[SOLVED] Playing MOV-files on Samsung E-Series TV
patagonia
Post Fri Jul 20, 2012 9:06 am
I recorded some movies with my Canon Eos 5D Mark II camera. This camera creates mov-files (1080p, 30Hz, H264).
As Serviio doesn't support the E-series renderer yet, I selected the Samsung C/D-series profile.
I can't manage to transcode these files. How can I play these movies on my Samsung E-series TV?
Thks for your help.
Jochen
Post Sat Jul 21, 2012 3:39 pm
Re: Playing MOV-files on Samsung E-Series TV
patagonia
Post Sat Jul 21, 2012 6:15 pm
Thanks for your reply.
I'm using Win7, x64. Renderer Device: Samsung UE46ES5700.
The result from ffmpeg.exe -i "file.MOV" is:
nfig
libavutil 51. 32. 0 / 51. 32. 0
libavcodec 53. 42. 0 / 53. 42. 0
libavformat 53. 24. 0 / 53. 24. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 53. 0 / 2. 53. 0
libswscale 2. 1. 0 / 2. 1. 0
Seems stream 0 codec frame rate differs from container frame rate: 50000.00 (500
00/1) -> 25.00 (25/1)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'k:\file.MOV':
major_brand : qt
minor_version : 537331968
compatible_brands: qt CAEP
creation_time : 2012-01-02 16:05:08
Duration: 00:00:42.20, start: 0.000000, bitrate: 45272 kb/s
Stream #0:0(eng): Video: h264 (Constrained Baseline) (avc1 / 0x31637661), yu
vj420p, 1920x1088, 43733 kb/s, 25 fps, 25 tbr, 25k tbn, 50k tbc
handler_name :
Stream #0:1(eng): Audio: pcm_s16le (sowt / 0x74776F73), 48000 Hz, stereo, s1
6, 1536 kb/s
handler_name :
The result from the mediainfo is:
Allgemein
Vollständiger Name : K:\file.MOV
Format : MPEG-4
Format-Profil : QuickTime
Codec-ID : qt
Dateigröße : 321 MiB
Dauer : 56s 440ms
Gesamte Bitrate : 47,7 Mbps
Kodierungs-Datum : UTC 2012-01-06 13:39:24
Tagging-Datum : UTC 2012-01-06 13:39:24
Xtra : WM/MediaClassPrimaryID
Format : AVC
Format-Profil : Baseline@L5.0
Format-Einstellungen für CABAC : Nein
Format-Einstellungen für ReFrames : 1 frame
Format_Settings_GOP : M=1, N=12
Codec-ID : avc1
Codec-ID/Info : Advanced Video Coding
Dauer : 56s 440ms
Bitrate : 46,2 Mbps
Breite : 1 920 Pixel
Höhe : 1 080 Pixel
Height_Original/String : 1 088 Pixel
Bildseitenverhältnis : 16:9
Ursprüngliches Bildseitenverhältnis : 16:9
Modus der Bildwiederholungsrate : konstant
Bildwiederholungsrate : 25,000 FPS
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
Scantyp : progressiv
Bits/(Pixel*Frame) : 0.890
Stream-Größe : 311 MiB (97%)
Sprache : Englisch
colour_primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
transfer_characteristics : BT.709-5, BT.1361
matrix_coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Format : PCM
Format-Einstellungen für Endianess : Little
Format-Einstellungen für Sign : Signed
Codec-ID : sowt
Dauer : 56s 440ms
Bitraten-Modus : konstant
Bitrate : 1 536 Kbps
Kanäle : 2 Kanäle
Kanal-Positionen : Front: L R
Samplingrate : 48,0 KHz
BitDepth/String : 16 bits
Stream-Größe : 10,3 MiB (3%)
Sprache : Englisch
Post Sun Jul 22, 2012 2:33 pm
it should work, can you post detailed log of when you play the file?
patagonia
Post Wed Jul 25, 2012 9:41 am
I created a debug-log. In the debug log it says that transcoding was successful, but the Samsung E-series TV posts "The file is currently not supported".
