Updating library issues
Halfkast
Post Mon Jun 11, 2012 4:46 am
Hi all =)
Up until about an hour ago and after 6 solid months of Serviio use i started having a few issues as per below:
1. When i add a new folder/file to the shared folder that i have shared in the serviio 6.2 console it does not appear on any of my other devices...
2. I removed all shared folders from the Serviio 6.2 console and then created a new folder, shared it in Serviio console 6.2 and added just a few files - (around 6 movies) waited about an hour and still nothing - in fact my devices (xbox 360, ps3, smsung tv) still show the old shared folders and i am still able to watch the files that were a part of them...
3. Once i created the new shared folder and added the 6 movies to it i clicked on the "show status" button under the library, shared folders tab and noticed the next to the "checking for new files" status it appears to be checking for new files in other places on my computer - for example it is checkin gall my mp3 files... is this normal?? i thought Serviio would only check the folders that i have selected to share in the console and NOT random folders on my computer... why is this happening and how can i make this stop?
Before all of this started to occur it was working fine - i could drag a file/folder into the folder where i added to the shared folders section in the serviio 6.2 console and about 5 - 10 mins later all of my devices would pick it up.
Now its like it has just frozen and will not pick up any new files nor will it let me remove the old file/folder structure that i had in order to create a new one...
I have increased the pause between refreshes in an attempt to resolve this issue to 20mins but still no luck....
Please help!
Thanks guys =)
Post Mon Jun 11, 2012 3:38 pm
Re: Updating library issues
post detailed log. It should not look through your folders that you had not shared.
Halfkast
Post Thu Jun 14, 2012 11:48 am
Another issue i am having is that i click save to save the new folders i have added or removed and Serviio 0.6.2 freezes for about 10 mins then becomes useable, as in i can add or remove folders to share.
Once i reboot my computer serviio defaults back to a configuration of shares that i previously had - so in other words its not saving any changes that i am making....
How do i collect the logs for Serviio? Please give a detailed step by step and i will post ASAP.
Sorry to be a noob...
Thanks!
Halfkast
Post Thu Jun 14, 2012 12:04 pm
OK found the logs - i will post 3 types
This is the derby logs....
Thu Jun 14 21:42:53 EST 2012:
Booting Derby version The Apache Software Foundation - Apache Derby - 10.8.2.2 - (1181258): instance a816c00e-0137-eacd-9f47-000065a59be2
on database directory C:\Program Files (x86)\Serviio\library\db with class loader sun.misc.Launcher$AppClassLoader@138d107f
Loaded from file:/C:/Program%20Files%20(x86)/Serviio/lib/derby.jar
java.vendor=Sun Microsystems Inc.
java.runtime.version=1.6.0_23-b05
user.dir=C:\Program Files (x86)\Serviio\bin
derby.system.home=C:\Program Files (x86)\Serviio\bin\\..\library
derby.stream.error.file=../log/derby.log
Database Class Loader started - derby.database.classpath=''
Thu Jun 14 21:44:58 EST 2012 Thread[LibraryAdditionsCheckerThread,2,main] (XID = 1781202330), (SESSIONID = 1), (DATABASE = db), (DRDAID = null), Cleanup action starting
Thu Jun 14 21:44:58 EST 2012 Thread[LibraryAdditionsCheckerThread,2,main] (XID = 1781202330), (SESSIONID = 1), (DATABASE = db), (DRDAID = null), Failed Statement is: SELECT DISTINCT(a.id), a.title, a.sort_title FROM music_album a, person_role pr, person p WHERE pr.music_album_id = a.id AND p.id = pr.person_id AND pr.role_type = ? AND LCASE(p.name) = LCASE(?) AND LCASE(a.title) = LCASE(?) with 3 parameters begin parameter #1: ALBUM_ARTIST :end parameter begin parameter #2: Unknown :end parameter begin parameter #3: Unknown :end parameter
ERROR 08000: Connection closed by unknown interrupt.
at org.apache.derby.iapi.util.InterruptStatus.setInterrupted(Unknown Source)
at org.apache.derby.iapi.util.InterruptStatus.throwIf(Unknown Source)
at org.apache.derby.impl.sql.execute.BasicNoPutResultSetImpl.checkCancellationFlag(Unknown Source)
at org.apache.derby.impl.sql.execute.BulkTableScanResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.ProjectRestrictResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.JoinResultSet.openCore(Unknown Source)
at org.apache.derby.impl.sql.execute.ProjectRestrictResultSet.openCore(Unknown Source)
at org.apache.derby.impl.sql.execute.SortResultSet.openCore(Unknown Source)
at org.apache.derby.impl.sql.execute.BasicNoPutResultSetImpl.open(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.executeStmt(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.execute(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedStatement.executeStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeQuery(Unknown Source)
at org.serviio.library.dao.MusicAlbumDAOImpl.findAlbum(MusicAlbumDAOImpl.java:87)
at org.serviio.library.local.service.AudioService.findOrCreateAlbum(AudioService.java:467)
at org.serviio.library.local.service.AudioService.addMusicTrackToLibrary(AudioService.java:62)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:154)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:128)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:78)
Stack traces for all live threads:
Thread name=Restlet-2110683211 id=15 priority=5 state=TIMED_WAITING isdaemon=true
java.lang.Thread.sleep(Native Method)
org.serviio.util.ThreadUtils.currentThreadSleep(ThreadUtils.java:16)
org.serviio.library.AbstractLibraryManager.stopThread(AbstractLibraryManager.java:31)
org.serviio.library.local.LibraryManager.stopLibraryAdditionsCheckerThread(LibraryManager.java:130)
org.serviio.library.local.LibraryManager.pauseUpdates(LibraryManager.java:139)
org.serviio.ui.resources.server.RepositoryServerResource.save(RepositoryServerResource.java:110)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
java.lang.reflect.Method.invoke(Unknown Source)
org.restlet.resource.ServerResource.doHandle(ServerResource.java:446)
org.restlet.resource.ServerResource.put(ServerResource.java:1170)
org.restlet.resource.ServerResource.doHandle(ServerResource.java:521)
org.restlet.resource.ServerResource.doNegotiatedHandle(ServerResource.java:587)
org.restlet.resource.ServerResource.doConditionalHandle(ServerResource.java:299)
org.restlet.resource.ServerResource.handle(ServerResource.java:846)
org.restlet.resource.Finder.handle(Finder.java:510)
org.restlet.routing.Filter.doHandle(Filter.java:156)
org.restlet.routing.Filter.handle(Filter.java:203)
org.restlet.routing.Router.doHandle(Router.java:497)
org.restlet.routing.Router.handle(Router.java:737)
org.restlet.engine.application.StatusFilter.doHandle(StatusFilter.java:151)
org.restlet.engine.ChainHelper.handle(ChainHelper.java:111)
org.restlet.engine.application.ApplicationHelper.handle(ApplicationHelper.java:72)
org.restlet.Application.handle(Application.java:388)
org.restlet.Component.handle(Component.java:388)
org.restlet.Server.handle(Server.java:488)
org.restlet.engine.http.connector.BaseServerHelper.handle(BaseServerHelper.java:158)
org.restlet.engine.http.connector.BaseServerHelper.handleInbound(BaseServerHelper.java:167)
org.restlet.engine.http.connector.BaseHelper.handleNextInbound(BaseHelper.java:418)
org.restlet.engine.http.connector.Connection.readMessages(Connection.java:695)
org.restlet.engine.http.connector.Controller$2.run(Controller.java:95)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
java.lang.Thread.run(Unknown Source)
Thread name=pool-2-thread-3 id=49 priority=5 state=WAITING isdaemon=false
sun.misc.Unsafe.park(Native Method)
java.util.concurrent.locks.LockSupport.park(Unknown Source)
java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(Unknown Source)
java.util.concurrent.LinkedBlockingQueue.take(Unknown Source)
java.util.concurrent.ThreadPoolExecutor.getTask(Unknown Source)
Thread name=Restlet-1310188746 id=13 priority=5 state=TIMED_WAITING isdaemon=true
org.restlet.engine.http.connector.Controller.run(Controller.java:250)
java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
java.util.concurrent.FutureTask.run(Unknown Source)
Thread name=LibraryAdditionsCheckerThread id=56 priority=2 state=RUNNABLE isdaemon=true
java.lang.Thread.dumpThreads(Native Method)
java.lang.Thread.getAllStackTraces(Unknown Source)
org.apache.derby.iapi.error.ThreadDump.getStackDumpString(Unknown Source)
