veetle plugin success !!
trigu75
Post Mon Jun 11, 2012 11:39 am
kind of ..
using perl and unix I managed to create a script that gets all the streams sources and names and creates a EXTM3U playlist
and used the playlist plugin to read the extm3u file , and I'm able see all beetle channels on my TV
the question , how can I make a plugin that executes my script and tells serviio to "refresh" the playlist , this way the list gets updated with the latest streams ?
, I'll post the scripts soon , 3 files , a perl script is used to get http requests
a unix script that parses the http , gets some info , executes a 3rd script that gets the stream info from the web (again using the perl script) and output a m3u file having all the information
this file is loaded in serviio as web resources as a normal playlist (using the playlist plugin)
Post Mon Jun 11, 2012 12:17 pm
Re: veetle plugin success !!
couldn't all this be done via Groovy?
trigu75
Post Mon Jun 11, 2012 12:19 pm
and here are the files , you need the playlist plugin installed ..
you can use them to create m3u files
on linux or osx , extract the files to some directory (home directory)
then run
sh vetest > ent.m3u
for entretaomment category
sh veshow > show.m3u
for shows category
then edit the m3u file , remove the 6 first lines , add #EXTM3U to the beginning
then on serviio add the playlist to the web resource
example :
http://-SW-uhttp://192.168.0.15/ent.m3u ... O-SW-lLIVE
name veetle movies
and that's it , all is there ... now , from time to time you rerun the scripts , to get the updated list ... , and then go back to servo . uncheck the playlist , save check the playlist , save
maybe using this base someone else can make a better , real plugin
m3u gotten file should look like :
#EXTM3U
#EXTINF:-1,2012 FILMS
http://213.254.202.139/flv/4f91c2005baa6
#EXTINF:-1,BR2-EPICTV II malu00e8na
http://213.254.202.144/flv/4f12ef90bad73
#EXTINF:-1,u026a-u0280u1d07u029fu1d00x-u029cu1d07u0280u1d07.u0299u029fu1d0fu0262su1d18u1d0fu1d1b.u1d04u1d0fu1d0d
http://213.254.202.149/flv/4fab772264e27
#EXTINF:-1,ACTIu047aN Mu047aVIES
http://213.254.202.13/flv/4f9250c819808
#EXTINF:-1,*The Dictator & BattleShip*
http://89.149.156.211/flv/4f5f56aa32e85
#EXTINF:-1,Watch Movies Online at moviesanytime.u1d04u1d0fu1d0d
http://89.149.156.210/flv/4f57e9a486e54
#EXTINF:-1,PLUS....BATTLESHIP>>>.....
http://213.254.202.13/flv/4dfa967c9fdf0
#EXTINF:-1,~ Random Movies! ~
http://213.254.202.13/flv/4fbc50c46fcac
#EXTINF:-1,Teeburd's Lounge
http://213.254.202.141/flv/4f85e06f64e17
#EXTINF:-1,u2606u2606 Marvel u2606u2606
http://213.254.202.144/flv/4f5fb15db5d6b
veetle.tar.gz
(651 Bytes) Downloaded 1750 times
trigu75
Post Mon Jun 11, 2012 12:24 pm
I guess it can , I just don't know groovy :)
I sent the way I get it to work ... maybe someone that knows groovy cam "translate" it to
and make this a better plugin .. (the thumbnail can be also be extracted , is $5 inside the awk that creates the ourput , I just didn't use it on m3u
trigu75
Post Mon Jun 11, 2012 4:52 pm
in groovy
mport groovy.json.JsonSlurper
def restResponse = new URL("http://veetle.com/index.php/listing/ajaxStreamByCategory/10/0/20/0").text
// Parse the response
def list = new JsonSlurper().parseText( restResponse )
list.payload.each {println it}
returns 20 channels , from there list.payload.channelId and list.payload.description are needed ...
channelID then is used again to get the stream link
which is the payload of http://veetle.com/index.php/stream/ajaxStreamLocation/ ' channelId ' /flash
if I knew how to put all that together in groovy then we already had the plugin :)
if you change the 20 and put 100 you will get 100 channels data
it's simple in groovy ... I wish I knew more ..
vaha
Post Mon Jun 11, 2012 9:57 pm
Thanks bro!! :)
trigu75
Post Tue Jun 12, 2012 5:23 am
ok .. looking at the ap web resource plugin , learning from it ..