Here is the relevant part of the debug log:
2012-07-25 11:34:21,506 DEBUG [ContentDirectory] Browse() called for renderer UE46ES5700 (profile 7) with parameters: objectID = V_F^FOL_R2, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-07-25 11:34:21,506 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder null
2012-07-25 11:34:21,507 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 1 (from=0, count=1)
2012-07-25 11:34:21,509 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2012-07-25 11:34:21,510 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2012-07-25 11:34:21,511 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2012-07-25 11:34:21,513 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2012-07-25 11:34:21,514 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1 and profile Samsung TV / player (C/D-series)
2012-07-25 11:34:21,514 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MVI_7352.MOV: AVC_TS_MP_HD_AC3_ISO
2012-07-25 11:34:21,514 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
2012-07-25 11:34:21,515 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2012-07-25 11:34:21,516 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2012-07-25 11:34:21,518 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root'
2012-07-25 11:34:21,519 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-07-25 11:34:21,527 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-25 11:34:21,547 DEBUG [WebServer] Incoming connection from /192.168.2.100:52830
2012-07-25 11:34:21,548 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.2.100:
2012-07-25 11:34:21,548 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:21,551 DEBUG [ContentDirectory] Browse() called for renderer UE46ES5700 (profile 7) with parameters: objectID = V_F^FOL_R2, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 30, sortCriteria =
2012-07-25 11:34:21,551 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder null
2012-07-25 11:34:21,552 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 1 (from=0, count=30)
2012-07-25 11:34:21,554 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2012-07-25 11:34:21,554 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2012-07-25 11:34:21,555 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2012-07-25 11:34:21,556 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2012-07-25 11:34:21,556 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1 and profile Samsung TV / player (C/D-series)
2012-07-25 11:34:21,557 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MVI_7352.MOV: AVC_TS_MP_HD_AC3_ISO
2012-07-25 11:34:21,557 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
2012-07-25 11:34:21,557 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2012-07-25 11:34:21,558 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2012-07-25 11:34:21,560 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root'
2012-07-25 11:34:21,561 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-07-25 11:34:21,565 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-25 11:34:21,669 DEBUG [WebServer] Incoming connection from /192.168.2.100:52831
2012-07-25 11:34:21,670 DEBUG [ResourceTransportRequestHandler] GET /resource/1/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.2.102:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-07-25 11:34:21,670 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:21,671 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.2.100, Profile=Samsung TV / player (C/D-series)'
2012-07-25 11:34:21,671 DEBUG [ResourceTransportRequestHandler] Request for resource 1 and type 'COVER_IMAGE' received
2012-07-25 11:34:21,671 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
2012-07-25 11:34:21,672 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 1
2012-07-25 11:34:21,672 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 4696
2012-07-25 11:34:21,673 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-07-25 11:34:21,673 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 4696,Date: Wed, 25 Jul 2012 09:34:21 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-07-25 11:34:21,785 DEBUG [WebServer] Incoming connection from /192.168.2.100:52832
2012-07-25 11:34:21,785 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2012-07-25 11:34:25,476 DEBUG [RendererManager] Removing renderer 0d1cef01-00dc-1000-a2c5-4844f7a68614 from list of active renderers
2012-07-25 11:34:33,259 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2012-07-25 11:34:39,759 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-07-25 11:34:39,759 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
Post Wed Jul 25, 2012 4:41 pm
I need to see the FFmpeg command it produces, which is not in the posted log
patagonia
Post Wed Jul 25, 2012 5:41 pm
I just post the whole part of the logfile for this action. Thks for your support!