org.apache.derby.iapi.error.ExceptionUtil$1.run(Unknown Source)
java.security.AccessController.doPrivileged(Native Method)
org.apache.derby.iapi.error.ExceptionUtil.dumpThreads(Unknown Source)
org.apache.derby.iapi.services.context.ContextManager.cleanupOnError(Unknown Source)
org.apache.derby.impl.jdbc.TransactionResourceImpl.cleanupOnError(Unknown Source)
org.apache.derby.impl.jdbc.TransactionResourceImpl.handleException(Unknown Source)
org.apache.derby.impl.jdbc.EmbedConnection.handleException(Unknown Source)
org.apache.derby.impl.jdbc.ConnectionChild.handleException(Unknown Source)
Thread name=LibraryUpdatesCheckerThread id=57 priority=1 state=RUNNABLE isdaemon=true
java.io.WinNTFileSystem.getBooleanAttributes(Native Method)
java.io.File.isHidden(Unknown Source)
org.serviio.library.local.metadata.extractor.CoverImageInFolderExtractor$1.accept(CoverImageInFolderExtractor.java:93)
java.io.File.listFiles(Unknown Source)
org.serviio.library.local.metadata.extractor.CoverImageInFolderExtractor.getMetadataFile(CoverImageInFolderExtractor.java:88)
org.serviio.library.local.metadata.extractor.AbstractLocalFileExtractor.isMetadataUpdated(AbstractLocalFileExtractor.java:68)
org.serviio.library.local.metadata.LibraryUpdatesCheckerThread.searchForRemovedAndUpdatedFiles(LibraryUpdatesCheckerThread.java:189)
org.serviio.library.local.metadata.LibraryUpdatesCheckerThread.run(LibraryUpdatesCheckerThread.java:96)
Thread name=ServioThread-2-DiscoverySSDPMessageListener id=30 priority=10 state=RUNNABLE isdaemon=true
java.net.PlainDatagramSocketImpl.receive0(Native Method)
java.net.PlainDatagramSocketImpl.receive(Unknown Source)
java.net.DatagramSocket.receive(Unknown Source)
org.serviio.util.MultiCastUtils.receive(MultiCastUtils.java:91)
org.serviio.upnp.discovery.DiscoverySSDPMessageListener.listenForMulticastMessages(DiscoverySSDPMessageListener.java:120)
org.serviio.upnp.discovery.DiscoverySSDPMessageListener.run(DiscoverySSDPMessageListener.java:94)
Thread name=Reference Handler id=2 priority=10 state=WAITING isdaemon=true
java.lang.Object.wait(Native Method)
java.lang.Object.wait(Object.java:485)
java.lang.ref.Reference$ReferenceHandler.run(Unknown Source)
Thread name=Restlet-368471295 id=14 priority=5 state=RUNNABLE isdaemon=false
java.net.PlainSocketImpl.socketAccept(Native Method)
java.net.PlainSocketImpl.accept(Unknown Source)
java.net.ServerSocket.implAccept(Unknown Source)
java.net.ServerSocket.accept(Unknown Source)
org.restlet.engine.http.connector.Acceptor.run(Acceptor.java:91)
Thread name=AWT-Windows id=70 priority=6 state=RUNNABLE isdaemon=true
sun.awt.windows.WToolkit.eventLoop(Native Method)
sun.awt.windows.WToolkit.run(Unknown Source)
Thread name=ServioThread-3-SubscriptionExpiryChecker id=31 priority=5 state=TIMED_WAITING isdaemon=true
org.serviio.upnp.eventing.EventSubscriptionExpirationChecker.run(EventSubscriptionExpirationChecker.java:105)
Thread name=derby.rawStoreDaemon id=18 priority=5 state=TIMED_WAITING isdaemon=true
org.apache.derby.impl.services.daemon.BasicDaemon.rest(Unknown Source)
org.apache.derby.impl.services.daemon.BasicDaemon.run(Unknown Source)
Thread name=ServioThread-1-CDS library notifier id=23 priority=5 state=TIMED_WAITING isdaemon=true
org.serviio.library.metadata.AbstractCDSLibraryIndexingListener$CDSNotifierThread.run(AbstractCDSLibraryIndexingListener.java:139)
Thread name=Thread-15 id=52 priority=5 state=RUNNABLE isdaemon=true
java.net.SocketInputStream.socketRead0(Native Method)
java.net.SocketInputStream.read(Unknown Source)
org.apache.http.impl.io.AbstractSessionInputBuffer.fillBuffer(AbstractSessionInputBuffer.java:130)
org.apache.http.impl.io.SocketInputBuffer.fillBuffer(SocketInputBuffer.java:127)
org.apache.http.impl.io.AbstractSessionInputBuffer.readLine(AbstractSessionInputBuffer.java:233)
org.apache.http.impl.io.HttpRequestParser.parseHead(HttpRequestParser.java:102)
org.apache.http.impl.io.AbstractMessageParser.parse(AbstractMessageParser.java:210)
org.apache.http.impl.AbstractHttpServerConnection.receiveRequestHeader(AbstractHttpServerConnection.java:232)
org.apache.http.protocol.HttpService.handleRequest(HttpService.java:160)
org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:187)
Thread name=ServioThread-19-CDS library notifier id=54 priority=5 state=TIMED_WAITING isdaemon=true
Thread name=PluginCompilerThread id=24 priority=1 state=TIMED_WAITING isdaemon=true
org.serviio.library.online.feed.PluginCompilerThread.run(PluginCompilerThread.java:94)
Thread name=main id=1 priority=5 state=RUNNABLE isdaemon=false
Thread name=Timer-0 id=17 priority=5 state=WAITING isdaemon=true
java.util.TimerThread.mainLoop(Unknown Source)
java.util.TimerThread.run(Unknown Source)
Thread name=FeedUpdaterThread id=55 priority=1 state=TIMED_WAITING isdaemon=true
org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:137)
Thread name=_shutdown_waiter id=9 priority=5 state=TIMED_WAITING isdaemon=true
com.exe4j.runtime.WinLauncher$1.run(Unknown Source)
Thread name=Java2D Disposer id=68 priority=10 state=WAITING isdaemon=true
java.lang.ref.ReferenceQueue.remove(Unknown Source)
sun.java2d.Disposer.run(Unknown Source)
Thread name=pool-2-thread-4 id=50 priority=5 state=WAITING isdaemon=false
Thread name=Finalizer id=3 priority=8 state=WAITING isdaemon=true
java.lang.ref.Finalizer$FinalizerThread.run(Unknown Source)
Thread name=Attach Listener id=4 priority=5 state=RUNNABLE isdaemon=true
Thread name=WebServer id=29 priority=5 state=RUNNABLE isdaemon=false
org.serviio.upnp.webserver.WebServer$RequestListenerThread.run(WebServer.java:141)
Thread name=ServioThread-5-DiscoveryNotifier id=33 priority=10 state=TIMED_WAITING isdaemon=true
org.serviio.upnp.discovery.DiscoveryAdvertisementNotifier.sendAliveToSingleInterface(DiscoveryAdvertisementNotifier.java:189)
org.serviio.upnp.discovery.DiscoveryAdvertisementNotifier.sendAlive(DiscoveryAdvertisementNotifier.java:135)
org.serviio.upnp.discovery.DiscoveryAdvertisementNotifier.run(DiscoveryAdvertisementNotifier.java:97)
Thread name=ServioThread-6-RendererExpirationChecker id=34 priority=10 state=TIMED_WAITING isdaemon=true
org.serviio.renderer.RendererExpirationChecker.run(RendererExpirationChecker.java:87)
Thread name=Instance checker id=12 priority=5 state=RUNNABLE isdaemon=true
org.serviio.ApplicationInstanceManager$1.run(ApplicationInstanceManager.java:78)
Thread name=pool-2-thread-2 id=48 priority=5 state=WAITING isdaemon=false
Thread name=ServioThread-4-EventDispatcher id=32 priority=5 state=TIMED_WAITING isdaemon=true
org.serviio.upnp.eventing.EventDispatcher.run(EventDispatcher.java:162)
Thread name=ElementEventQueue.QProcessor-1 id=20 priority=5 state=WAITING isdaemon=true
org.apache.jcs.engine.control.event.ElementEventQueue.take(ElementEventQueue.java:181)
org.apache.jcs.engine.control.event.ElementEventQueue.access$300(ElementEventQueue.java:35)
org.apache.jcs.engine.control.event.ElementEventQueue$QProcessor.run(ElementEventQueue.java:245)
Thread name=pool-2-thread-1 id=47 priority=5 state=WAITING isdaemon=false
Cleanup action completed
Thu Jun 14 21:44:58 EST 2012 Thread[LibraryAdditionsCheckerThread,2,main] (XID = 1781202348), (SESSIONID = 3), (DATABASE = db), (DRDAID = null), Cleanup action starting
Thu Jun 14 21:44:58 EST 2012 Thread[LibraryAdditionsCheckerThread,2,main] (XID = 1781202348), (SESSIONID = 3), (DATABASE = db), (DRDAID = null), Failed Statement is: UPDATE repository SET last_scanned = ? WHERE id = ? with 2 parameters begin parameter #1: 2012-06-14 21:44:58.345 :end parameter begin parameter #2: 2 :end parameter
at org.apache.derby.impl.sql.execute.TableScanResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.IndexRowToBaseRowResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.NormalizeResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.DMLWriteResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.execute.UpdateResultSet.collectAffectedRows(Unknown Source)
at org.apache.derby.impl.sql.execute.UpdateResultSet.open(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeUpdate(Unknown Source)
at org.serviio.library.dao.RepositoryDAOImpl.markRepositoryAsScanned(RepositoryDAOImpl.java:157)
at org.serviio.library.local.service.RepositoryService.markRepositoryAsScanned(RepositoryService.java:108)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:79)
sun.reflect.GeneratedMethodAccessor50.invoke(Unknown Source)
Halfkast
Post Thu Jun 14, 2012 12:05 pm
More of the Derby log....
