Better logging for ffmpeg commands (ffmpeg 100% CPU)
robertsearle
Post Mon Jul 02, 2012 5:18 pm
I turned up tracing on the log file hoping to see which file is causing a problem. I guess from other posts that serviio is having problems generating thumbnails or something like that. For now all that happens is serviio uses most of the CPUs
robertsearle
Post Sat Jul 28, 2012 6:03 pm
Re: Better logging for ffmpeg commands (ffmpeg 100% CPU)
This doesn't appear to be a problem with 1.0
Post Sat Jul 28, 2012 6:33 pm
any details?
robertsearle
Post Mon Jul 30, 2012 3:24 am
For now, I would say bug found in 0.6 fixed in 1.0
yaro
Post Mon Jul 30, 2012 5:17 am
On Osx lion , I notice that after I stopped watching a stream on the Philips TV, the file javaapplicationstub continues using about 150% of CPU for a while. I am on a Mac mini dual core.
I do not see javaapplicationstub in the log. I see ffmpeg.
I think it cleans up after itself.
Post Mon Jul 30, 2012 8:49 am
yaro wrote:On Osx lion , I notice that after I stopped watching a stream on the Philips TV, the file javaapplicationstub continues using about 150% of CPU for a while. I am on a Mac mini dual core.
It finishes transcoding the entire movie, unless you start watching another movie that needs transcoding, in which case that one take over
yaro
Post Mon Jul 30, 2012 10:03 pm
You should take another look at the javaapplicationstub. It stays on way longer than necessary and burns lots of CPU cycles.
Post Mon Jul 30, 2012 10:16 pm
see my last reply.. and it's the way by design. discussed here many times.
yaro
Post Tue Jul 31, 2012 11:58 pm
Does it continue transcoding the online live streams too? That may be the cause.
Post Wed Aug 01, 2012 8:45 am
yaro wrote:Does it continue transcoding the online live streams too? That may be the cause.
Not the live streams, at least it should not (FFmpeg will be killed after 30 seconds or 1 minute after you stop watching the live stream)
Return to Feature requests
