BubbleUPnP Subtitle support
Post Fri Jun 29, 2012 1:56 pm
I am using BubbleUPnp to obtain Serviio media on my Android tablet. Everything works fine except subtitles.
Attached is the sink info for the BubbleUPnP renderer and the BubbleUPnP profile I am using which includes the subtitle mime.
I know the MX player supports the subtitles from Serviio because ServiiGo is able to add them.
What am I missing to obtain subtitle support via DLNA?
bubbleUPnP.zip
(506 Bytes) Downloaded 640 times
Android_Profile.txt.zip
(664 Bytes) Downloaded 656 times
Post Fri Jun 29, 2012 2:10 pm
Re: BubbleUPnP Subtitle support
you have to ask BubbleUpnp guys if they support subtitles ... they are not DLNA standard
Post Fri Jun 29, 2012 3:16 pm
I need to tell them what to support.
Does Serviio customize subtitle support to what each manufactures renderer supports or is there a common ad-hoc way that they all use that you support?
Right now seems they expect the subs to be embedded by transcoding but seem to be open to better support if they knew what was required.
Post Sun Jul 01, 2012 7:35 pm
is BubbleUpnp renderer, controller or what? Does it just pass the media onto the device? Str subs are per manufacturer, but a few seem to support the way Pnasocin/Twonky do it - an additional resource with mime-type text/srt.
Post Sun Jul 01, 2012 10:19 pm
zip wrote:is BubbleUpnp renderer, controller or what? Does it just pass the media onto the device? Str subs are per manufacturer, but a few seem to support the way Pnasocin/Twonky do it - an additional resource with mime-type text/srt.
Thanks. Its a full featured UPnP/DLNA Control Point, UPnP Media Renderer and UPnP Media Server, but I simply use it to connect to Serviio and then it passes the files to MXPlayer which has subtitle support. Features here http://forum.xda-developers.com/showthr ... ?t=1118891
Users browsing this forum: Google [Bot] and 45 guests