Thu Jun 14 21:49:17 EST 2012 Thread[LibraryAdditionsCheckerThread,2,main] (XID = 1781300099), (SESSIONID = 8), (DATABASE = db), (DRDAID = null), Cleanup action starting
Thu Jun 14 21:49:17 EST 2012 Thread[LibraryAdditionsCheckerThread,2,main] (XID = 1781300099), (SESSIONID = 8), (DATABASE = db), (DRDAID = null), Failed Statement is: UPDATE repository SET last_scanned = ? WHERE id = ? with 2 parameters begin parameter #1: 2012-06-14 21:49:17.978 :end parameter begin parameter #2: 2 :end parameter
Thread name=Restlet-2110683211 id=15 priority=5 state=RUNNABLE isdaemon=true
java.io.BufferedInputStream.fill(Unknown Source)
java.io.BufferedInputStream.read(Unknown Source)
org.restlet.engine.http.connector.ServerConnection.readMessage(ServerConnection.java:157)
org.restlet.engine.http.connector.Connection.readMessages(Connection.java:673)
Thread name=LibraryAdditionsCheckerThread id=148 priority=2 state=RUNNABLE isdaemon=true
Thread name=LibraryUpdatesCheckerThread id=149 priority=1 state=TIMED_WAITING isdaemon=true
org.serviio.library.local.metadata.LibraryUpdatesCheckerThread.run(LibraryUpdatesCheckerThread.java:123)
Thread name=Restlet-1424946182 id=146 priority=5 state=TIMED_WAITING isdaemon=true
org.serviio.upnp.discovery.DiscoveryAdvertisementNotifier.run(DiscoveryAdvertisementNotifier.java:108)
Thu Jun 14 21:52:06 EST 2012 Thread[LibraryAdditionsCheckerThread,2,main] (XID = 1781372222), (SESSIONID = 12), (DATABASE = db), (DRDAID = null), Cleanup action starting
Thu Jun 14 21:52:06 EST 2012 Thread[LibraryAdditionsCheckerThread,2,main] (XID = 1781372222), (SESSIONID = 12), (DATABASE = db), (DRDAID = null), Failed Statement is: UPDATE repository SET last_scanned = ? WHERE id = ? with 2 parameters begin parameter #1: 2012-06-14 21:52:06.177 :end parameter begin parameter #2: 2 :end parameter
Thread name=pool-2-thread-5 id=232 priority=5 state=WAITING isdaemon=false
Thread name=pool-2-thread-6 id=316 priority=5 state=WAITING isdaemon=false
Thread name=pool-2-thread-7 id=317 priority=5 state=WAITING isdaemon=false
Thread name=Restlet-1620528117 id=231 priority=5 state=TIMED_WAITING isdaemon=true
java.util.concurrent.locks.LockSupport.parkNanos(Unknown Source)
java.util.concurrent.SynchronousQueue$TransferStack.awaitFulfill(Unknown Source)
java.util.concurrent.SynchronousQueue$TransferStack.transfer(Unknown Source)
java.util.concurrent.SynchronousQueue.poll(Unknown Source)
Thread name=pool-2-thread-10 id=321 priority=5 state=WAITING isdaemon=false
Thread name=pool-2-thread-8 id=319 priority=5 state=WAITING isdaemon=false
Thread name=LibraryUpdatesCheckerThread id=323 priority=1 state=TIMED_WAITING isdaemon=true
org.serviio.library.local.metadata.LibraryUpdatesCheckerThread.searchForRemovedAndUpdatedFiles(LibraryUpdatesCheckerThread.java:158)
Thread name=Keep-Alive-Timer id=332 priority=8 state=TIMED_WAITING isdaemon=true
sun.net.www.http.KeepAliveCache.run(Unknown Source)
Thread name=pool-2-thread-9 id=320 priority=5 state=WAITING isdaemon=false
Thread name=LibraryAdditionsCheckerThread id=322 priority=2 state=RUNNABLE isdaemon=true
Thread name=Thread-268 id=318 priority=5 state=RUNNABLE isdaemon=true
Thu Jun 14 21:52:06 EST 2012 Thread[LibraryUpdatesCheckerThread,1,main] (XID = 1781372300), (SESSIONID = 5), (DATABASE = db), (DRDAID = null), Cleanup action starting
Thu Jun 14 21:52:06 EST 2012 Thread[LibraryUpdatesCheckerThread,1,main] (XID = 1781372300), (SESSIONID = 5), (DATABASE = db), (DRDAID = null), Failed Statement is: SELECT media_item.file_name as file_name, media_item.folder_id as folder_id, repository.folder as root_folder FROM media_item, repository, folder WHERE folder.id = media_item.folder_id AND repository.id = folder.repository_id AND media_item.id = ? with 1 parameters begin parameter #1: 31557 :end parameter
at org.serviio.library.dao.MediaItemDAOImpl.getFile(MediaItemDAOImpl.java:136)
at org.serviio.library.local.service.MediaService.getFile(MediaService.java:45)
at org.serviio.library.local.metadata.LibraryUpdatesCheckerThread.searchForRemovedAndUpdatedFiles(LibraryUpdatesCheckerThread.java:162)
at org.serviio.library.local.metadata.LibraryUpdatesCheckerThread.run(LibraryUpdatesCheckerThread.java:96)
org.serviio.library.local.LibraryManager.stopLibraryUpdatesCheckerThread(LibraryManager.java:122)
org.serviio.library.local.LibraryManager.pauseUpdates(LibraryManager.java:140)
Thread name=Restlet-1424946182 id=146 priority=5 state=RUNNABLE isdaemon=true
Thread name=LibraryUpdatesCheckerThread id=350 priority=1 state=RUNNABLE isdaemon=true
Halfkast
Post Thu Jun 14, 2012 12:08 pm
more of the Derby log....
Thu Jun 14 21:52:07 EST 2012 Thread[LibraryUpdatesCheckerThread,1,main] (XID = 1781372336), (SESSIONID = 10), (DATABASE = db), (DRDAID = null), Cleanup action starting
Thu Jun 14 21:52:07 EST 2012 Thread[LibraryUpdatesCheckerThread,1,main] (XID = 1781372336), (SESSIONID = 10), (DATABASE = db), (DRDAID = null), Failed Statement is: SELECT media_item.file_name as file_name, media_item.folder_id as folder_id, repository.folder as root_folder FROM media_item, repository, folder WHERE folder.id = media_item.folder_id AND repository.id = folder.repository_id AND media_item.id = ? with 1 parameters begin parameter #1: 31558 :end parameter
Thread name=LibraryUpdatesCheckerThread id=356 priority=1 state=RUNNABLE isdaemon=true
Thread name=Restlet-1620528117 id=231 priority=5 state=RUNNABLE isdaemon=true
Thread name=Restlet-302782104 id=361 priority=5 state=TIMED_WAITING isdaemon=true
Thu Jun 14 21:52:12 EST 2012 Thread[LibraryAdditionsCheckerThread,2,main] (XID = 1781372801), (SESSIONID = 14), (DATABASE = db), (DRDAID = null), Cleanup action starting
Thu Jun 14 21:52:12 EST 2012 Thread[LibraryAdditionsCheckerThread,2,main] (XID = 1781372801), (SESSIONID = 14), (DATABASE = db), (DRDAID = null), Failed Statement is: UPDATE repository SET last_scanned = ? WHERE id = ? with 2 parameters begin parameter #1: 2012-06-14 21:52:12.214 :end parameter begin parameter #2: 2 :end parameter
Thread name=LibraryAdditionsCheckerThread id=362 priority=2 state=RUNNABLE isdaemon=true
Thread name=Restlet-302782104 id=361 priority=5 state=RUNNABLE isdaemon=true
Thread name=Keep-Alive-Timer id=380 priority=8 state=TIMED_WAITING isdaemon=true
Thread name=LibraryUpdatesCheckerThread id=363 priority=1 state=TIMED_WAITING isdaemon=true
Thu Jun 14 21:53:26 EST 2012 Thread[LibraryAdditionsCheckerThread,2,main] (XID = 1781398776), (SESSIONID = 18), (DATABASE = db), (DRDAID = null), Cleanup action starting
Thu Jun 14 21:53:26 EST 2012 Thread[LibraryAdditionsCheckerThread,2,main] (XID = 1781398776), (SESSIONID = 18), (DATABASE = db), (DRDAID = null), Failed Statement is: UPDATE repository SET last_scanned = ? WHERE id = ? with 2 parameters begin parameter #1: 2012-06-14 21:53:26.777 :end parameter begin parameter #2: 2 :end parameter
Halfkast
Last part of the derby log.....
