Profile for BDP 370 Blu-Ray
bbking67
Post Tue Jul 17, 2012 12:52 am
I have a Blu-ray that is around two years old, a BDP-370. It works well enough with Serviio serving up DLNA, but some files will not play... I am under the assumption that transcoding these files using a proper "profile" will allow them to play. The files play using other devices (including my Android tablet).
Is there a compatible profile? Would the BDP-370 be the same as one of the Bravia profiles?
patters
Post Tue Jul 17, 2012 7:11 am
Re: Profile for BDP 370 Blu-Ray
The Sony BDP / SMP profile that gets autoselected is the correct one. What is it that won't play?
bbking67
Post Thu Jul 19, 2012 1:27 am
I'm not getting audio from some mkv files (as per my other post). It generally works well, I just wasn't sure if there was anything more optimized or something like that.
patters
Post Thu Jul 19, 2012 4:30 pm
Serviio is only remuxing the streams in the MKV file so it's quite likely that you'd have the same issue trying to play the MKV file from a USB drive plugged directly into the player. Often a problem like this will be an issue with the way the file was encoded. Trying on USB is a good way to rule this out.
bbking67
Post Fri Aug 03, 2012 2:59 am
I thought that Serbiio would transcode to a format that would work (depending on the profile). I was able to convert the files using handbrake and the .mp4 versions now work.
If i run into this problem with more .mkv, can I just set up Serviio to transcode into MP4? Obviously I'm a Serviio newb...