2012-07-25 11:34:02,445 DEBUG [WebServer] Incoming connection from /192.168.2.100:52804
2012-07-25 11:34:02,445 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2012-07-25 11:34:07,782 DEBUG [WebServer] Incoming connection from /192.168.2.100:52805
2012-07-25 11:34:07,783 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.2.100:
2012-07-25 11:34:07,783 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:07,789 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-25 11:34:07,926 DEBUG [WebServer] Incoming connection from /192.168.2.100:52806
2012-07-25 11:34:07,927 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.2.100:
2012-07-25 11:34:07,927 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:07,932 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-25 11:34:07,968 DEBUG [WebServer] Incoming connection from /192.168.2.100:52807
2012-07-25 11:34:07,969 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.2.100:
2012-07-25 11:34:07,969 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:07,975 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-25 11:34:08,440 DEBUG [WebServer] Incoming connection from /192.168.2.100:52808
2012-07-25 11:34:08,441 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.2.100:
2012-07-25 11:34:08,441 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:08,447 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-25 11:34:08,465 DEBUG [WebServer] Incoming connection from /192.168.2.100:52809
2012-07-25 11:34:08,466 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.2.100:
2012-07-25 11:34:08,466 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:08,470 DEBUG [ContentDirectory] Browse() called for renderer UE46ES5700 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-07-25 11:34:08,471 DEBUG [VideoDAOImpl] Retrieving number of video initials
2012-07-25 11:34:08,476 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-25 11:34:08,595 DEBUG [WebServer] Incoming connection from /192.168.2.100:52810
2012-07-25 11:34:08,595 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.2.100:
2012-07-25 11:34:08,595 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:08,600 DEBUG [ContentDirectory] Browse() called for renderer UE46ES5700 (profile 7) with parameters: objectID = V, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 30, sortCriteria =
2012-07-25 11:34:08,600 DEBUG [VideoDAOImpl] Retrieving number of video initials
2012-07-25 11:34:08,601 DEBUG [VideoDAOImpl] Retrieving number of videos of type 2
2012-07-25 11:34:08,602 DEBUG [SeriesDAOImpl] Retrieving number of series
2012-07-25 11:34:08,603 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO
2012-07-25 11:34:08,603 DEBUG [VideoDAOImpl] Retrieving number of 10 last viewed videos
2012-07-25 11:34:08,605 DEBUG [VideoDAOImpl] Retrieving number of 10 last added videos
2012-07-25 11:34:08,605 DEBUG [VideoDAOImpl] Retrieving number of videos of type 0
2012-07-25 11:34:08,606 DEBUG [GenreDAOImpl] Retrieving number of genres for VIDEO
2012-07-25 11:34:08,607 DEBUG [PersonDAOImpl] Retrieving number of person initials for role ACTOR
2012-07-25 11:34:08,609 DEBUG [PersonDAOImpl] Retrieving number of person initials for role DIRECTOR
2012-07-25 11:34:08,610 DEBUG [PersonDAOImpl] Retrieving number of person initials for role PRODUCER
2012-07-25 11:34:08,611 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [FEED, WEB_RESOURCE] OnlineRepositories for VIDEO
2012-07-25 11:34:08,612 DEBUG [OnlineRepositoryDAOImpl] Retrieving list of [LIVE_STREAM] OnlineRepositories for VIDEO
2012-07-25 11:34:08,624 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-25 11:34:08,784 DEBUG [WebServer] Incoming connection from /192.168.2.100:52811
2012-07-25 11:34:08,785 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2012-07-25 11:34:09,853 DEBUG [WebServer] Incoming connection from /192.168.2.100:52812
2012-07-25 11:34:09,854 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.2.100:
2012-07-25 11:34:09,854 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:09,859 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-25 11:34:09,879 DEBUG [WebServer] Incoming connection from /192.168.2.100:52813
2012-07-25 11:34:09,879 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.2.100:
2012-07-25 11:34:09,879 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:09,884 DEBUG [ContentDirectory] Browse() called for renderer UE46ES5700 (profile 7) with parameters: objectID = V_F, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-07-25 11:34:09,885 DEBUG [RepositoryDAOImpl] Retrieving list of Repositories for VIDEO (from=0, count=1)
2012-07-25 11:34:09,897 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root'
2012-07-25 11:34:09,929 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO
2012-07-25 11:34:09,930 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-07-25 11:34:09,934 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-25 11:34:09,954 DEBUG [WebServer] Incoming connection from /192.168.2.100:52814
2012-07-25 11:34:09,954 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.2.100:
2012-07-25 11:34:09,954 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:09,957 DEBUG [ContentDirectory] Browse() called for renderer UE46ES5700 (profile 7) with parameters: objectID = V_F, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 30, sortCriteria =
2012-07-25 11:34:09,957 DEBUG [RepositoryDAOImpl] Retrieving list of Repositories for VIDEO (from=0, count=30)
2012-07-25 11:34:09,965 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root'