I'm getting to it ..
in groovy
this , makes a m3u file from veetle entertainment category
import groovy.json.JsonSlurper
// Example Response Data
def restResponse = new URL("http://veetle.com/index.php/listing/ajaxStreamByCategory/10/0/199/0").text
def toal = list.totalCount as int // number of channels gotten
println "#EXTM3U"
for ( i = 0; i < toal ; i++) {
println "#EXTINF:-1,"+ list.payload.description [i]
def test = new URL ("http://veetle.com/index.php/stream/ajaxStreamLocation/" + list.payload.channelId [i]+"/flash").text
def link = new JsonSlurper().parseText( test )
println link.payload
just run it using groovy but output the results to a m3u file
so I guess I need to output that to serviio , and that's the way the plugging will get ready
trigu75
Post Tue Jun 12, 2012 10:04 am
is this the way to do it??
please help ,
// Print them out to make sure
List<WebResourceItem> items = []
def itemsAdded = 0;
for( int i = 0; i < toal ; i++) {
String programName = list.payload.description [i]
String programID = list.payload.channelId [i]
String thumbu= list.payload.thumbnailUrl [i]
WebResourceItem item = new WebResourceItem(thumbnail: thumbu, title: programName, AdditionalInfo: ['programID':programID])
println "item = $item"
items << item
itemsAdded++
return new WebResourceContainer(title: pageTitle, items: items)
ContentURLContainer extractUrl(WebResourceItem item, PreferredQuality requestedQuality) {
String programID = item.getAdditionalInfo()['programID']
assert programID != null
def test = new URL ("http://veetle.com/index.php/stream/ajaxStreamLocation/" + programID + "/flash").text
String contentUrl = link.payload
String thumbUrl = item.thumbnail
return new ContentURLContainer(fileType: MediaFileType.VIDEO, contentUrl: contentUrl, thumbnailUrl: thumbUrl, live: true)
this is the output of LIST , and the programID is then transformed to the stream file
item = thumbnail: http://image.veetle.com//channel_logos/ ... 28x297.jpg, title: Broadcasting LIVE, AdditionalInfo: ['programID':4fc755eeb8cb6]
item = thumbnail: http://image.veetle.com/channel_logos/5 ... 28x297.jpg, title: So You Would Like To Be on TV http://www.theagent.biz, AdditionalInfo: ['programID':4d2b5a98a9505]
item = thumbnail: http://image.veetle.com//channel_logos/ ... 28x297.jpg, title: BREAKING BAD STAFFEL 1-4 - Solltet Ihr Probleme mit dem Stream haben dr?ckt mal das blaue "HD"-K?stchen, Viel Spa?!, AdditionalInfo: ['programID':4f26ebaa8ab1b]
item = thumbnail: http://image.veetle.com/channel_logos/c ... 28x297.jpg, title: Television de La Serena Chile, AdditionalInfo: ['programID':4c5e177728cc4]
item = thumbnail: http://image.veetle.com/channel_thumbs/ ... 28x297.jpg, title: Broadcasting live, AdditionalInfo: ['programID':4f9673fb112c2]
item = thumbnail: http://image.veetle.com//channel_logos/ ... 28x297.jpg, title: The Gift of Everlasting Life, AdditionalInfo: ['programID':4f74dfaed6f87]
item = thumbnail: http://image.veetle.com//channel_logos/ ... 28x297.jpg, title: tiha44ever blogspot com, AdditionalInfo: ['programID':4fd4c7aaaf095]
Post Tue Jun 12, 2012 10:34 am
that looks good, the first part has to be in a proper method
WebResourceContainer extractItems(URL resourceUrl, int maxItemsToRetrieve)
trigu75
Post Tue Jun 12, 2012 11:46 am
ok .. this is the code ... veetle gets added , no errors in log
just
Lion:log nurielt$ 2012-06-12 14:36:17,704 INFO [PluginCompilerThread] Added Web Resouce plugin veetle (test1.groovy)
but for some reason is empty
import org.serviio.library.metadata.*
import org.serviio.library.online.*
import org.serviio.util.*
class veetle extends WebResourceUrlExtractor {
        final VALID_FEED_URL = '^(?:http?://)?(?:www\\.)?veetle\\.com.*?'
        String getExtractorName() {
                return 'veetle'
        boolean extractorMatches(URL feedUrl) {
                return feedUrl ==~ VALID_FEED_URL
                def itemsAdded = 0;
                        String programID = list.payload.channelID [i]
                        WebResourceItem item = new WebResourceItem( title: programName, additionalInfo: ['programID':programID])
                        items << item
                        itemsAdded++
                return new WebResourceContainer(title: 'http://www.veetle.com', items: items)
                String thumbnailUrl = item.thumbnail
                return new ContentURLContainer(fileType: MediaFileType.VIDEO, contentUrl: contentUrl, thumbnailUrl: thumbnailUrl , live: true)
Post Tue Jun 12, 2012 12:07 pm
did you add a URL to the console as a video WebResource ? Should be one to match the VALID_FEED_URL regex.
trigu75
Post Tue Jun 12, 2012 12:28 pm
yes ,
tried http://www.veetle.com
but I can't see is using the plugin
trigu75
Post Tue Jun 12, 2012 1:43 pm
ok .. changed a bit the code .. got it to load :)
but now I got this , so I'm checking all again :P
java.io.IOException: Unexpected error while invoking plugin (veetle): Expected a value on line: 1, column: 57975.