Thread name=Restlet-651353967 id=420 priority=5 state=TIMED_WAITING isdaemon=true
Thread name=ServioThread-22-EventDispatcher id=467 priority=5 state=TIMED_WAITING isdaemon=true
Thread name=ServioThread-20-DiscoverySSDPMessageListener id=465 priority=10 state=RUNNABLE isdaemon=true
Thread name=WebServer id=464 priority=5 state=RUNNABLE isdaemon=false
Thread name=LibraryAdditionsCheckerThread id=421 priority=2 state=RUNNABLE isdaemon=true
Thread name=ServioThread-23-DiscoveryNotifier id=468 priority=10 state=TIMED_WAITING isdaemon=true
Thread name=ServioThread-21-SubscriptionExpiryChecker id=466 priority=5 state=TIMED_WAITING isdaemon=true
Thread name=LibraryUpdatesCheckerThread id=422 priority=1 state=TIMED_WAITING isdaemon=true
Thread name=Restlet-421320459 id=431 priority=5 state=TIMED_WAITING isdaemon=true
Halfkast
Post Thu Jun 14, 2012 12:10 pm
OK Now this is the Serviio.txt log - at the end of this it is a whole list of mp3's that were not shared but i did not include the names of them all...
2012-06-14 21:42:21,647 WARN [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
java.sql.SQLException: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@6d6f0472, see the next exception for details.
at org.apache.derby.impl.jdbc.Util.newEmbedSQLException(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.bootDatabase(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.<init>(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection30.<init>(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection40.<init>(Unknown Source)
at org.apache.derby.jdbc.Driver40.getNewEmbedConnection(Unknown Source)
at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)
at org.apache.derby.jdbc.AutoloadedDriver.connect(Unknown Source)
at java.sql.DriverManager.getConnection(Unknown Source)
at org.serviio.db.DBConnectionPool.newConnection(DBConnetionPool.java:186)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:123)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:149)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:66)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:59)
at org.serviio.library.dao.RepositoryDAOImpl.findAll(RepositoryDAOImpl.java:176)
at org.serviio.library.local.service.RepositoryService.getAllRepositories(RepositoryService.java:45)
at org.serviio.library.local.metadata.LibraryUpdatesCheckerThread.run(LibraryUpdatesCheckerThread.java:90)
Caused by: java.sql.SQLException: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@6d6f0472, see the next exception for details.
... 20 more
Caused by: java.sql.SQLException: Derby system shutdown.
... 17 more
Caused by: ERROR XJ015: Derby system shutdown.
at org.apache.derby.impl.services.monitor.BaseMonitor.bootService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startProviderService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.findProviderAndStartService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startPersistentService(Unknown Source)
at org.apache.derby.iapi.services.monitor.Monitor.startPersistentService(Unknown Source)
... 17 more
2012-06-14 21:42:24,533 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-06-14 21:42:24,907 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-06-14 21:42:42,646 INFO [ServiioConsole] Starting Serviio Console
2012-06-14 21:42:43,005 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-06-14 21:42:52,569 INFO [MediaServer] ------------------------------------------------------------------------
2012-06-14 21:42:52,584 INFO [MediaServer] Serviio DLNA media streaming server v 0.6.2 (rev. aec3abd196d6+)
2012-06-14 21:42:52,584 INFO [MediaServer] Petr Nejedly 2009-2011
2012-06-14 21:42:52,584 INFO [MediaServer] http://www.serviio.org
2012-06-14 21:42:52,584 INFO [MediaServer] Java 1.6.0_23-Sun Microsystems Inc.
2012-06-14 21:42:52,584 INFO [MediaServer] OS Windows 7 amd64 6.1
2012-06-14 21:42:52,584 INFO [MediaServer] File encoding: windows-1252
2012-06-14 21:42:52,584 INFO [MediaServer] Headless mode enabled: true
2012-06-14 21:42:52,584 INFO [MediaServer] User home dir: C:\
2012-06-14 21:42:52,584 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2012-06-14 21:42:52,584 INFO [MediaServer] ------------------------------------------------------------------------
2012-06-14 21:42:52,740 INFO [RestletServer] Starting Restlet server exposed on port 23423
2012-06-14 21:42:52,787 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-06-14 21:42:53,427 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2012-06-14 21:42:54,784 INFO [Messages] Loaded console message bundle for locale: en
2012-06-14 21:42:54,815 INFO [UpdateChecker] Checking if a new version is available
2012-06-14 21:42:55,311 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-06-14 21:42:56,151 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-06-14 21:42:56,581 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-06-14 21:42:56,821 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-06-14 21:42:57,221 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-06-14 21:42:57,391 ERROR [ServiioConsole] Unexpected exception occured: 0
java.lang.ArrayIndexOutOfBoundsException: 0
at org.serviio.ui.view.swing.StatusView$RenderersTableModel.addRenderer(StatusView.java:705)
at org.serviio.ui.view.swing.StatusView.addRowToTable(StatusView.java:208)
at org.serviio.ui.view.swing.StatusView.updateRenderersTable(StatusView.java:184)
at org.serviio.ui.view.swing.StatusView.refreshRenderersTable(StatusView.java:152)
at org.serviio.ui.view.swing.StatusView.initComponents(StatusView.java:127)
at org.serviio.ui.view.swing.StatusView.<init>(StatusView.java:97)
at org.serviio.ui.view.swing.ServiioFrameView.<init>(ServiioFrameView.java:68)
at org.serviio.console.ServiioConsole.main(ServiioConsole.java:112)
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
at com.exe4j.runtime.WinLauncher.main(Unknown Source)
2012-06-14 21:42:57,391 INFO [ServiioConsole] Leaving Serviio Console
2012-06-14 21:42:57,451 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-06-14 21:42:57,631 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-06-14 21:42:58,171 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2012-06-14 21:42:58,201 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-06-14 21:42:58,721 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=9)
2012-06-14 21:42:59,051 INFO [ServiioConsole] Starting Serviio Console
2012-06-14 21:42:59,191 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-06-14 21:42:59,611 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-06-14 21:43:00,021 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2012-06-14 21:43:00,381 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-06-14 21:43:00,581 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-06-14 21:43:00,641 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-06-14 21:43:00,821 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-06-14 21:43:00,891 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-06-14 21:43:01,141 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-06-14 21:43:01,281 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=19)
2012-06-14 21:43:01,658 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-06-14 21:43:01,892 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=21)
2012-06-14 21:43:02,510 INFO [WebServer] Socket buffer set to 65535 bytes
2012-06-14 21:43:02,510 INFO [Device] Created UPnP Device with UUID: 66333861-1e81-334b-9cff-028e77be7789, bound address: 10.0.0.4
2012-06-14 21:43:02,540 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files (x86)\Serviio\bin\..\plugins
2012-06-14 21:43:02,540 INFO [PluginCompilerThread] Started looking for plugins
2012-06-14 21:43:02,710 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-06-14 21:43:02,750 INFO [WebServer] WebServer starting on port 8895
2012-06-14 21:43:02,750 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-06-14 21:43:02,750 INFO [EventDispatcher] Starting EventDispatcher
2012-06-14 21:43:02,750 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-06-14 21:43:02,750 INFO [RendererSearchSender] Searching for Renderer devices
2012-06-14 21:43:02,750 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2012-06-14 21:43:02,790 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Realtek PCIe GBE Family Controller) and address 10.0.0.4, timeout = 0
2012-06-14 21:43:09,870 INFO [Messages] Loaded console message bundle for locale: en
2012-06-14 21:43:09,964 INFO [UpdateChecker] Checking if a new version is available
2012-06-14 21:43:11,618 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-06-14 21:43:12,133 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-06-14 21:43:16,657 INFO [ServiioConsole] Starting Serviio Console
2012-06-14 21:43:16,766 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2012-06-14 21:43:17,279 INFO [Messages] Loaded console message bundle for locale: en
2012-06-14 21:43:17,309 INFO [UpdateChecker] Checking if a new version is available
2012-06-14 21:43:29,369 INFO [FeedUpdaterThread] Started looking for information about online resources
2012-06-14 21:43:29,369 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-06-14 21:43:29,369 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-06-14 21:43:31,181 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Faults and Fixes(1) - Nick Price.divx [VideoDescription [type=FILM, names=[david leadbetter faults and fixes(1) nick price, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:43:31,806 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter - Faults and Fixes(1) - Nick Price.divx' (title: David Leadbetter - Faults and Fixes(1) - Nick Price) to Library