2012-07-25 11:34:09,966 DEBUG [RepositoryDAOImpl] Retrieving number of repositories for VIDEO
2012-07-25 11:34:09,966 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-07-25 11:34:09,969 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-25 11:34:10,080 DEBUG [WebServer] Incoming connection from /192.168.2.100:52815
2012-07-25 11:34:10,080 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2012-07-25 11:34:11,291 DEBUG [WebServer] Incoming connection from /192.168.2.100:52816
2012-07-25 11:34:11,291 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.2.100:
2012-07-25 11:34:11,291 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:11,297 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-25 11:34:11,316 DEBUG [WebServer] Incoming connection from /192.168.2.100:52817
2012-07-25 11:34:11,316 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.2.100:
2012-07-25 11:34:11,316 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:11,321 DEBUG [ContentDirectory] Browse() called for renderer UE46ES5700 (profile 7) with parameters: objectID = V_F^FOL_R2, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-07-25 11:34:11,321 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder null
2012-07-25 11:34:11,335 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 1 (from=0, count=1)
2012-07-25 11:34:11,363 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2012-07-25 11:34:11,369 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2012-07-25 11:34:11,378 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2012-07-25 11:34:11,402 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2012-07-25 11:34:11,416 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1 and profile Samsung TV / player (C/D-series)
2012-07-25 11:34:11,418 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MVI_7352.MOV: AVC_TS_MP_HD_AC3_ISO
2012-07-25 11:34:11,418 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
2012-07-25 11:34:11,446 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2012-07-25 11:34:11,447 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2012-07-25 11:34:11,448 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root'
2012-07-25 11:34:11,449 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-07-25 11:34:11,454 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-25 11:34:11,516 DEBUG [WebServer] Incoming connection from /192.168.2.100:52818
2012-07-25 11:34:11,516 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.2.100:
2012-07-25 11:34:11,516 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:11,521 DEBUG [ContentDirectory] Browse() called for renderer UE46ES5700 (profile 7) with parameters: objectID = V_F^FOL_R2, browseFlag = BrowseDirectChildren, filter = *, startIndex = 0, count = 30, sortCriteria =
2012-07-25 11:34:11,521 DEBUG [FolderDAOImpl] Getting number of sub-Folders in folder null
2012-07-25 11:34:11,523 DEBUG [VideoDAOImpl] Retrieving list of videos for folder 1 (from=0, count=30)
2012-07-25 11:34:11,547 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2012-07-25 11:34:11,547 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2012-07-25 11:34:11,548 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2012-07-25 11:34:11,549 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2012-07-25 11:34:11,550 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1 and profile Samsung TV / player (C/D-series)
2012-07-25 11:34:11,550 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MVI_7352.MOV: AVC_TS_MP_HD_AC3_ISO
2012-07-25 11:34:11,550 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
2012-07-25 11:34:11,551 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2012-07-25 11:34:11,551 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2012-07-25 11:34:11,553 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 'root'
2012-07-25 11:34:11,554 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-07-25 11:34:11,558 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-25 11:34:11,616 DEBUG [WebServer] Incoming connection from /192.168.2.100:52819
2012-07-25 11:34:11,616 DEBUG [ResourceTransportRequestHandler] GET /resource/1/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.2.102:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2012-07-25 11:34:11,616 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:11,618 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.2.100, Profile=Samsung TV / player (C/D-series)'
2012-07-25 11:34:11,619 DEBUG [ResourceTransportRequestHandler] Request for resource 1 and type 'COVER_IMAGE' received
2012-07-25 11:34:11,620 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
2012-07-25 11:34:11,621 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 1
2012-07-25 11:34:11,623 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 4696
2012-07-25 11:34:11,624 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-07-25 11:34:11,624 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 4696,Date: Wed, 25 Jul 2012 09:34:11 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=00D00000000000000000000000000000,transferMode.dlna.org: Interactive]]
2012-07-25 11:34:11,693 DEBUG [WebServer] Incoming connection from /192.168.2.100:52820
2012-07-25 11:34:11,693 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2012-07-25 11:34:13,573 DEBUG [WebServer] Incoming connection from /192.168.2.100:52821
2012-07-25 11:34:13,573 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.2.100:
2012-07-25 11:34:13,573 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:13,578 DEBUG [ContentDirectory] Browse() called for renderer UE46ES5700 (profile 7) with parameters: objectID = V_F^FOL_R2$MI1, browseFlag = BrowseMetadata, filter = *, startIndex = 0, count = 1, sortCriteria =
