun Jun 10, 2012 10:08 am
good idea, added.
patters
Post Thu Jun 14, 2012 10:51 pm
Yes, great idea. That has caught me out before a few times when I forget that on my NAS the folder names are case-sensitive.
Return to Feature requests