2012-06-14 21:43:33,755 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Faults and Fixes(2) - Nick Price.divx [VideoDescription [type=FILM, names=[david leadbetter faults and fixes(2) nick price, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:43:33,798 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter - Faults and Fixes(2) - Nick Price.divx' (title: David Leadbetter - Faults and Fixes(2) - Nick Price) to Library
2012-06-14 21:43:34,726 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Golf - Greatest tips - DvdRip.mp4 [VideoDescription [type=FILM, names=[david leadbetter golf greatest tips, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:43:34,824 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter - Golf - Greatest tips - DvdRip.mp4' (title: David Leadbetter - Golf - Greatest tips - DvdRip) to Library
2012-06-14 21:43:37,309 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter-Beginner to Winner.avi' (title: David Leadbetter From Beginner to Winner) to Library
2012-06-14 21:43:38,960 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter-Beginner to Winner.mp4' (title: David Leadbetter From Beginner to Winner) to Library
2012-06-14 21:43:40,093 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter-Golf-Short Game.avi [VideoDescription [type=FILM, names=[david leadbetter golf short game, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:43:40,153 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter-Golf-Short Game.avi' (title: David Leadbetter-Golf-Short Game) to Library
2012-06-14 21:43:41,137 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter-Golf-Short Game.mp4 [VideoDescription [type=FILM, names=[david leadbetter golf short game, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:43:41,183 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter-Golf-Short Game.mp4' (title: David Leadbetter-Golf-Short Game) to Library
2012-06-14 21:43:42,407 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter_Golf Swing_DVDRip.avi [VideoDescription [type=FILM, names=[david leadbetter golf swing, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:43:42,463 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter_Golf Swing_DVDRip.avi' (title: David Leadbetter_Golf Swing_DVDRip) to Library
2012-06-14 21:43:43,344 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter_Golf Swing_DVDRip.mp4 [VideoDescription [type=FILM, names=[david leadbetter golf swing, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:43:43,411 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter_Golf Swing_DVDRip.mp4' (title: David Leadbetter_Golf Swing_DVDRip) to Library
2012-06-14 21:43:46,550 INFO [LibraryAdditionsCheckerThread] Added file 'David_Leadbetter.avi' (title: David Leadbetter The Short Game) to Library
2012-06-14 21:43:47,302 INFO [LibraryAdditionsCheckerThread] Added file '304-m.o.p-ante_up_(robbin_hoodz_theory).mp3' (title: Ante Up (Robbin Hoodz Theory)) to Library
2012-06-14 21:43:47,430 INFO [LibraryAdditionsCheckerThread] Added file '001 Cant Nobody (Acapella).mp3' (title: Cant Nobody (Acapella)) to Library
Halfkast
Post Thu Jun 14, 2012 12:11 pm
next part of the serviio.txt file
Cannot add file Omarion - Ice Box (Benja Styles Bmore Remix) (Clean).mp3 because of an unexpected error. Message: Cannot find MusicAlbum (title = Unknown, artist=Unknown)
org.serviio.db.dao.PersistenceException: Cannot find MusicAlbum (title = Unknown, artist=Unknown)
at org.serviio.library.dao.MusicAlbumDAOImpl.findAlbum(MusicAlbumDAOImpl.java:90)
Caused by: java.sql.SQLNonTransientConnectionException: Connection closed by unknown interrupt.
... 6 more
Caused by: java.sql.SQLException: Connection closed by unknown interrupt.
... 16 more
Caused by: ERROR 08000: Connection closed by unknown interrupt.
... 10 more
2012-06-14 21:44:58,377 WARN [LibraryAdditionsCheckerThread] An error occured while scanning for item to be added, will continue
org.serviio.db.dao.PersistenceException: Cannot mark Repository with id 2 as scanned
at org.serviio.library.dao.RepositoryDAOImpl.markRepositoryAsScanned(RepositoryDAOImpl.java:159)
... 2 more
... 12 more
... 6 more
2012-06-14 21:44:58,377 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-06-14 21:44:58,423 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-06-14 21:47:33,341 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-06-14 21:47:33,341 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-06-14 21:47:33,346 ERROR [RepositoryView$9] Unexpected REST error: Internal Server Error (500) - Internal Server Error
2012-06-14 21:47:34,835 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Faults and Fixes(1) - Nick Price.divx [VideoDescription [type=FILM, names=[david leadbetter faults and fixes(1) nick price, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:47:34,910 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter - Faults and Fixes(1) - Nick Price.divx' (title: David Leadbetter - Faults and Fixes(1) - Nick Price) to Library
2012-06-14 21:47:35,807 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Faults and Fixes(2) - Nick Price.divx [VideoDescription [type=FILM, names=[david leadbetter faults and fixes(2) nick price, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:47:35,834 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter - Faults and Fixes(2) - Nick Price.divx' (title: David Leadbetter - Faults and Fixes(2) - Nick Price) to Library
2012-06-14 21:47:36,641 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Golf - Greatest tips - DvdRip.mp4 [VideoDescription [type=FILM, names=[david leadbetter golf greatest tips, david leadbetter golf], year=null, season=null, episode=null]]
Halfkast
Post Thu Jun 14, 2012 12:13 pm
more of the serviio.txt file....
2012-06-14 21:49:17,992 WARN [LibraryAdditionsCheckerThread] An error occured while scanning for item to be added, will continue
... 2 more
... 12 more
... 6 more
2012-06-14 21:49:17,992 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-06-14 21:49:18,073 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-06-14 21:49:55,454 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-06-14 21:49:55,454 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-06-14 21:49:55,456 ERROR [RepositoryView$9] Unexpected REST error: Internal Server Error (500) - Internal Server Error
2012-06-14 21:49:56,911 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Faults and Fixes(1) - Nick Price.divx [VideoDescription [type=FILM, names=[david leadbetter faults and fixes(1) nick price, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:49:56,956 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter - Faults and Fixes(1) - Nick Price.divx' (title: David Leadbetter - Faults and Fixes(1) - Nick Price) to Library
2012-06-14 21:49:57,835 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Faults and Fixes(2) - Nick Price.divx [VideoDescription [type=FILM, names=[david leadbetter faults and fixes(2) nick price, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:49:57,859 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter - Faults and Fixes(2) - Nick Price.divx' (title: David Leadbetter - Faults and Fixes(2) - Nick Price) to Library
2012-06-14 21:49:58,632 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Golf - Greatest tips - DvdRip.mp4 [VideoDescription [type=FILM, names=[david leadbetter golf greatest tips, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:49:58,661 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter - Golf - Greatest tips - DvdRip.mp4' (title: David Leadbetter - Golf - Greatest tips - DvdRip) to Library
2012-06-14 21:50:00,711 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter-Beginner to Winner.avi' (title: David Leadbetter From Beginner to Winner) to Library
2012-06-14 21:50:02,396 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter-Beginner to Winner.mp4' (title: David Leadbetter From Beginner to Winner) to Library
2012-06-14 21:50:03,356 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter-Golf-Short Game.avi [VideoDescription [type=FILM, names=[david leadbetter golf short game, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:50:03,384 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter-Golf-Short Game.avi' (title: David Leadbetter-Golf-Short Game) to Library
2012-06-14 21:50:04,230 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter-Golf-Short Game.mp4 [VideoDescription [type=FILM, names=[david leadbetter golf short game, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:50:04,255 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter-Golf-Short Game.mp4' (title: David Leadbetter-Golf-Short Game) to Library
2012-06-14 21:50:05,277 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter_Golf Swing_DVDRip.avi [VideoDescription [type=FILM, names=[david leadbetter golf swing, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:50:05,304 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter_Golf Swing_DVDRip.avi' (title: David Leadbetter_Golf Swing_DVDRip) to Library
2012-06-14 21:50:06,773 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter_Golf Swing_DVDRip.mp4 [VideoDescription [type=FILM, names=[david leadbetter golf swing, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:50:06,799 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter_Golf Swing_DVDRip.mp4' (title: David Leadbetter_Golf Swing_DVDRip) to Library
2012-06-14 21:50:09,682 INFO [LibraryAdditionsCheckerThread] Added file 'David_Leadbetter.avi' (title: David Leadbetter The Short Game) to Library
2012-06-14 21:50:09,744 INFO [LibraryAdditionsCheckerThread] Added file '304-m.o.p-ante_up_(robbin_hoodz_theory).mp3' (title: Ante Up (Robbin Hoodz Theory)) to Library
Halfkast
more of the serviio.txt file.....