2012-07-25 11:34:13,579 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2012-07-25 11:34:13,580 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2012-07-25 11:34:13,580 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2012-07-25 11:34:13,581 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2012-07-25 11:34:13,583 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2012-07-25 11:34:13,584 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1 and profile Samsung TV / player (C/D-series)
2012-07-25 11:34:13,584 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MVI_7352.MOV: AVC_TS_MP_HD_AC3_ISO
2012-07-25 11:34:13,585 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
2012-07-25 11:34:13,585 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2012-07-25 11:34:13,586 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2012-07-25 11:34:13,588 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2012-07-25 11:34:13,594 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-25 11:34:14,261 DEBUG [WebServer] Incoming connection from /192.168.2.100:52822
2012-07-25 11:34:14,262 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO*0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,Host: 192.168.2.102:8895]]
2012-07-25 11:34:14,262 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:14,263 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.2.100, Profile=Samsung TV / player (C/D-series)'
2012-07-25 11:34:14,264 DEBUG [ResourceTransportRequestHandler] Request for resource 1 and type 'MEDIA_ITEM' received
2012-07-25 11:34:14,264 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1 (local)
2012-07-25 11:34:14,264 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2012-07-25 11:34:14,265 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2012-07-25 11:34:14,266 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1, format AVC_TS_MP_HD_AC3_ISO and profile Samsung TV / player (C/D-series)
2012-07-25 11:34:14,266 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file MVI_7352.MOV
2012-07-25 11:34:14,266 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MVI_7352.MOV: AVC_TS_MP_HD_AC3_ISO
2012-07-25 11:34:14,267 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-07-25 11:34:14,268 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Wed, 25 Jul 2012 09:34:14 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_MP_HD_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-07-25 11:34:14,281 DEBUG [WebServer] Incoming connection from /192.168.2.100:52823
2012-07-25 11:34:14,281 DEBUG [ResourceTransportRequestHandler] GET /resource/1/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO*0 HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,getMediaInfo.sec: 1,TimeSeekRange.dlna.org: npt=0-,Host: 192.168.2.102:8895]]
2012-07-25 11:34:14,281 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:14,282 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.2.100, Profile=Samsung TV / player (C/D-series)'
2012-07-25 11:34:14,283 DEBUG [ResourceTransportRequestHandler] Request for resource 1 and type 'MEDIA_ITEM' received
2012-07-25 11:34:14,283 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1 (local)
2012-07-25 11:34:14,283 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2012-07-25 11:34:14,284 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2012-07-25 11:34:14,285 DEBUG [VideoDeliveryEngine] Delivering item '1' for client 'IPAddress=/192.168.2.100, Profile=Samsung TV / player (C/D-series)'
2012-07-25 11:34:14,285 DEBUG [VideoDeliveryEngine] Delivering file 'MVI_7352.MOV' using transcoding
2012-07-25 11:34:14,285 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.2.100, Profile=Samsung TV / player (C/D-series)'
2012-07-25 11:34:14,286 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2012-07-25 11:34:14,288 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: C:\temp\MOV\MVI_7352.MOV
2012-07-25 11:34:14,288 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i C:\temp\MOV\MVI_7352.MOV -y -async 1 -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec ac3 -ab 192k -ar 48000 -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-1-MPEG2TS.stf
2012-07-25 11:34:14,788 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-07-25 11:34:14,789 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MVI_7352.MOV: AVC_TS_MP_HD_AC3_ISO
2012-07-25 11:34:14,789 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1) as read
2012-07-25 11:34:14,807 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-07-25 11:34:14,807 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 50000000000
2012-07-25 11:34:14,808 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-07-25 11:34:14,808 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-109.0/109,Content-Length: 50000000000,Date: Wed, 25 Jul 2012 09:34:14 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_MP_HD_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,MediaInfo.sec: SEC_Duration=109000;]]
2012-07-25 11:34:17,151 DEBUG [WebServer] Incoming connection from /192.168.2.100:57132
2012-07-25 11:34:17,151 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO*0 HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2012-07-25 11:34:17,151 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:17,152 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.2.100, Profile=Samsung TV / player (C/D-series)'