But got an unterminated object.
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:169)
at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:184)
at org.serviio.library.online.metadata.FeedUpdaterThread.getOnlineItems(FeedUpdaterThread.java:158)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:95)
Caused by: groovy.json.JsonException: Expected a value on line: 1, column: 57975.
at groovy.json.JsonSlurper.parseObject(JsonSlurper.java:222)
at groovy.json.JsonSlurper.parseArray(JsonSlurper.java:114)
at groovy.json.JsonSlurper.parseObject(JsonSlurper.java:235)
at groovy.json.JsonSlurper.parse(JsonSlurper.java:75)
at groovy.json.JsonSlurper.parseText(JsonSlurper.java:59)
at sun.reflect.GeneratedMethodAccessor88.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoCachedMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:230)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
at veetle.extractItems(test1.groovy:26)
at org.serviio.library.online.WebResourceUrlExtractor.parseWebResource(WebResourceUrlExtractor.java:29)
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:56)
... 4 more
Post Tue Jun 12, 2012 3:03 pm
the JSON object is not correct
trigu75
Post Tue Jun 12, 2012 4:14 pm
I finished
and works like a charm .. finally , serviio veetle
just put it in plugins folder , and add web resource address http://www.veetle.com and that's it
a few seconds later (just think it actually query every channel stream url)
it gets all the channels loaded :)
ENJOY !!!!!!!!!!!
updated , veetleshow.groovy added also for show category , web resource url , type http://www.veetles.com , name beetle shows
Currently lists channels from the movies area ..
I'll make another one for the sport area , and for the TV shows area and post it
now I need to work on adding the thumbnails which I disabled cause it gave me some errors ..
and one question ... what do I need to add to it so it gets refreshed with new or non working streams? (currently , to get the list updated it's enough the uncheck and check back again
veetleshow.groovy
(1.81 KiB) Downloaded 1797 times
veetle.groovy
(1.81 KiB) Downloaded 1801 times
Post Tue Jun 12, 2012 7:37 pm
you can give the URL and expiry date which would expire the whole feed on that date. otherwise it'll recheck in the interval given in the console (cache expiry).
Also make sure you only get the number of items the user requires, and not all (which could be hundreds).
good job :-) Once you have a final version upload it to the Available plugins area.
trigu75
Post Wed Jun 13, 2012 8:19 am
posted in available plugins my files ..
thumbnails work , and TV shows gets you 20 most popular , while movies gets you 40 most popular .. and used the usernames instead of description which contained a lot of garbage
Post Wed Jun 13, 2012 10:05 am
trigu75 wrote:thumbnails work , and TV shows gets you 20 most popular , while movies gets you 40 most popular .. and used the usernames instead of description which contained a lot of garbage
You should meet the user's selected number of items to retrieve, you are getting the number in the mehod prameter. Look at Channel4 plugin to see what I've done
trigu75
Post Wed Jun 13, 2012 12:24 pm
done ... current plugin (in available plugins) , any number you add after / is the number of channels you ask to retrieve ..
if the payload is bigger than the requested , then the payload becomes the number of requested items , else it will use the amount of channels that can be retrieved (which are less than the number the user asked)
sometimes I see in the log this error which I have no idea how to solve
the plugins work fine what so ever .. and sometimes this error appear ..
java.io.IOException: Unexpected error while invoking plugin (veetle): Lexing failed on line: 1, column: 2, while reading '�', no possible valid JSON value or punctuation could be recognized.
Caused by: groovy.json.JsonException: Lexing failed on line: 1, column: 2, while reading '�', no possible valid JSON value or punctuation could be recognized.
at groovy.json.JsonLexer.nextToken(JsonLexer.java:84)
at groovy.json.JsonSlurper.parse(JsonSlurper.java:73)
at sun.reflect.GeneratedMethodAccessor39.invoke(Unknown Source)
at veetleis.extractItems(veetle.groovy:26)
... 4 more
Post Wed Jun 13, 2012 1:24 pm
that looks like dodgy json document, you should try to retrieve it manually and check what form it has
Return to Plugin development