21:50:47,716 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-06-14 21:51:07,792 ERROR [RepositoryView$9] Unexpected REST error: Internal Server Error (500) - Internal Server Error
2012-06-14 21:51:21,372 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-06-14 21:51:21,372 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-06-14 21:51:21,372 INFO [EventDispatcher] Leaving EventDispatcher
2012-06-14 21:51:21,372 INFO [WebServer] WebServer shutting down
2012-06-14 21:51:21,608 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-06-14 21:51:22,950 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2012-06-14 21:52:02,371 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-06-14 21:52:02,371 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-06-14 21:52:02,386 ERROR [RepositoryView$9] Unexpected REST error: Internal Server Error (500) - Internal Server Error
2012-06-14 21:52:03,915 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Faults and Fixes(1) - Nick Price.divx [VideoDescription [type=FILM, names=[david leadbetter faults and fixes(1) nick price, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:52:04,165 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter - Faults and Fixes(1) - Nick Price.divx' (title: David Leadbetter - Faults and Fixes(1) - Nick Price) to Library
2012-06-14 21:52:05,179 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Faults and Fixes(2) - Nick Price.divx [VideoDescription [type=FILM, names=[david leadbetter faults and fixes(2) nick price, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:52:05,350 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter - Faults and Fixes(2) - Nick Price.divx' (title: David Leadbetter - Faults and Fixes(2) - Nick Price) to Library
2012-06-14 21:52:06,162 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Golf - Greatest tips - DvdRip.mp4 [VideoDescription [type=FILM, names=[david leadbetter golf greatest tips, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:52:06,193 WARN [LibraryAdditionsCheckerThread] An error occured while scanning for item to be added, will continue
... 2 more
... 12 more
... 6 more
2012-06-14 21:52:06,193 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-06-14 21:52:06,224 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-06-14 21:52:06,739 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-06-14 21:52:06,739 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-06-14 21:52:06,739 ERROR [RepositoryView$9] Unexpected REST error: Internal Server Error (500) - Internal Server Error
2012-06-14 21:52:06,848 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-06-14 21:52:06,910 WARN [LibraryUpdatesCheckerThread] An error occured while scanning for items to be removed or updated, will continue
org.serviio.db.dao.PersistenceException: Cannot get file of media item: 31557
at org.serviio.library.dao.MediaItemDAOImpl.getFile(MediaItemDAOImpl.java:148)
... 3 more
... 13 more
... 7 more
2012-06-14 21:52:06,910 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-06-14 21:52:06,988 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-06-14 21:52:06,988 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-06-14 21:52:06,988 ERROR [RepositoryView$9] Unexpected REST error: Internal Server Error (500) - Internal Server Error
2012-06-14 21:52:07,098 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-06-14 21:52:07,191 WARN [LibraryUpdatesCheckerThread] An error occured while scanning for items to be removed or updated, will continue
org.serviio.db.dao.PersistenceException: Cannot get file of media item: 31558
... 3 more
... 13 more
... 7 more
2012-06-14 21:52:07,191 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-06-14 21:52:07,300 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-06-14 21:52:07,300 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-06-14 21:52:07,300 ERROR [RepositoryView$9] Unexpected REST error: Internal Server Error (500) - Internal Server Error
2012-06-14 21:52:08,221 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Faults and Fixes(1) - Nick Price.divx [VideoDescription [type=FILM, names=[david leadbetter faults and fixes(1) nick price, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:52:08,299 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter - Faults and Fixes(1) - Nick Price.divx' (title: David Leadbetter - Faults and Fixes(1) - Nick Price) to Library
2012-06-14 21:52:09,157 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Faults and Fixes(2) - Nick Price.divx [VideoDescription [type=FILM, names=[david leadbetter faults and fixes(2) nick price, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:52:09,204 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter - Faults and Fixes(2) - Nick Price.divx' (title: David Leadbetter - Faults and Fixes(2) - Nick Price) to Library
2012-06-14 21:52:10,077 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Golf - Greatest tips - DvdRip.mp4 [VideoDescription [type=FILM, names=[david leadbetter golf greatest tips, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:52:10,124 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter - Golf - Greatest tips - DvdRip.mp4' (title: David Leadbetter - Golf - Greatest tips - DvdRip) to Library
2012-06-14 21:52:12,230 WARN [LibraryAdditionsCheckerThread] An error occured while scanning for item to be added, will continue
... 2 more
... 12 more
... 6 more
2012-06-14 21:52:12,230 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-06-14 21:52:12,261 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-06-14 21:52:12,667 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-06-14 21:52:12,667 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-06-14 21:52:12,667 ERROR [RepositoryView$9] Unexpected REST error: Internal Server Error (500) - Internal Server Error
2012-06-14 21:52:13,478 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Faults and Fixes(1) - Nick Price.divx [VideoDescription [type=FILM, names=[david leadbetter faults and fixes(1) nick price, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:52:13,494 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-06-14 21:52:13,603 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-06-14 21:52:13,712 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-06-14 21:52:13,712 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-06-14 21:52:13,712 ERROR [RepositoryView$9] Unexpected REST error: Internal Server Error (500) - Internal Server Error
2012-06-14 21:52:13,774 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-06-14 21:52:13,868 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-06-14 21:52:13,977 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-06-14 21:52:13,977 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-06-14 21:52:13,977 ERROR [RepositoryView$9] Unexpected REST error: Internal Server Error (500) - Internal Server Error
2012-06-14 21:52:14,102 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-06-14 21:52:14,196 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-06-14 21:52:14,305 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-06-14 21:52:14,305 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-06-14 21:52:14,305 ERROR [RepositoryView$9] Unexpected REST error: Internal Server Error (500) - Internal Server Error
2012-06-14 21:52:15,272 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Faults and Fixes(1) - Nick Price.divx [VideoDescription [type=FILM, names=[david leadbetter faults and fixes(1) nick price, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:52:15,428 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter - Faults and Fixes(1) - Nick Price.divx' (title: David Leadbetter - Faults and Fixes(1) - Nick Price) to Library
2012-06-14 21:52:16,270 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Faults and Fixes(2) - Nick Price.divx [VideoDescription [type=FILM, names=[david leadbetter faults and fixes(2) nick price, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:52:16,302 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter - Faults and Fixes(2) - Nick Price.divx' (title: David Leadbetter - Faults and Fixes(2) - Nick Price) to Library
2012-06-14 21:52:17,113 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Golf - Greatest tips - DvdRip.mp4 [VideoDescription [type=FILM, names=[david leadbetter golf greatest tips, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:52:17,347 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter - Golf - Greatest tips - DvdRip.mp4' (title: David Leadbetter - Golf - Greatest tips - DvdRip) to Library
2012-06-14 21:52:19,328 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter-Beginner to Winner.avi' (title: David Leadbetter From Beginner to Winner) to Library
Halfkast
Post Thu Jun 14, 2012 12:14 pm
More of the serviio.txt file....
... 2 more
... 12 more
... 6 more
2012-06-14 21:53:26,794 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-06-14 21:53:26,876 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-06-14 21:53:51,293 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-06-14 21:53:51,293 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-06-14 21:53:51,295 ERROR [RepositoryView$9] Unexpected REST error: Internal Server Error (500) - Internal Server Error
2012-06-14 21:54:00,359 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Faults and Fixes(1) - Nick Price.divx [VideoDescription [type=FILM, names=[david leadbetter faults and fixes(1) nick price, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:54:00,838 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter - Faults and Fixes(1) - Nick Price.divx' (title: David Leadbetter - Faults and Fixes(1) - Nick Price) to Library
2012-06-14 21:54:05,232 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Faults and Fixes(2) - Nick Price.divx [VideoDescription [type=FILM, names=[david leadbetter faults and fixes(2) nick price, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:54:05,255 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter - Faults and Fixes(2) - Nick Price.divx' (title: David Leadbetter - Faults and Fixes(2) - Nick Price) to Library
2012-06-14 21:54:10,729 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter - Golf - Greatest tips - DvdRip.mp4 [VideoDescription [type=FILM, names=[david leadbetter golf greatest tips, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:54:11,129 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter - Golf - Greatest tips - DvdRip.mp4' (title: David Leadbetter - Golf - Greatest tips - DvdRip) to Library
2012-06-14 21:54:39,337 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter-Beginner to Winner.avi' (title: David Leadbetter From Beginner to Winner) to Library
2012-06-14 21:55:23,858 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter-Beginner to Winner.mp4' (title: David Leadbetter From Beginner to Winner) to Library
2012-06-14 21:55:33,224 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter-Golf-Short Game.avi [VideoDescription [type=FILM, names=[david leadbetter golf short game, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:55:33,381 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter-Golf-Short Game.avi' (title: David Leadbetter-Golf-Short Game) to Library
2012-06-14 21:55:41,625 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter-Golf-Short Game.mp4 [VideoDescription [type=FILM, names=[david leadbetter golf short game, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:55:41,656 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter-Golf-Short Game.mp4' (title: David Leadbetter-Golf-Short Game) to Library
2012-06-14 21:55:51,453 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter_Golf Swing_DVDRip.avi [VideoDescription [type=FILM, names=[david leadbetter golf swing, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:55:51,468 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter_Golf Swing_DVDRip.avi' (title: David Leadbetter_Golf Swing_DVDRip) to Library
2012-06-14 21:56:01,889 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file David Leadbetter_Golf Swing_DVDRip.mp4 [VideoDescription [type=FILM, names=[david leadbetter golf swing, david leadbetter golf], year=null, season=null, episode=null]]
2012-06-14 21:56:02,076 INFO [LibraryAdditionsCheckerThread] Added file 'David Leadbetter_Golf Swing_DVDRip.mp4' (title: David Leadbetter_Golf Swing_DVDRip) to Library
2012-06-14 21:56:49,189 INFO [LibraryAdditionsCheckerThread] Added file 'David_Leadbetter.avi' (title: David Leadbetter The Short Game) to Library
2012-06-14 21:56:49,345 INFO [LibraryAdditionsCheckerThread] Added file '304-m.o.p-ante_up_(robbin_hoodz_theory).mp3' (title: Ante Up (Robbin Hoodz Theory)) to Library
2012-06-14 21:56:49,408 INFO [LibraryAdditionsCheckerThread] Added file '001 Cant Nobody (Acapella).mp3' (title: Cant Nobody (Acapella)) to Library
Halfkast
Post Thu Jun 14, 2012 12:15 pm
Re: Updating library issues
The last part of the serviio.txt file....