2012-07-25 11:34:17,153 DEBUG [ResourceTransportRequestHandler] Request for resource 1 and type 'MEDIA_ITEM' received
2012-07-25 11:34:17,153 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1 (local)
2012-07-25 11:34:17,153 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2012-07-25 11:34:17,155 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2012-07-25 11:34:17,156 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1, format AVC_TS_MP_HD_AC3_ISO and profile Samsung TV / player (C/D-series)
2012-07-25 11:34:17,156 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file MVI_7352.MOV
2012-07-25 11:34:17,156 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MVI_7352.MOV: AVC_TS_MP_HD_AC3_ISO
2012-07-25 11:34:17,156 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2012-07-25 11:34:17,157 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2012-07-25 11:34:17,159 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-07-25 11:34:17,160 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Wed, 25 Jul 2012 09:34:17 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.2,Cache-control: no-cache,transferMode.dlna.org: Streaming,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_MP_HD_AC3_ISO;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000]]
2012-07-25 11:34:18,509 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-07-25 11:34:20,521 DEBUG [WebServer] Incoming connection from /192.168.2.100:52824
2012-07-25 11:34:20,522 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_SetBookmark"' from 192.168.2.100:
2012-07-25 11:34:20,522 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:20,526 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2012-07-25 11:34:20,528 DEBUG [GenreDAOImpl] Reading a Genre (id = 1)
2012-07-25 11:34:20,528 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2012-07-25 11:34:20,529 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2012-07-25 11:34:20,531 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2012-07-25 11:34:20,532 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1 and profile Samsung TV / player (C/D-series)
2012-07-25 11:34:20,532 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MVI_7352.MOV: AVC_TS_MP_HD_AC3_ISO
2012-07-25 11:34:20,532 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 1)
2012-07-25 11:34:20,533 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2012-07-25 11:34:20,534 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2012-07-25 11:34:20,536 DEBUG [MediaItemDAOImpl] Bookmarking MediaItem (id = 1) at 0 seconds
2012-07-25 11:34:20,548 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-07-25 11:34:20,548 DEBUG [LocalContentCacheDecorator] Cleared cache (local_default)
2012-07-25 11:34:20,549 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-25 11:34:21,273 DEBUG [WebServer] Incoming connection from /192.168.2.100:52825
2012-07-25 11:34:21,274 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.2.100:
2012-07-25 11:34:21,274 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:21,280 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-25 11:34:21,406 DEBUG [WebServer] Incoming connection from /192.168.2.100:52826
2012-07-25 11:34:21,407 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.2.100:
2012-07-25 11:34:21,407 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:21,412 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-25 11:34:21,448 DEBUG [WebServer] Incoming connection from /192.168.2.100:52827
2012-07-25 11:34:21,448 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.2.100:
2012-07-25 11:34:21,448 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:21,453 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-25 11:34:21,471 DEBUG [WebServer] Incoming connection from /192.168.2.100:52828
2012-07-25 11:34:21,474 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"' from 192.168.2.100:
2012-07-25 11:34:21,474 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
2012-07-25 11:34:21,479 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-07-25 11:34:21,500 DEBUG [WebServer] Incoming connection from /192.168.2.100:52829
2012-07-25 11:34:21,501 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.2.100:
2012-07-25 11:34:21,501 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.100
Post Wed Jul 25, 2012 9:54 pm
that looks ok and the TV should play this kind of file. Can you try with 1.0 ?
patagonia
Post Fri Jul 27, 2012 2:05 pm
same behaviour with serviio 1.0
Post Fri Jul 27, 2012 6:13 pm
ok, it might be because of the high video bitrate (40 MBit)
you might have to transcode the videos, which will need powerful PC... try to change this to the C/D/E profile
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="192" maxVBitrate="20000">
      <Matches container="*" vCodec="h264" profile="high_10" />
      <Matches container="*" vCodec="h264" profile="high" levelGreaterThan="4.2" />
      <Matches container="*" vCodec="h264" profile="main" levelGreaterThan="4.2" />
to
                <Matches container="mp4" vCodec="h264" aCodec="lpcm" />
patagonia
Post Sat Jul 28, 2012 8:46 am
Now it's working - thks a lot.
I'm wondering because I have a Xeon E5620 CPU @ 2,4 GHz (4 cores + 4 virtual cores). Anyway, it's working - that's the main thing!
rm3086
Post Sun Apr 12, 2015 8:59 am
Re: [SOLVED] Playing MOV-files on Samsung E-Series TV
I am running into the same issues with Serviio 1.5, but it seems the profile.xml format has changed since the posting. How do I change the current configuration to be able to get a .mov created on a canon camera and displayed on a Samsung ESeries TV?
Question everything