2012-06-14 22:02:18,004 INFO [LibraryAdditionsCheckerThread] Added file '09-trick_daddy-suga_(feat _ludacris_and_cee-lo)-qmb.mp3' (title: Suga (Feat. Ludacris & Cee-Lo)) to Library
2012-06-14 22:02:18,117 INFO [LibraryAdditionsCheckerThread] Added file '09. Booti Call.MP3' (title: 09. Booti Call) to Library
2012-06-14 22:02:18,240 INFO [LibraryAdditionsCheckerThread] Added file '090 - Maroon 5 ft. Rihanna - If I Never See Your Face Again [Torrent Tatty] (™ A&M Octone).MP3' (title: 090 - Maroon 5 ft. Rihanna - If I Never See Your Face Again [Torrent Tatty] (™ A&M Octone)) to Library
2012-06-14 22:02:18,264 ERROR [id3] 090 Flashing Lights.mp3:An error occurred within abstractID3v2FrameBody for identifier:PRIV:Invalid DataType for Frame Body:Unable to find null terminated string
2012-06-14 22:02:18,355 INFO [LibraryAdditionsCheckerThread] Added file '090 Flashing Lights.mp3' (title: Flashing Lights) to Library
2012-06-14 22:02:18,513 INFO [LibraryAdditionsCheckerThread] Added file '091 - Shwayze - Corona And Lime [Torrent Tatty] (™ Suretone Geffen - Promo @128).MP3' (title: 091 - Shwayze - Corona And Lime [Torrent Tatty] (™ Suretone Geffen - Promo @128)) to Library
2012-06-14 22:02:18,538 ERROR [id3] 091 Mrs. Officer.mp3:An error occurred within abstractID3v2FrameBody for identifier:PRIV:Invalid DataType for Frame Body:Unable to find null terminated string
2012-06-14 22:02:18,654 INFO [LibraryAdditionsCheckerThread] Added file '091 Mrs. Officer.mp3' (title: Mrs. Officer) to Library
2012-06-14 22:02:18,769 INFO [LibraryAdditionsCheckerThread] Added file '092 - Luis Fonsi - No Me Doy Por Vencido [Torrent Tatty] (™ Universal Latino).MP3' (title: 092 - Luis Fonsi - No Me Doy Por Vencido [Torrent Tatty] (™ Universal Latino)) to Library
2012-06-14 22:02:18,799 ERROR [id3] 092 7 Things.mp3:An error occurred within abstractID3v2FrameBody for identifier:PRIV:Invalid DataType for Frame Body:Unable to find null terminated string
2012-06-14 22:02:19,111 INFO [LibraryAdditionsCheckerThread] Added file '092 7 Things.mp3' (title: 7 Things) to Library
2012-06-14 22:02:19,234 INFO [LibraryAdditionsCheckerThread] Added file '093 - Demi Lovato - Get Back [Torrent Tatty] (™ Hollywood).mp3' (title: Get Back) to Library
2012-06-14 22:02:19,258 ERROR [id3] 093 You're Gonna Miss This.mp3:An error occurred within abstractID3v2FrameBody for identifier:PRIV:Invalid DataType for Frame Body:Unable to find null terminated string
2012-06-14 22:02:19,356 INFO [LibraryAdditionsCheckerThread] Added file '093 You're Gonna Miss This.mp3' (title: You're Gonna Miss This) to Library
2012-06-14 22:02:19,480 INFO [LibraryAdditionsCheckerThread] Added file '094 - Miley Cyrus - 7 Things [Torrent Tatty] (™ Hollywood).MP3' (title: 094 - Miley Cyrus - 7 Things [Torrent Tatty] (™ Hollywood)) to Library
2012-06-14 22:02:19,505 ERROR [id3] 094 Love Remains The Same.mp3:An error occurred within abstractID3v2FrameBody for identifier:PRIV:Invalid DataType for Frame Body:Unable to find null terminated string
2012-06-14 22:02:19,613 INFO [LibraryAdditionsCheckerThread] Added file '094 Love Remains The Same.mp3' (title: Love Remains The Same) to Library
2012-06-14 22:02:19,723 INFO [LibraryAdditionsCheckerThread] Added file '095 - Luke Bryan - Country Man [Torrent Tatty] (™ Capitol Nashville).MP3' (title: 095 - Luke Bryan - Country Man [Torrent Tatty] (™ Capitol Nashville)) to Library
2012-06-14 22:02:19,756 ERROR [id3] 095 Feels Like Tonight.mp3:An error occurred within abstractID3v2FrameBody for identifier:PRIV:Invalid DataType for Frame Body:Unable to find null terminated string
2012-06-14 22:02:19,840 INFO [LibraryAdditionsCheckerThread] Added file '095 Feels Like Tonight.mp3' (title: Feels Like Tonight) to Library
2012-06-14 22:02:19,960 INFO [LibraryAdditionsCheckerThread] Added file '096 - Montgomery Gentry - Roll With Me [Torrent Tatty] (™ Columbia).MP3' (title: 096 - Montgomery Gentry - Roll With Me [Torrent Tatty] (™ Columbia)) to Library
2012-06-14 22:02:19,988 ERROR [id3] 096 The Way I Are.mp3:An error occurred within abstractID3v2FrameBody for identifier:PRIV:Invalid DataType for Frame Body:Unable to find null terminated string
2012-06-14 22:02:20,098 INFO [LibraryAdditionsCheckerThread] Added file '096 The Way I Are.mp3' (title: The Way I Are) to Library
2012-06-14 22:02:20,212 INFO [LibraryAdditionsCheckerThread] Added file '097 - Alicia Keys - Superwoman [Torrent Tatty] (™ MBKJ RMG).MP3' (title: 097 - Alicia Keys - Superwoman [Torrent Tatty] (™ MBKJ RMG)) to Library
2012-06-14 22:02:20,239 ERROR [id3] 097 Addicted.mp3:An error occurred within abstractID3v2FrameBody for identifier:PRIV:Invalid DataType for Frame Body:Unable to find null terminated string
2012-06-14 22:02:20,332 INFO [LibraryAdditionsCheckerThread] Added file '097 Addicted.mp3' (title: Addicted) to Library
2012-06-14 22:02:20,465 INFO [LibraryAdditionsCheckerThread] Added file '098 - Theory Of A Deadman - Bad Girlfriend [Torrent Tatty] (™ Roadrunner).MP3' (title: 098 - Theory Of A Deadman - Bad Girlfriend [Torrent Tatty] (™ Roadrunner)) to Library
2012-06-14 22:02:20,504 ERROR [id3] 098 Into The Night.mp3:An error occurred within abstractID3v2FrameBody for identifier:PRIV:Invalid DataType for Frame Body:Unable to find null terminated string
2012-06-14 22:02:20,591 INFO [LibraryAdditionsCheckerThread] Added file '098 Into The Night.mp3' (title: Into The Night) to Library
2012-06-14 22:02:20,719 INFO [LibraryAdditionsCheckerThread] Added file '099 - John Mayer - Free Fallin' [Torrent Tatty] (™ Columbia).MP3' (title: 099 - John Mayer - Free Fallin' [Torrent Tatty] (™ Columbia)) to Library
2012-06-14 22:02:20,755 ERROR [id3] 099 Heaven Sent.mp3:An error occurred within abstractID3v2FrameBody for identifier:PRIV:Invalid DataType for Frame Body:Unable to find null terminated string
2012-06-14 22:02:20,846 INFO [LibraryAdditionsCheckerThread] Added file '099 Heaven Sent.mp3' (title: Heaven Sent) to Library
2012-06-14 22:02:20,969 INFO [LibraryAdditionsCheckerThread] Added file '09_Swiss_Beats_-_Where_da_cash_at_I-O_by_Delux.mp3' (title: 09_Swiss_Beats_-_Where_da_cash_at_I-O_by_Delux) to Library
2012-06-14 22:02:21,096 INFO [LibraryAdditionsCheckerThread] Added file '1. What's My Magic Stick.mp3' (title: WHATS MY MAGIC STICK) to Library
2012-06-14 22:02:21,215 INFO [LibraryAdditionsCheckerThread] Added file '1.Krafty kuts - its ya booty.mp3' (title: IT'S YA BOOTY (ORIGINAL CUTZ)) to Library
2012-06-14 22:02:21,344 INFO [LibraryAdditionsCheckerThread] Added file '10 Fergie - Big Girls Dont Cry.mp3' (title: Big Girls Dont Cry) to Library
2012-06-14 22:02:21,474 INFO [LibraryAdditionsCheckerThread] Added file '10 - Concrete Streets.mp3' (title: Concrete Streets) to Library
Halfkast
Post Thu Jun 14, 2012 12:16 pm
sorry here's some more....
2012-06-14 21:53:26,793 WARN [LibraryAdditionsCheckerThread] An error occured while scanning for item to be added, will continue
at org.apache.derby.impl.jdbc.EmbedStatement.executeStatement(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeStatement(Unknown Source)
... 2 more
... 12 more
at org.apache.derby.iapi.util.InterruptStatus.setInterrupted(Unknown Source)
at org.apache.derby.iapi.util.InterruptStatus.throwIf(Unknown Source)
at org.apache.derby.impl.sql.execute.BasicNoPutResultSetImpl.checkCancellationFlag(Unknown Source)
at org.apache.derby.impl.sql.execute.ProjectRestrictResultSet.getNextRowCore(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.executeStmt(Unknown Source)
at org.apache.derby.impl.sql.GenericPreparedStatement.execute(Unknown Source)
... 6 more
Halfkast
Post Thu Jun 14, 2012 12:18 pm
More logs - this was from serviio.log....
2012-06-14 11:00:27,062 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 11:00:27,124 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 11:20:31,929 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 11:20:31,997 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 11:40:37,910 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 11:40:37,988 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 12:00:59,617 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 12:00:59,664 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 12:21:03,643 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 12:21:03,710 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 12:41:15,914 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 12:41:15,981 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 13:01:46,683 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 13:01:46,756 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 13:22:22,862 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 13:22:22,940 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 13:42:26,878 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 13:42:26,937 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 14:02:31,827 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 14:02:31,901 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 14:22:35,488 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 14:22:35,545 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 14:42:52,610 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 14:42:52,688 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 15:03:07,475 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 15:03:07,545 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 15:23:10,685 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 15:23:10,746 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 15:43:41,879 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 15:43:41,934 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 16:03:46,461 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 16:03:46,523 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 16:23:50,752 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 16:23:50,803 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 16:44:13,512 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 16:44:13,580 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 17:05:08,502 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 17:05:08,564 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 17:25:13,090 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 17:25:13,159 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 17:45:39,595 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 17:45:39,656 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 18:06:12,594 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 18:06:12,655 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 18:26:16,280 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 18:26:16,338 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 18:46:20,991 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 18:46:21,055 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 19:06:56,309 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 19:06:56,368 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 19:27:00,759 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 19:27:00,827 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 19:47:35,980 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 19:47:36,043 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 20:07:40,859 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 20:07:40,917 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 20:28:08,252 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 20:28:08,310 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 20:48:11,265 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 20:48:11,330 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 21:08:15,930 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 21:08:16,014 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 21:28:20,924 WARN [OnlineVideoSourcesMetadataExtractor] Online metadata search returned no results for file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 [VideoDescription [type=FILM, names=[tyga x juvenile rack city ass up, dj newish songs to mix with - like a g6 biatch!], year=null, season=null, episode=null]]
2012-06-14 21:28:20,994 WARN [LibraryAdditionsCheckerThread] Cannot add file Tyga x Juvenile - Rack City Ass Up [Benja Styles Blend] [Clean].mp4 because of invalid metadata. Message: Unknown video width.
2012-06-14 21:30:54,767 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-06-14 21:30:54,867 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-06-14 21:42:20,959 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-06-14 21:42:20,959 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-06-14 21:42:20,960 INFO [FeedUpdaterThread] Finished looking for online resources information
2012-06-14 21:42:21,060 INFO [PluginCompilerThread] Finished looking for plugins
2012-06-14 21:42:21,160 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-06-14 21:42:21,160 INFO [WebServer] WebServer shutting down
2012-06-14 21:42:21,160 INFO [EventDispatcher] Leaving EventDispatcher
2012-06-14 21:42:21,160 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-06-14 21:42:21,615 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-06-14 21:42:21,615 INFO [DatabaseManager] Shutting down database
2012-06-14 21:42:21,615 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-06-14 21:42:21,615 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-06-14 21:42:21,647 WARN [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
java.sql.SQLException: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@6d6f0472, see the next exception for details.
at org.apache.derby.impl.jdbc.Util.newEmbedSQLException(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.bootDatabase(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.<init>(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection30.<init>(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection40.<init>(Unknown Source)
at org.apache.derby.jdbc.Driver40.getNewEmbedConnection(Unknown Source)
at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)
at org.apache.derby.jdbc.AutoloadedDriver.connect(Unknown Source)
at java.sql.DriverManager.getConnection(Unknown Source)
at org.serviio.db.DBConnectionPool.newConnection(DBConnetionPool.java:186)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:123)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:113)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:149)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:66)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:59)
at org.serviio.library.dao.RepositoryDAOImpl.findAll(RepositoryDAOImpl.java:176)
at org.serviio.library.local.service.RepositoryService.getAllRepositories(RepositoryService.java:45)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:71)
Caused by: java.sql.SQLException: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@6d6f0472, see the next exception for details.
... 22 more
Caused by: java.sql.SQLException: Derby system shutdown.
... 19 more
Caused by: ERROR XJ015: Derby system shutdown.
at org.apache.derby.impl.services.monitor.BaseMonitor.bootService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startProviderService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.findProviderAndStartService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startPersistentService(Unknown Source)
at org.apache.derby.iapi.services.monitor.Monitor.startPersistentService(Unknown Source)
... 19 more
Hope this will clear things up.... just confused the shit out of me LOL =)
Thanks for your assistance =)
Post Thu Jun 14, 2012 6:05 pm
try to upgrade your Java
Halfkast
Post Thu Jun 14, 2012 10:16 pm
OK i updated Java and applied all updates that were "important" from the microsoft website and am still having issues...
I rebooted the computer and still no bingo.
Files are still being scanned from some random folder on my computer and Serviio is still not saving the folders i select to share...
Any other options?
Windows 7 Ultimate SP1, 64bit, Intel i7 950 @ 3.07Hz 3.07GHz, 6GB RAM
Post Mon Jun 18, 2012 10:41 pm
did you try to uninstall and install again?
madman10
Post Wed Jun 20, 2012 4:17 am
I'm having the same issues, it shows the main folders, but about 50% show no content in the folders, it used to show them all. Recently the files in the folders are not showing in Serviio, I also tried to uninstall Serviio and reboot then install it again and reboot and still no change. Also files that used to play fine now it says "File format not supported", my TV has not been updated so it has to be something with Serviio, I suspect that maybe some recent Windows updates have caused this and we need a up to date new version of Serviio. It seems that there is a problem with the library updating the files, and I have it to do so every 5mins and it don't seem to do anythink. I have also Serviio on my brothers NAS and it used to show everything also on his and now it has the same problem, showing the main folders (Movies, Music, Pictures) and each added folder to Serviio but no contents in them, and we haven't changed anything since it was working so there's a bug in Serviio somewhere.
Post Wed Jun 20, 2012 10:09 pm
madman10 wrote:I'm having the same issues, it shows the main folders, but about 50% show no content in the folders, it used to show them all. Recently the files in the folders are not showing in Serviio, I also tried to uninstall Serviio and reboot then install it again and reboot and still no change. Also files that used to play fine now it says "File format not supported", my TV has not been updated so it has to be something with Serviio, I suspect that maybe some recent Windows updates have caused this and we need a up to date new version of Serviio. It seems that there is a problem with the library updating the files, and I have it to do so every 5mins and it don't seem to do anythink. I have also Serviio on my brothers NAS and it used to show everything also on his and now it has the same problem, showing the main folders (Movies, Music, Pictures) and each added folder to Serviio but no contents in them, and we haven't changed anything since it was working so there's a bug in Serviio somewhere.
You have posted no information that would help us to diagnose your problem.
viewtopic.php?f=5&t=1289
Users browsing this forum: Google [Bot], Riversiderepeat and 38 guests
